Results 1 to 20 of 27
Dismantling a CD/DVD Drive;
    Mechanic688 started this thread.
    This will show you what's on the inside of a CD/DVD drive. You can sell them whole or broke down to maximize your profits. There is usually 2 to 6 screws in the bottom cover
    and under the cover is the circuit board. Older drives have one large board (hi-grade) and newer ones have a small hi grade board and a smaller low grade board with a motor attached. Older,,,
    Newer,,,
    Just pop the plastic clips (sometimes 2 screws) and remove the board.
    I use a large screwdriver and pry the plastic drive carriage out of the metal shell, and separate the smaller drive carriage from the sliding tray. Usually that just goes into the steel pile as it has a motor, laser eye, and metal rods. Drives have 2-3 small motors, one for the sliding carriage and one to spin the disc.
    Some people go further and save the drive head with the eye as the head should have a laser diode with gold plating on it.
    GeorgeB's Avatar
    Manassas Park, VA
    2,919
    462
    What type of board would it be considered? Either way, not bad considering all in all should take you what a minute if that to do it.
    George, the single board or the larger of the two is considered hi-grade because of the gold plated pins (see the board on the wood desk) the small board with motor is just low-grade (even tho it's green). Ya, about a minute or two if you just pull the board, maybe 5 minutes to pull the carriage and separate and pull the extra motor out of the plastic.
    This drive has a total of 3 motors, 2 are easy to pull, the third just goes with the metal carriage.
  4. The Following 4 Users say Thank You for This Post by Mechanic688:
    GeorgeB's Avatar
    Manassas Park, VA
    2,919
    462
    George, the single board or the larger of the two is considered hi-grade because of the gold plated pins (see the board on the wood desk) the small board with motor is just low-grade (even tho it's green). Ya, about a minute or two if you just pull the board, maybe 5 minutes to pull the carriage and seperate and pull the extra motor out of the plastic.
    The 3rd picture from the top also has a chip right? I have been curious, how do you remove a chip?
    Like I said, not bad. Will keep that in mind for cd drives.
    Those chips are all soldered in so I don't mess with them. there is small removable IC chips on PCI, video cards that can be sold separately. I take this back; Picture #4 over in the top right side of the board is a small removable IC chip.(with white paper label) Don't see them too often on this style of board.
    directrecycle's Avatar
    521
    94
    using a 7 volt drill with a #1 phillips tip i was able to process 65 in one hour. Removed 17 pounds of hi grade boards. Didnt take the time to remove motors. I purchased these at current scrap rate of.10 per pound
    beginning weight - 137 pounds...$13.70
    hi grade boards 17 #'s @ 4.20 = $71.40
    remaining steel - 120#'s @ .10 =$ 12.00
  8. The Following 6 Users say Thank You for This Post by directrecycle:
    Torker Man's Avatar
    Melbourne, Australia
    381
    Quote Originally Posted by directrecycle View Post
    Nice numbers
    I get $3.10 a lb for these boards over here in Aus, but I don't have alot of choice of buyer at the moment...
    So you left the plastic front cover on them? or seperated that too? Is there a market for the laser unit?
    Many thanks
    2,529
    2,906
    Theres tiny magnets around the lens assembly, really really strong magnets.
  11. The Following User Says Thank You to eesakiwi for This Post:
    I didn't find any little super magnets in the cd/drives, only in the hard drives.
    harrisvh is offline Metal Recycling Entrepreneur
    Nottingham
    181
    26
    They are there, they are just much smaller and square in shape
  14. The Following User Says Thank You to harrisvh for This Post:
    6,810
    Haha, Thanks Mech! This is the one I was looking for, not exactly how I remembered, but tells what I wanted to know. I was thinking one you had taken the eye apart to a little gold something in there?
  16. The Following User Says Thank You to Bear for This Post:
    Are you thinking about these?? These are laser eye's out of CD/DVD drive heads, the one in the middle of the drive on the slider bars. Usually tucked up into the side of the laser. Some just have gold legs and others are solid plated. .
  18. The Following 7 Users say Thank You for This Post by Mechanic688:
    6,810
    I believe it is Mech, where do I get to those at? I have about 50 or 60 or maybe a 100 if i get into my old stash, that I'm going to be scrapping
  20. #14
    jghilino's Avatar
    KANSAS CITY
    2,673
    1,422
    those gold plated eyes go in the bag with the gold pins $60 pound all day long, also find nice little gold chunks like that in cell phones =)
  21. The Following 4 Users say Thank You for This Post by jghilino:
  22. #15
    If you look right behind the #1 motor there is the laser eye that slides back and forth. I usually pry it loose and look around the side of it and the little round eye will be "glued" into the side. Usually have the small ribbon circuit attached to it.
  23. The Following 4 Users say Thank You for This Post by Mechanic688:
  24. #16
    jghilino's Avatar
    KANSAS CITY
    2,673
    1,422
    you can also see some mylar ribbon cables in them, save those up even silver mylar is valuable
  25. The Following 3 Users say Thank You for This Post by jghilino:
  26. #17
    travistemple202020's Avatar
    ames iowa
    1,326
    266
    yep I strip and sell everything from them boards steel laser eyes whole pieces since I do not want to myself gears belts motors and pulleys usually average $2-3 a drive or more if juicy lol
  27. #18
    joebob49 is offline Metal Recycling Entrepreneur
    Kentucky
    217
    159
    Remove the jumpers also. The little white rectangle thing in the top pic. I send mine with the pins and stuff to be refined. Its on the pins .
  28. #19
    NC
    213
    99
    Yall are killin me. I have around 500 or so carcases from CD drives that I have just been throwing in a box until I figure out what to do with them. I pop them open grab the board separate the the case and throw the rest in a box.
  29. The Following User Says Thank You to CarolinaEwaste for This Post:
  30. #20
    LarryB is offline Metal Recycling Entrepreneur
    LarryB's Avatar
    Ottawa, Ontario, Canada
    221
    886
    Quote Originally Posted by jghilino View Post
    Far freak'n out brother. Just pulled my first ones out and started a empty shot glass container, thinking it'll be well over an oz before I know it. Thanx for your sharing. lb
  31. Similar threads on the Scrap Metal Forum
    1. Dismantling a Monitor
      By Mechanic688 in forum TV and Monitor Recycling
      Last Post: 09-12-2013, 08:31 PM
    2. dismantling vs nondismantling
      By ZE608 in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 04-01-2012, 09:56 AM
    3. Dismantling a Monitor
      By Mechanic688 in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 03-19-2012, 12:24 PM
    4. Dismantling tires from aluminum rims
      By gustavus in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 10-16-2011, 03:13 PM
    5. Dismantling forum
      By wayne1956 in forum Off Topic Discussions
      Last Post: 08-30-2011, 08:42 PM
