Results 1 to 9 of 9
comparative motherbaord valuation
    rbrooks715 started this thread.
    261
    127
    the ongoing 'discussion' about the valuation of a motherboard.
    i am going to offer a solution that will end that discussion.
    this something that any member or guest will be able to do for themselves. no need to determine if one opinion or link is viable or correct.
    you will need a pair of pliers and a 6" or longer flat blade screw driver. for the older sight impaired folks, like myself, i would suggest a strong light and a magnifying glass.
    i used a the following motherboards, but this will work with any 2 different motherboards.
    early version p-1
    a p-3 slot
    a purple chinese 478
    a lpga socket t commonly called a socket 775
    remove the plastic retaining guides from the memory, pci, cpu sockets. ( pliers and screw driver) some of the guides will have crystallized due to age and heat. no problem. we are only trying to expose a few pins from each socket. no need to remove the all of the plastic.
    i normally lay the pliers flat and use it as a fulcrum to pry off the guide with the screw driver. some folks like to use the pliers and simply pull of the guide. the guides are not glued or sonic welded. they just seem like it.
    DO NOT RUN THE SCREW DRIVER THRU YOUR HAND!!
    this requires a combination of finesse and force.
    a simple observation of the pins will reveal several things.
    the coverage area of the pins and the color of the gold plating.
    the newer the board the less coverage found on the pins.
    the lighter color is indicative of a thinner plating that does not reflect light at the same wave length as the heavier plating. it is still pure gold. there is just less of it.
    if you look at the pins on the chinese boards, you will note that the pins are only covered at the arc of the pin. that is the expanded part, rounded part, of the pin that makes contact. a close examination shows that the arc is not fully covered on the back or opposing sides of the pin. the color reflection seems to show that the gold has been flashed rather than plated.
    while these are not regulated terms requiring a set minimum thickness, such as a karat hall mark, it does mean that there is far less plated material present. it is especially true considering these boards were manufactured in the asian market.
    86 and p-1 boards have larger pins with more full coverage pins. the slot board has smaller, thinner pins with fewer full coverage pins. the 775 and chinese board have almost no coverage on any part of the pin besides the mating point of the pin.
    if you look at the progression of less plating and thinner plating on each generation of motherboard, you can see how the newer boards have less value than the older generations of boards.
    while there are some variations, particularly with slot and 775 boards, it is clear that there is less gold per board in and on today's motherboards than the older generation of boards.
    as an example
    take a stack of business cards and stack them up 1" high. we will give that a value of 1/10 gram of full coverage pins.
    when we use pins that are only half plated we must now stack those cards 2" high to get that same 1/10 gram value.
    no that is not absolutely mathematically correct but it does show how easily a board can lose value. and how value can be lost.
    the lack of plating quality in the newer boards does seem to offer an explanation for the high motherboard failure rate of the past few years. dell & compaq replaced a lot of 478 motherboards. wonder why.
  2. The Following 8 Users say Thank You for This Post by rbrooks715:
    261
    127
    now for the debate. it should be obvious that a board that contains less gold is going to recover less gold. meaning the boards is worth less.
    as the ratio of lower grade boards on the market continues to increase, i predict the prices of those boards will fall. resulting in a multiple grading and pricing system.
    2 years ago it was common to find gaylords of old 86, p-1 and p-2 motherboards. those volumes have been steadily dropping. they have been replaced with slot, p-4 and 775 boards.
    it is inevitable that pricing will change. the only real question is when it will become a standard pricing.
  4. The Following 3 Users say Thank You for This Post by rbrooks715:
    I have mostly just been stashing any ewaste I come across, and not that I have a lot, but enough to get things started. I am definitely starting to get curious with all the spirited discussions and happy gold dance business going on that I think I'd better take a peek.
    3,400
    1,004
    Sounds like a trip to your house is in order
    ComputerScrapper's Avatar
    Portland, Indiana
    497
    18
    Quote Originally Posted by rbrooks715 View Post
    early version p-1
    a p-3 slot
    as an example
    I have maintained that I can usually get in a load of 10 486 series towers and at least 7 of them will still work...Get 10 Pentium 4 towers in and I am lucky if 2 or 3 of them still work.
    Currently Buying E-Scrap
    Visit http://www.wastenotecycling.com for more details.
    "A good jockey sits straight up on the horse....Otherwise your boobs flop around and get caught in your back fat." Betty White
  8. The Following User Says Thank You to ComputerScrapper for This Post:
    Portland, Indiana
    497
    18
    I have also predicted that prices will start to change for the lower grade boards....As I mentioned in the other thread, it is not hard to see that things will eventually have to change. With lower recovery numbers there is going to be a trickle down effect as the number of 86, P-1 and so on boards continues to decrease.
  10. The Following User Says Thank You to ComputerScrapper for This Post:
    261
    127
    Quote Originally Posted by ComputerScrapper View Post
    that is really a good rate for p-4's. we get a lot of 775's and i doubt if we get 1 in 20 that have a working motherboard. the cpu's are all good, but the board is fried. i can't remember the last 478's we had that were any good.
    to be honest, i had never checked into any of these boards. i have been going off settlement returns. now that i have dismantled a few of these boards, it is rather obvious what the problems are.
    i would agree that most of the 86 computers will still work. i found a quite a few of the old p-1 and pentium pros still work as well. i just don't get many any more.
  12. The Following 2 Users say Thank You for This Post by rbrooks715:
    Scrap Master J's Avatar
    Alaska
    227
    82
    Thanks for the info. I find it interesting to look at a 10 or 20 year gold chart and see where the gold price was when the different CPUs/boards were in production. Lower price = heavier plate.
    2,864
    350
    Srap Master is wright, if you look at any board from the 50's and 60's that have gold pins, the pins are 2-3 time laarger than boards made within last few years. The same thing with low grade boards that were made in the 50's and 60's has about 5 or 6 time the amount of solder on them plus it was silver solder.
