Results 1 to 16 of 16
Maxing out a Motherboard
    ScrapperStoke started this thread.
    ScrapperStoke's Avatar
    Hamilton, NJ
    49
    35
    I did a search for motherboard in the sub and came up with two hits...lol. Neither of which had any thing to do with motherboards directly. So I thought I would start a Motherboard thread to discuss the best way to maximize ones profits on recycling motherboards. Hopeful both the buyer and supplier will partake and we can get the boundaries set on whats worthwhile to do and whats not. I'll start...
    Back in the day, we would just strip computers and throw all MBs into a Gaylord and send them off to Sabin for processing. But reading through this site, I'm not that sure that was the correct way to maximize profits. I see people pulling off all kinds of stuff off of boards.
  2. The Following User Says Thank You to ScrapperStoke for This Post:
    Filthy's Avatar
    Northern New Jersey
    780
    849
    did you remove the CPUs first? im assuming that you have
    other than that, unless you can get more than the price of motherboard for any item attached to the board, you're better off leaving them intact.
    We're the renegades of Junk!
  4. The Following User Says Thank You to Filthy for This Post:
    Hi, we usually pull the cpu's like mentioned, then the cards get pulled if there's any on the MB. (this is on a normal computer) Then we pull the power supply and it goes in a separate box, hard drives(to be broken down later), floppy's- cd/dvd drives all go in the same box. We cut the wires off the power supplies and their sold that way. Mother boards, cards, cpu's, all go in separate totes.
  6. The Following User Says Thank You to Mechanic688 for This Post:
    Torker Man's Avatar
    Melbourne, Australia
    381
    I take the Li-Ion battery and the removable e-proms off them too, also that second heat sink thats stuck on to a surfac mounted chip.
    I do this as my buyer over here reduces the price if I leave them on.
    I also have to take the metal strip of all the ISA and PCI cards I sell.. or I loose $0.20 a Kg in rate.
  8. The Following User Says Thank You to Torker Man for This Post:
    I guess after reading the original post again, my answer wasn't close. If there actual mother boards we pull the cpu and heatsink, and memory and all the plug in cards, and if there's a small ic chip on a socket. That's about it.
    Hamilton, NJ
    49
    35
    I also read that people are pulling the gold pins and surface mounted capacitor chips. What kind of impact would that have on MB rates...is it even worh the time. Must be if a lot of people are doing it...right?
    SS
    Torker Man's Avatar
    381
    the small surface mount capacitors, or "Monolithic capacitors" have platinum listed as one of the items they contain (from manufacturers sites etc..) I do not know of anyone reliably getting any sort of real yeild from them...same goes for pins.
    I would rather get the MB price per lb for them, would take you at least 1 hr per board to remove the monos and pins...
    IMO
    IF you do that to all your motherboards, you have "cherrypicked" them and have taken the price per lb. from $3-4 per lb. down to .10-15 a lb. low grade price. Your better off getting the good money per lb. and letting the "pro's" do their own refining.
    Copper Head's Avatar
    Up North
    1,883
    579
    Do TV's have a 10-15 a lb. low grade price. as i find my share of tv's.
    Winnipeg, Manitoba
    26
    I am new to this venture but my plan is to only remove the following componenets from the motherboard.
    Fan (mostly plastic - don't know what to do with them yet, but I'm sure the board buyers don't need or want them)
    Heat sink (Solid Aluminum, and for a second or two of work the board buyers don't have to remove it before calculating the weight and sending a cheque)
    CPU (they will go to the same board buyer, but separated from the boards)
    Button Battery (again, not sure what to do with them, but they might as well be removed as the board buyer is mostly after the gold)
    This way I feel I am doing the fastest dismantle that will create resonable profit for both me as a seller and the board buyer/processer as well.
    Maybe a board buyer can chime in and let me know if I'm close or way off in my thinking.
    Scrapette's Avatar
    Kentucky USA
    942
    2,391
    Does anyone have a photo of a "monolithic capacitor" ? Thx.
    963
    612
    For us, you only need to remove the fan, CPU and heatsink... we go through every lb of boards here so we will remove the battery and have it recycled properly.
    Specializing in Maximum value for mixed precious metal printed circuit boards and electronics
    Check out our pricing and read some of our RAVING reviews: http://www.scrapmetalforum.com/scrap...tal-scrap.html
    QUESTIONS? Email us: info@CashForComputerScrap.com
    or Chat with us: www.CashForComputerScrap.com
    Winnipeg, Manitoba
    26
    Ewasted, to make it worth your while, and mine, what is a good shipment size(weight) for you to receive? 20lbs? 50lbs?, a heck of a lot more??
    Remember I would be shipping from Canada and I certainly don't want to start off on the wrong foot and be a PITA!
    Yes, tv's stereo's, vcr's, etc. etc.
    Here is also a surface mount tantalum cap.
    We throw our fan's (minus the plastic housing) in with the small transformers from low grade boards and small motors, our yard buys them all together; check with your yard, we don't know their policy!
    Ballymoss's Avatar
    Leeds, United Kingdom
    71
    11
    They come in different sizes and colours but most contain Silver (solder) and Palladium.
  20. #16
    Ballymoss thanks dude I was looking for a picture myself.
    1. golden motherboard
      By jghilino in forum Computer Recycling
      Last Post: 06-26-2013, 01:06 PM
    2. cpu soldered to motherboard?
      By phildogg in forum General Electronics Recycling
      Last Post: 06-12-2012, 09:22 PM
    3. motherboard break down
      By bigbade in forum Scrap Metal Questions and Answers
      Last Post: 11-26-2011, 10:41 PM
    4. motherboard break down
      By bigbade in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 11-26-2011, 11:44 AM
    5. Parts of a Motherboard
      By Mechanic688 in forum General Electronics Recycling
      Last Post: 11-10-2011, 07:06 PM
