Page 1 of 6 123 ... LastLast
Results 1 to 20 of 118
Computer parts Breakdown and identification
    PartTimeScrapper started this thread.
    3,398
    993
    Ok here goes my attempt at sorting out all the different types of computer parts and what they are commonly called.
    Lets start with the inside look of the whole computer.
    As you can see there is alot going on in there.
    Top left of picture is 2 dvd/cdrom drives and a 3.5 inch drive
    Bottom left is the power supply
    Bottom right is the motherboard and everything attached to it.
    Top right is the hard drive.
    On the motherboard
    Top left in the black slots you will see a ram stick.
    Middle left you will see a fan. Under that fan is the heatsink and CPU
    Bottom right you will see 2 PCI/AGP/FINGER Cards sticking up vertical from the motherboard.
    Now lets get a closer look at all the different parts out of the case.
    Lets start with different motherboards.
    This is a motherboard from a server.
    These are motherboards from home computers.
    You will notice they do look different. Most home computer motherboards will have square on them where the CPU plugs in where as a server board will usualy have slots card style CPU's or square mounted CPU's on riser cards.
    Also home computer motherboards will usually have 2 to 4 ram slots. Servers have alot more. If you look at the server motherboard all the white slots on the left side are for ram. This server board has room for 18 sticks of ram. That would be about a full pound if they were all full.
    [IMG][/IMG]
    In this picture you can see the different types of RAM chips.
    Top to bottom are
    Laptop/Printer style ram
    Oldschool 386/486 EDO RAM Silver or Gold Fingered
    Newer style ddr/ddr2/ddr3 RAM
    Server Ram
    Here is a picture of what most people call rambus. You will notice its just like a regualr RAM chip just cased in metal. Some of these are very easly removed. They use to sell heatsinks you could slip over your ram.
    3,398
    993
    Ok now on to diferent types of CPU's
    This picture shows the 3 different stages of a SLOT Processors. when selling these they have to be removed from the plastic case like the one on the bottom.
    This picture is of metal toped green fiber CPU's Commonly found in Pentium 4 systems, amd systems, and some mac's
    This picutre is of pentium and AMD green and brown fiber chips without metal tops. these are usualy pentium 2 and 3 and early amd series.
    This picture is of ceramic pentium and amd chips. Usualy these are pentium 1 chips notice no gold tops.
    Here is a pic of a golt top pentium chip.
    This is a pentium pro gold top chip. From what ive found out this is probable the heavist chip of them all and has the most gold content per chip of them all. Ive seen these sell for 20 to 30 bucks or more each on ebay.
    This is a 486 chip. The 386 chip looks just like it. These are the best chips by the pound as far as gold recovery goes. DONT throw these in with your ceramic chips they are worth about 3 times as much right now.
    This is the black fiber chips. They look and feel like plastic.
    These are PCI/AGP/FINGERBOARDS These plug into the motherboard and are usualy what you see when looking at the back of a computer. They have the gold finger looking things running down one side of the card.
    These are 3.5 inch floppy drives. Most people will just break off the gold connector you see in the middle drive in the picture and throw it in with there gold conector ends.
    3,398
    993
    This is a 5.25 inch floppy drive. I would put these on ebay and sell them instead of scrapping them. But if you want to scrap them you can take the board off of these just like you would a cd/dvd drive.
    This is a 3.5/5.25 combo floppy drive. DO NOT SCRAP THESE. Sell them on ebay. I just sold this one for $20 with free shipping on ebay untested. So after shipipng and fees I still made about $12.
    OK these next three pics show me taking apart acd/dvd rom drive just to get the board out. It took me a whole minute to do it and take all 3 pics. These boards fetch motherboard price if im not mistakin. Back panel was held on by 4 screws and then lifts right off. Then board just held in by plastic clamps and it to lifts right out. If you get DVDRW drives dont scrap them either. I sell them for $15 on ebay and $20 for the lightscribe ones.
    This is a pic of all diferent kinds of EPROMS/IC CHIPS/FLATBACKS. They all sell for same price.
    This is called ribbon cable. Cut the black parts off this is where all the gold plated pins are. When cut from copper wires throw them in a bucket with your connector ends from other cables like monitor and printer cables. Shown below.
