Results 1 to 20 of 40
Results From Scrapping A Monitor
    Jeremiah started this thread.
    Jeremiah's Avatar
    Virginia
    437
    147
    Although there is still a margin of error, these are the results from scrapping a 17 inch monitor.
    .36lbs of Al (@.50lb = $.18)
    .66lbs of Flyback Transistor (@.25lb = $.17)
    .20lbs of Transformers (@.25lb = $.18)
    1.37lbs of Low Grade Circuit Board (@.12lb = $.16)
    .72lbs of Copper From The Monitor Yoke (@ 2.75lb = $1.98)
    .85lbs of Internal Insulated Copper Wire (.41 if you strip the electrical tape copper wire) (@.90lb = $.77)
    2.15lbs of internal shred-price metal (@.10lb = $.22)
    .35lbs of external insulated copper cord (@.90lb = $.32)
    .05lbs of Monitor End (@1.75lb = $.09)
    If you strip the electrical tape copper wire
    .16lbs (@.2.95lb = $.47)
    Results
    Without stripping electrical tape copper wire $4.07
    With stripping electrical tape copper wire $4.15
    I will post pics if you want
  2. The Following 3 Users say Thank You for This Post by Jeremiah:
    Jeremiah's Avatar
    Virginia
    437
    147
    If my math is correct you could get about 87% of the results by leaving the circuit board in tact and not stripping the wire
  4. The Following User Says Thank You to Jeremiah for This Post:
    AuburnEwaste's Avatar
    Metro Detroit
    773
    31
    I am to the point where I open the case, pull the copper yokes and the degaussing wire and call it a day. The space required to store low grade boards is not worth 10 cents per pound. I do pull the boards if they are mid grade but they are not very common. Of course I cut the VGA cable off and the end goes in the gold connector bin.
    One thing I have learned is that stripping the degaussing wire is a huge waste of time. The difference in price is 10 or 20 cents per pound so I sell it as is.
    I must respectfully disagree about stripping the degaussing cable. If it is copper I always strip it because after you do a few it is real fast and easy and that difference in price adds up fast. Don't forget the little grey copper wire attached to springs.
    Thanks for taking the time to itemize everything like that J
  7. The Following User Says Thank You to Dumpster-Dee for This Post:
    GeorgeB's Avatar
    Manassas Park, VA
    2,919
    462
    Just always remember to ensure it is copper, and not aluminum, even though aluminum will add up, need to be sure what pile to put it into!
    I use a 55 gal. barrel and cram it full even if I have to break them to slide down the sides. I should be able to get close to 100 lb's in each one.
  10. The Following 4 Users say Thank You for This Post by Mechanic688:
    TheHoss's Avatar
    The tater state
    863
    1,111
    Nice breakdown, very accurate.
    I strip the degaussing cable. Only the thick stuff, over the thickness of a pencil (not the lead tip, the pencil itsself)
    For my lowgrade, it doesnt matter the shape its in. I crush the board after depopulating it. The little bits are then stored in a series of gaylords. Crushed/shredded, they take up a LOT less space.
    I tried running degauss through my wire stripper. It does "okay" until it gets to the part where 2 smaller wires are wrapped with 14 miles of tape. Then it jams up.
    New plan, whatever that may be.
    I did use this to get through the extra tape. Works okay but I don't have a very good grip on it and I will slice myself up one of these days.
    TheHoss's Avatar
    The tater state
    863
    1,111
    Idaho, the part with the 839283 miles of tape. Cut the section out, you can kinda tell where it stops. Just cut that out and turn it in to the yard like that. Then run the rest with yer stripper.
    I stripped about 150 of those degaussing cables, using the method i just said. Got about $45 just in the insulated.
  14. The Following 2 Users say Thank You for This Post by TheHoss:
    TheHoss's Avatar
    The tater state
    863
    1,111
    That section should be about 4-5 inches long, by the way. Just too make sure you have it all.
