Results 1 to 20 of 28
Breaking down an electric motor for copper
    PartTimeScrapper started this thread.
    3,400
    1,004
    Here is a pic of the motor as it weighs whole 27.8 lbs
    First as you can see there are 4 screw/bolts that you need to remove and then both ends of the motor will pop off. Center shaft can then be pulled out .
    Here you can see the center shaft out and the outer casing with all the copper in it.
    Here is the center shaft. On the end is a cast aluminum fan. Just wack it with a hammer and it breaks right off. Ended up weighing about .25 pounds.
    Here you must cut this weld or grind it off like I do and remove the outer metal case.
    3,400
    1,004
    Here is the weight of the copper and metal together. Now you have to cut off one side of the copper looped wire with either a metal cut of disk or sawsall.
    Here you can see the end when its been cut off. Now use a punch and hammer and push the strands threw the motor housing or pry them out threw the other side. I pryed this one out using a screw driver and channel locks.
    Here is all the copper removed from the housing. Total weight of copper is 3.5 pounds the metal popcorn tin the copper is in weighed 1.1 pounds.
    So it started out at 27.8 LBS at $.41/lb = $11.40
    Broke down we had 3.5 lbs of copper at $3.50/lb = $12.25
    .25 lbs of cast alliminum at $.52 = $.13
    24 lbs of steel at $.10/lbs = $2.40
    Total after tear down is $14.78 for a difference of $3.38
    Now this motor took me about an hour to tear down because I was taking pictures. This one really was a pain in the but to get the copper out because I didnt have a small enuff punch to just punch the copper out so I had to pry it out with screw driver and channel locks. So all though there wasnt much money gained from it I hope this will help the rest of you on how to tear a motor apart for the copper.
    Good job, very informative! If you were to do quite a few motors at a time you might want to sweep up the copper grindings that are left over and include them into a bucket for scrapping.
    GeorgeB's Avatar
    Manassas Park, VA
    2,919
    462
    Thanks for the pictures part time scrapper. I need to get a new grinder myself.
    10
    Thanks for the post. Where did you get that cool scale?
    3,400
    1,004
    ebay 15 bucks.
    Nice work Part Time. May I suggest instead of cutting/grinding through the weld you cut the thinner metal jacket.
    When I cut the housing I start with an old pair of Wiss aviation snips. I cut in as far as I can on each side then just use cutting wheel to finish connecting the two snip cuts. This saves not only electric and time but it also saves on cutting wheel costs. On some motors I can cut inward enough to just peel back the metal housing with my large end nippers and tear the metal. The latter method is very fast and quiet! Great for working my scrap late at night.
    I mentioned "end nippers" before in the forums. The are the best for pulling out the windings. Harbor Freight sells them pretty cheap. At first they are a bit to sharp and tend to cut rather then grab. Simple fix is to file down the cutting edge a little.
  8. The Following 5 Users say Thank You for This Post by injunjoe:
    I did the same, pictures and weights, on several motors. I found that the heavy motor,74 lbs, had a lower percentage of copper than a group of small motors, total weight about 40 lbs. Also I find it much easier to remove the copper from the smaller motors. I will try to learn to post pictures. I purchase motors from another scrapper and then break them down. This is my main scraping activity so far.
    Thank you for taking the time to post the pictures I know it was time consuming. Best to you, Mike.
  10. The Following User Says Thank You to miked for This Post:
    I think I figured out how to post pictures. Here is my break down of the four smaller motors.
    Here is a link of the break down of the motors above, Mike.
    http://s597.photobucket.com/albums/t...medium%20mtrs/
  12. The Following 3 Users say Thank You for This Post by miked:
    neon's Avatar
    20
    Thank you for the pictures and showing your method. I have the same experience about copper volume as miked said. In a heavier ones is less percentage of copper per weight than in the small ones. It's getting to 7% in some heaviers and the most I got was from 24lbs one, similar as you posted (14%). When we know this, it's easy to calculate the profits and what should we pay for them. In my country (Czech), usual price per kg of unstripped motor is $0.40. I would never pay so much as you, it's not worth the time, as you perfectly documented.
    neon's Avatar
    20
    Btw, I get the stator from the casing usually by punching the casing with a hammer few times, very hard. It breaks easily when it's cast iron. It doesn't work, when it's aluminium - then I try to knock out the stator with a hammer and a chisel (when it's possible to hold in vice, it's better) - it gets out very often.
    skylinejack's Avatar
    Baton Rouge, La.
    827
    1,194
    Right now I have about 30 motors of similar size. My yard pays about the same as yours. So my profit would be about $101.40. I break em down on rainy days so all in all I guess it's worth to me. Thanks for the breakdown. Now I know about how many to do at a time. Great job!
    Upstate NY
    44
    23
    Thanks to those that contributed, very informative. On motors that have carbon brushes, I noticed the contact surface that rubs against the brushes is copper, about 1/8" thick, set in a sort of plastic material that can be busted out with a hammer. Not sure what that part is called.
    little726's Avatar
    74
    1,377
    Starting at the beginning, in the third photo, is there copper inside the dark part? The part is located above the fan.
    Mike.
    Also a nice job! When I run into bolts that refuse to come out from being snipped off during installation or just rust and abuse, I just go ahead and cut outer jacket and peel apart. Then you can just use bolt cutters on all four of the bolts. The rest pretty much falls apart for ya.
    Most of those motors you have in photo are condenser fan motors. I find they are exposed to the weather more then the air handler and tend to be a bit harder to pull the windings out! This is where my "recycled" saved up compressor oil comes into play! I Like to " baste" them in a shallow dish with my saved up "marinade" after I cut the one side and find them being a problem. That make the copper slide out'athere like ..............
    Hope this helps!
  19. The Following 5 Users say Thank You for This Post by injunjoe:
  20. #16
    3,400
    1,004
    Quote Originally Posted by little726 View Post
    Not in this motor it was solid. no copper winding inside it. It was aluminum with iron outside.
  21. The Following User Says Thank You to PartTimeScrapper for This Post:
  22. #17
    I will keep the oil trick in mind and use it next time I have a tought one. Very generous of you to share that info, Mike.
  23. #18
    little726's Avatar
    74
    1,377
    Thank you, PartTimeScrapper. I've been hack sawing an old sump pump motor and came across this same looking core.
    Do some of the motors have copper in that part?
  24. #19
    3,400
    1,004
    YEs but its obvious. You will see the windings. I throw that part in my breakage though. I think its to time consuming to get it from there but one of the other experienced motor breakers might have a good idea on how to do it.
  25. The Following User Says Thank You to PartTimeScrapper for This Post:
  26. #20
    ginofrater's Avatar
    May 2013
    506
    921
    PartTimeScrapper
    Nice post....nice pictures..very well done .
    Thanks.
    ginofrater
    1. Breaking down a 90lb motor
      By miked in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 03-06-2013, 09:15 PM
    2. Electric motor
      By Mick in forum A Day in the Life of a Scrapper
      Last Post: 10-27-2012, 06:06 PM
    3. Electric Trolling Motor
      By scrapmommyof3 in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 03-22-2012, 09:57 PM
    4. electric motor copper
      By devo in forum Scrap Metal Questions and Answers
      Last Post: 02-11-2012, 12:46 AM
    5. Electric Motor Copper Windings
      By Pronto Hauling in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 12-01-2011, 09:14 PM
There are currently 6 users browsing this thread. (0 members and 6 guests)
