Page 1 of 5 123 ... LastLast
Results 1 to 20 of 92
Dismantling a Monitor
| TV and Monitor Recycling
    Mechanic688 started this thread.
    I took a few pic's that I hope will answer a few questions for the newbee's on dismantling a monitor. Hope this helps someone; Just make sure it has not been plugged in for awhile, don't want anyone getting shocked! And please do not break the tube.
    Cover unscrewed and ready to remove.
    Just removed the cover, ready to unplug silver box on top. Silver box has a small circuit board inside. (can usually cut open the box to remove the low grade board) Box is tin.
    Removed the plug-in box on neck of tube(see socket pins)
    Circuit board unplugged and removed from the monitor, black transformer top right, surrounded by alum heat sink. Two smaller alum. heat sinks in the middle. (only things of value on this low grade board) If IC chip is big enough then I will use a chisel and pop it off, (lower left). Just a couple of copper bearing items (coils-chokes) on this board to be removed.
    Close up of the yoke and degaussing cable around the tube. Small silver braid wire is actually copper braid, and degaussing cable is larger black cable that goes around the tube. Yoke still attached. (degaussing cable is usually copper or alum. wire wrapped in black tape)
  2. The Following 11 Users say Thank You for This Post by Mechanic688:
    The yoke is next after removing metal clamps; some have one clamp, others two. (the clamps are usually stainless steel)
    Sliding the yoke off the neck of the tube. I usually take the yoke after removal, and set it on some concrete and hit it with a hammer(use eye protection) and the ferrite the copper is wrapped around will break or shatter.
    Throw the ferrite in the steel bucket. Copper goes as #2 clean.(the reason for it being #2 is because it's varnished)
    This is a bonus; Inside of a computer power supply after removing cover. Fan to the right while up top is transformer, straight in is two alum. heatsinks.
    TheHoss's Avatar
    The tater state
    863
    1,111
    A fan?! I dont know how many TV's/CRT's i've torn apart that dont have a fan. In fact, none that i've torn apart have ever had a fan. Pretty cool! That degaussing cable is copper, to anyone who didnt know. Just unwind the black tape and BAM, their ya go. I believe that sometimes it can be aluminum also...you can usually tell by the weight.
    Also, the big black transformer surrounded by the alum heatsink, is their anything in that? I've never torn that apart. Always all the other copper windings, and smaller transformers.
    Good pic tutorial!
  5. The Following User Says Thank You to TheHoss for This Post:
    that was a computer power supply the fan is in,,,
    The black transformer has copper in it but I think it's epoxy baked so we turn them in with other small transformers and small motors. The black tape on the degaussing cable is real easy to slice thru with a razor knife, I can do 5 of them an hour while watching tv.
  7. The Following User Says Thank You to Mechanic688 for This Post:
    TheHoss's Avatar
    The tater state
    863
    1,111
    Hey, yeah, sorry i didnt see that, try being nicer about correcting folks.
    Hoss, read my lips, that was a computer power supply the fan is in,,,
    Hoss, wasn't being mean, I just enlarged it in case anyone else mistook the last picture, sorry. Your right, I've never seen a fan in a tv or monitor. I took the last pic the same time as the other dismantling so I just thought I'd add it also, for the newbee's, like I said.
    rca987's Avatar
    939
    Quote Originally Posted by TheHoss View Post
    I don't think you'd be able to tell by the weight as much as you could tell by the color. Just snip it somewhere to break the "circle" and look at the fresh cut ends... it will be either copper(redish) color or aluminum(silver) color.
  11. The Following User Says Thank You to rca987 for This Post:
    fiat128 is offline Metal Recycling Entrepreneur
    187
    Interesting, I've always thrown the ferrite in the trash. It's mostly ceramic right? Seems to me to be about the same a sticking a brick in with every load as it's not really recycleable is it?
    It sticks to a magnet and is also the material that magnets for your car stereo is made out of, I've always heard that ferrite is recyclable. No I'm not padding my weight bucket.
    it has a powdered metal of some sort in it.