  16. The Following User Says Thank You to TheHoss for This Post:
    You might fabricate a nice hardwood handle for that thing,
    Minnesota
    22
    Here in Minnesota we have to dispose of the CRT monitor properly and have to pay 25 cents a pound. So if a average weight of a 19 CRT is 20 pounds... That means I have to pay $5.00 for $4.15 worth of scrap. ( I also charge 20.00 per monitor to drop off.) that sounds like a lot bot when you factor in all the "hidden costs", I may make a $1 to $1.50.
    Jeremiah's Avatar
    Virginia
    437
    147
    Quote Originally Posted by Dumpster-Dee View Post
    I also strip the degaussing cable. As you said, its easy and I love to see the bright copper . I would just make sure you're not neglecting other more important things to strip it.
    Electrical tape is somewhat dense since it is made out of some type of plastic/finberglass. Note the two weights below
    http://www.flickr.com/photos/44373382@N05/6844479391
    http://www.flickr.com/photos/4437338...n/photostream/
    You loose about 63% of the weight by stripping. On 20 pounds of degaussing cable
    20pounds @ .90 = $18.00
    After Stripping
    7.4pounds @ $2.95= $21.83
    A difference of about $4.00
  20. The Following 3 Users say Thank You for This Post by Jeremiah:
  21. #14
    AND...all of this depends on how YOUR yard grades it. Different formula's for different folks !
  22. #15
    AND, it depends if you get ahold of a few that are alum. wire. Like these,
  23. The Following 2 Users say Thank You for This Post by Mechanic688:
  24. #16
    I wish you wouldn't bring that up !! I was turning all mine in as copper cause I did not know that some were Au......UNTIL YOU TOLD ME !!! Now, my conscience won't let me !! AND, after you EDUCATED me I started finding twice as much AU ones....you jinxed me also !!
  25. The Following 2 Users say Thank You for This Post by Dumpster-Dee:
  26. #17
    3,398
    993
    I will say bravo on this post you did a great job of breaking it down. I learned something from it. I learned that I was right in assuming there is about $5 per tv/crt in value.
  27. #18
    ElectricMetal's Avatar
    71
    84
    Many Thanks for this post.
    I love the intricate accounting of every detail. Very nice. The pre and post wire stripping photos are really nice as well.
    By the way, I looked through some of your flickr photostream shots and I really liked that blue motherboard from IBM -- very appropriate, a blue board from Big Blue.
  28. #19
    I thought you would have seen that in my original post called "breaking down a monitor" back in the summer (I didn't rate a sticky) You can tell if you pick one of them alum. ones up in one hand and a copper one in the other, weighs half as much. and can be about any color. Just clip a few strands to know for sure.
  29. #20
    2,907
    I stripped a early 90's Mitsubishi 29 inch CRT Tv a few days ago & got over 3 Lb's of copper just from the degaussing cable & the yoke.
    Thats 1.35Kg of Copper @ NZ$7.30Kg = NZ$9.85,
    or US$7.88 from one TV. (plus all the other little bits)
    Its weird how the earlyer TVs has Ali degausing cables & the 80's CRT's had big fat Copper cables, anyone know why?
    I woulda thought it'd be the other way around, since copper was cheaper way back them.
  30. Similar threads on the Scrap Metal Forum
    1. T.V. and Monitor Scrapping Guide
      By Gravitar in forum TV and Monitor Recycling
      Last Post: 11-25-2012, 09:27 AM
    2. Delivery results
      By Scrapcrazy in forum General Electronics Recycling
      Last Post: 08-26-2012, 08:15 PM
    3. Cisco Switches. My results
      By wdaddy in forum General Electronics Recycling
      Last Post: 03-29-2012, 06:28 AM
    4. And the Results are in!
      By Julie in forum General Electronics Recycling
      Last Post: 03-05-2012, 09:06 PM
    5. VCR Results
      By BRASSCATCHER in forum A Day in the Life of a Scrapper
      Last Post: 02-27-2012, 07:00 PM