    This is power supply. Personaly I just cut the wires off and throw the rest in my shred. Some yards will pay low copper breakage for them too. All depends on yard. Some yards even have there own prices for them.
    These are 3.5 inch hard drives. There are older 5.25 inch hard drives and 2.5 inch you will find in laptops. They pretty much all look the same. Pull the baords off and sell them seperate. They usualy go for 2 times the motherboard rate or better depending on buyer. the back plate is usualy Stainless and the rest of the drive body is cast alluminum. The boards are usualy only held on with a couple screws and come off real easy.
    Well thats it I hope this helps you all and if I missed anything let me know and ill add it to this post with an edit.
    3,398
    993
    Saving this spot for updates since there is a 10 picture max per post.
  5. The Following 3 Users say Thank You for This Post by PartTimeScrapper:
    directrecycle's Avatar
    521
    94
    in your ic/eprom pic the 2 gold top ones should bring 100+ per pound versus 6dollars per pound on the rest
  7. The Following User Says Thank You to directrecycle for This Post:
    6,998
    Great info and nice stock pile there PTS.
    ScrapperStoke's Avatar
    Hamilton, NJ
    49
    35
    Back in my day the power supplies were scrapped as copper bearing. Do they still do that?
    3,398
    993
    Quote Originally Posted by ScrapperStoke View Post
    Some yards do some yards dont. really depends on the yard.
    3,398
    993
    Quote Originally Posted by KZBell View Post
    LOL thanks thats not even touching the surface. My shed looks like a bomb hit it right now and I just cleaned it last weekend.
    little726's Avatar
    74
    1,377
    AWESOME post!!! These photos will really help me.
    ilovejunk's Avatar
    163
    112
    Bravo, nicely done, Sir.
    If you end up with quite a few ribbon cables, just find an old paper cutter from an office or school and it'll shear the end connectors off real slick like.
  15. The Following 8 Users say Thank You for This Post by Mechanic688:
    3,699
    Great post: !!!!!!!!!!! Thanks!!!!!!!!!
    3,398
    993
    Quote Originally Posted by olddude View Post
    Is that what you were asking for olddude?
    3,699
    QUESTIONS ON E PROMS AND FLAST PACKS.
    1. are all square chips considered flat packs
    2. are only the removable long chips e proms
    3. e waste buyers, does removing these from the boards down grade the board?
  19. The Following User Says Thank You to EcoSafe for This Post:
  20. #16
    3,398
    993
    Answers as i know them.
    1. The square ones with the metal fingers around the 4 sides are wat people call flatbacks. Thesquare ceramic grey looking ones are more like a CPU.
    2. No any chip that looks like these even if they are soldered to the board are eproms.
    3. Depends on buyer. I only pull the ones that can come off without tearing up the board. So far no downgrade from the people ive sold too. Now I know if I took every single one of them off they would surely downgrade it.
  21. The Following 3 Users say Thank You for This Post by PartTimeScrapper:
  22. #17
    Torker Man's Avatar
    Melbourne, Australia
    381
    Awesome post!
    Over here I get electric motor price for my power supplies (about 45 - 50c per KG, or like 20 - 22cents per lb)
    WOW gold connectors on ribbon cable...didn't know that, have moved 100s of lbs of these cables recently..Oh well, live and learn.
  23. #18
    I pull the one's that are on a socket and unplug only, anything more than that and your downgrading.
    Torker, that one has been posted a few times with pic's also.
  24. #19
    3,398
    993
    Thats exactly what I ment Mechanic the ones in sockets not sodlered to the board is the only ones I take off too. however I take them all off low grade boards. 1 inch wood chisel and hammer one smack and they literly fly right off.
  25. The Following 4 Users say Thank You for This Post by PartTimeScrapper:
  26. #20
    3,398
    993
    To the Admins THANKS FOR THE STICKY!!!! Took me 2 hours to right this post up glad to see you all appriciate the work. Thanks to all of you.
  27. The Following 13 Users say Thank You for This Post by PartTimeScrapper:
    1. Question on computer parts
      By justjunkin in forum General Electronics Recycling
      Last Post: 04-23-2012, 01:04 AM
    2. The different parts inside of a computer
      By easyrecycle in forum General Electronics Recycling
      Last Post: 09-25-2011, 09:12 PM
There are currently 4 users browsing this thread. (0 members and 4 guests)