    Thanks to Wiki for this;
    A ferrite is a type of ceramic compound composed of iron oxide (Fe2O3) combined chemically with one or more additional metallic elements.[1] They are ferromagnetic, meaning they can be magnetized or attracted to a magnet, and are electrically nonconductive
  14. The Following User Says Thank You to Mechanic688 for This Post:
    Here is an idea of the copper that just came out of a normal degaussing cable. About a pound worth.
  16. The Following 2 Users say Thank You for This Post by Mechanic688:
    And here is an example of some aluminum wire that came out of some degaussing cables, you can tell by weight after you've done quite a few. Doesn't seem to be any rhyme or reason for the colors.
    Re-cycler is offline Metal Recycling Entrepreneur
    Re-cycler's Avatar
    Southwest MN
    168
    125
    Very nicely laid out. This is the kind of info that anyone wandering the internet search engines hopes to find, thanks for sharing......
  19. The Following 3 Users say Thank You for This Post by Re-cycler:
  20. #13
    Re-cycler's Avatar
    Southwest MN
    168
    125
    But where are the nekkid ladies????
  21. The Following 3 Users say Thank You for This Post by Re-cycler:
  22. #14
    I figured it was easier to post the pic's than answer the same questions 10 times. Hope I'm right,,,
  23. The Following 2 Users say Thank You for This Post by Mechanic688:
  24. #15
    Re-cycler's Avatar
    Southwest MN
    168
    125
    yeah yeah.....that was good , but where are the nekkid ladies??
    Anyone guess that the full moon amps me up a little?
  25. #16
    2,161
    Dang, I always wondered what those big heavy black things were int he third piture top right corner - I didnt know those were transformers and couldn't find ANY info on the google search for those either was probably doing it wrong. thanks for the info!
  26. #17
    When you look at a circuit board, the hi voltage orange/red wire comes from those black transformers and goes to the picture tube(suction cup). Like I said earlier I think their epoxy wrapped or baked but there is copper wrapped inside, and that is what make some of the hi voltage for the tube. I've never tried to beat one apart, we just turn them in with other xformers. Looking at the third picture you can see where I cut the red wire off the xformer after discharging.
    Someone on here took one apart and for the time invested in getting it apart it just wasn't worth it.
  27. The Following User Says Thank You to Mechanic688 for This Post:
  28. #18
    New jersey
    133
    14
    Nice post, I am just harvesting my first monitor and had some questions, you answered them all. By the way, I just took a razor knife down the middle of the degaussing cable and peeled the tape right off, no real problem.
  29. The Following User Says Thank You to fnd5055 for This Post:
  30. #19
    New jersey
    133
    14
    Still the question though, what to do with the CRT when your done with it.
  31. The Following 2 Users say Thank You for This Post by fnd5055:
  32. #20
    We have a company over in Ohio that accepts them for recycle (I think you pay). Out east there is a huge amount of factory's and I'll bet someone out there recycles the tubes also. Just need to really research it.
    Some Goodwills will accept them whole and some stripped with the plastic put back on.
    The only ones I don't like are the sticky tape ones. When your done with one of them everything around you sticks to you whether you want it to or not!
  33. The Following 2 Users say Thank You for This Post by Mechanic688:
    1. Dismantling a CD/DVD Drive;
      By Mechanic688 in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 12-20-2012, 11:25 PM
    2. dismantling vs nondismantling
      By ZE608 in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 04-01-2012, 09:56 AM
    3. Dismantling a Monitor
      Last Post: 03-19-2012, 12:24 PM
    4. Dismantling tires from aluminum rims
      By gustavus in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 10-16-2011, 03:13 PM
    5. Dismantling forum
      By wayne1956 in forum Off Topic Discussions
      Last Post: 08-30-2011, 08:42 PM
There are currently 2 users browsing this thread. (0 members and 2 guests)
