Results 1 to 12 of 12
component identification
    devo started this thread.
    Eastern Ontario
    294
    139
    I know some of you are into breaking down low value boards, and some of you want to, but aren't sure whats what. I thought with the recent break out of skippyism around here I would throw up a post that might be useful to one or two.
    I'm not going to hand hold here, some of the stuff is pretty basic. If it looks like a big ball of copper, it is, take it. I'm hoping to help you identify some of the harder hidden stuff. Before I was a carpenter, I went to school and worked as an electrical engineer, just a little background for you.
    A lot of the time there will be some sort of designation printed right on the board, this goes back to the days when boards were hand assembled. Here are some common abbreviations found:
    BT = Battery
    C = Capacitor
    CB = Circuit Breaker
    CR = Diode
    D = Diode
    F = Fuse
    FL = Filter (also a coil - copper)
    IC = Integrated circuit
    K = Relay (copper coil inside)
    L = Inductor (copper)
    Q = Transistor, Semiconductor
    QA = Transistor array (on older stuff this can look like an IC)
    R = Resistor, Potentiometer
    RA = Resistor array
    S = Switch
    T = Transformer
    TB = Terminal Block
    U = Integrated Circuit
    VR = Zener Diode
    X = Socket
    Y = Crystal Unit
    If there is no indication on the board, sometimes you can determine what the component is from the symbols on the side:
    OHM : either written as "ohm" or more likely a symbol that looks like an upside down horse shoe. This is a resistor.
    Farad: symbol (F) almost always preceded by a funny looking "u" (micro). This is a capacitor.
    Henry: (yes really), Symbol (h), this is a coil.
    This is far from a definitive list, nor is it always exact. If there is interest I'll add more with pics of the symbols. Anyway maybe someone can benefit a bit from this.
    Interest is shown.
    Just to add to what you have started this is a very good explanation of the different parts.
    26
    Devo,
    Very helpful. I was just looking at an odd-ball board last night.... it had the printed letters and while most were fairly obvious, a few had me stumped. You're list has given me immediate results. Thanks!
    2,416
    667
    The colored lines on the resistors indicate the resistance value in ohms. There were 2 sayings to help remember the order if I can remember them
    Bad Beer Rots Our Young Guts But Vodka Goes Well
    or
    Bad Boys Rape Our Young Girls But Violet Gives Willingly
  6. The Following User Says Thank You to parrothead for This Post:
    I really hope they make a sticky out of this thread so I don't have to keep posting this.
    Answers——————
    1 Diodes
    2 Piezo Buzzer
    3 Transistor
    4 Transformer
    5 Relay
    6 Inductors
    7 Integrated Circuits (IC’s)
    8 Capacitors
    9 Crystal
    10 Resistors
    Here's a resistor calculator for anyone who needs to use one.
    http://www.dannyg.com/examples/res2/resistor.htm
  9. The Following 5 Users say Thank You for This Post by Mechanic688:
    [QUOTE=Mechanic688;62213]I really hope they make a sticky out of this thread so I don't have to keep posting this.
    No sooner said than done.
  11. The Following 3 Users say Thank You for This Post by Mick:
    Thank you Mick, I owe you a cold one,,,
    Identification Pictures for Surface Mount Devices (SMD) : Capacitors
    Resistors: In these pic's their using a 1/4 watt resistor for scale. (The one without a number).
    IC's
    1. 20 Pin DIP (Reference) 2. 20 Pin (WIDE) SO-IC 3. SO-IC 8 with heat sink tab 4. SOIC-8 5. 20 Pin SSOP
    1. SMT Power Transistor 2. SMD Led 3. Melf Diode 4. 4 Leg SOT 5 - SMB Diode 6. SOT-223
    1. 1008 Inductor (Wire Wound) 2. 1210 Ferrite Bead 3. Variable Ind 4. RF Transformer 5. Ferrite Bead
    Eastern Ontario
    294
    139
    Wow this turned out well in a hurry, nice change from the antics of the last couple days. I just checked what I had laying around that might be of interest and found quite a bit that I should take some pics of. I will this evening, time for a Sunday nap for now though.
    Ps Thanks Mechanic688 for helping with those pics, going to help a lot of people out I think.
  15. The Following 3 Users say Thank You for This Post by devo:
    Closed
  17. The Following 4 Users say Thank You for This Post by Mick:
    1. Component Identification
      By Jeremiah in forum E-Waste Grading and Identification
      Last Post: 01-01-2013, 01:10 AM
    2. Wire identification
      By BRASSCATCHER in forum Scrap Metal Tips and Advice
      Last Post: 05-31-2012, 11:59 PM
    3. Question: Low Grade Board Component Shearing/Shredding?
      By Primo in forum Low-Grade Electronics Recycling
      Last Post: 02-04-2012, 05:46 PM
    4. Aluminum identification
      By Hypoman in forum Scrap Metal Identification
      Last Post: 12-24-2010, 01:36 PM
