Results 1 to 9 of 9
How to remove the small heat sink off the cpu
| Batteries, Capacitors, Heat Sinks
  1. #1
    conrad4784 is offline Metal Recycling Entrepreneur
    conrad4784 started this thread.
    SMF Badges of Honor
    Member since
    Oct 2011
    Posts
    48
    Thanks
    21
    I found a quick way to remove the small heatsink from cpu's. Taking them apart and selling them seperate you will make more money just a matter of how quick you are and what your time is worth. Every once in awhile you will get a heatsink with gold underneath the cap.(added bonus, usually from some P4 and celeron D) I will attach some pictures one was previously posted by jghilino showing the gold cap. Basically you will need a descent sized magnet to hold the cpu in place so that you can hit the heat sink downward to remove it.
    https://www.dropbox.com/s/ruv7854tfcxjwlv/chizel.jpg
    https://www.dropbox.com/s/ryiqg6jcl8...sink%20off.jpg
    Below is a price comparison using Ewasted prices for cpus hopefully he wont mind.
    http://www.scrapmetalforum.com/scrap...tal-scrap.html
    $6.40lb Green Fiber with Heatsink - Pins
    11.4oz*6.40= $4.56
    $16.00lb Green/Brown Fiber without Heatsink
    4.4oz*16= $4.40
    #2 Copper(tinned 14awg or larger/paint $2.25/lb
    Im not an expert on what grade this would be considered they are solid cooper that is tinned I believe.(if Im wrond please advise)
    7oz* 2.25/lb= .98
    4.40+.98= $5.38 seperated
    VS
    $4.56 whole
    Thats .82 cents more from 14 cpus approx 6 cents more per cpu not alot more profit for the work but it is pretty easy and can be done quickly. If my values for copper or fiber cpus are low than it could be worth it.
    Attached Images Attached Images
  2. The Following 2 Users say Thank You for This Post by conrad4784:
  3. #2
    Mechanic688's Avatar
    SMF Badges of Honor
    Member since
    Mar 2011
    Location
    Warsaw , Ind. In the heart of the lakes, and down the street from the hotel where Al Capone stayed.
    Posts
    9,571
    Thanks
    11,207
    It's usually just dried up heat sink grease that's holding them fast to the heat sink, so I use a flat blade and start sliding between the chip and sink, tap it if you need to.
    P & M Recycling - Specializing in E-Waste Recycling.
    If you enjoy your freedom, thank a vet.
  4. The Following 2 Users say Thank You for This Post by Mechanic688:
  5. #3
    SMF Badges of Honor
    Member since
    Oct 2011
    Posts
    48
    Thanks
    21
    Quote Originally Posted by Mechanic688 View Post
    I have done that in the past this is just a quicker method for me and it makes it easier to remove the caps that have been expoxied on along with grease in the middle. Just curious what do you sell the caps as? #2 copper? thanks
  6. #4
    Bear is offline Metal Recycling Entrepreneur
    SMF Badges of Honor
    Member since
    Feb 2012
    Location
    OK
    Posts
    5,731
    Thanks
    6,810
    I lay them flat on the slab against a door stop and pop em off with a hammer and wood chisel
  7. #5
    dsvtechie's Avatar
    SMF Badges of Honor
    Member since
    May 2012
    Location
    Ozark, Missouri
    Posts
    9
    Thanks
    15
    Just curious.... What about Pentium 4 pinless procs with the heatsink soldered to the cpu? What happens to the sort and the price then? Thanks.
  8. The Following User Says Thank You to dsvtechie for This Post:
  9. #6
    BRASSCATCHER's Avatar
    SMF Badges of Honor
    Member since
    Feb 2012
    Posts
    2,476
    Thanks
    3,419
    Quote Originally Posted by dsvtechie View Post
    Good question, never had that one answered by ANY buyer. But from what I know the pinless P4 is not worth refining unless they are mixed in with other material. I would think that removing the sink should bump up price but only a buyer would have that answer
    I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them.” John Wayne-- The Shootist
    NEWBS READ THIS THREAD ABOUT REFINING!!!!
    http://www.scrapmetalforum.com/off-t...ning-read.html
  10. The Following 2 Users say Thank You for This Post by BRASSCATCHER:
  11. #7
    SMF Badges of Honor
    Member since
    Jul 2013
    Location
    Ohio
    Posts
    162
    Thanks
    54
    I was able to put them in with green fiber a few months ago for one seller. You can always ask. I was using the heat gun to melt the solder before lifting the cap off. It wasn't worth my time.
  12. The Following User Says Thank You to foobar for This Post:
  13. #8
    dsvtechie's Avatar
    SMF Badges of Honor
    Member since
    May 2012
    Location
    Ozark, Missouri
    Posts
    9
    Thanks
    15
    Thanks for the quick reply, I'll try asking a person I know locally that your response made me think of and I'll reply back but it'll be a couple of weeks before I run to town again. I'm more limited to mail in recycling since I'm usually down in between chemo treatments (that's mostly when I go to town), but that's more for off topic thread. I'll ask next time I'm in town and get back. Thanks again!!!
  14. #9
    dsvtechie's Avatar
    SMF Badges of Honor
    Member since
    May 2012
    Location
    Ozark, Missouri
    Posts
    9
    Thanks
    15
    Thanks I'll probably do it if I can get someone to buy it separately, just for something to tinker with, thanks again!!
  15. Similar threads on the Scrap Metal Forum
    1. Tool to remove copper plug from heat sink?
      By Ironhunter in forum Scrap Metal Tips and Advice
      Last Post: 01-29-2014, 05:50 PM
    2. This thead is a question - Processor Heat Sink
      By GWOTTO in forum Scrap Metal Identification
      Last Post: 03-22-2013, 06:35 PM
    3. CPU Heat Sink
      By Racer997 in forum Batteries, Capacitors, Heat Sinks
      Last Post: 01-07-2013, 06:46 AM
    4. funkiest heat sink i've ever seen
      By Ecycle Atlanta in forum Scrap Metal Questions and Answers
      Last Post: 09-16-2012, 12:08 PM
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Browse the Most Recent Threads
On SMF In THIS CATEGORY.
OR
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
The Scrap Metal Forum
    The Scrap Metal Forum is the #1 scrap metal recycling community in the world. Here we talk about the scrap metal business, making money, where we connect with other scrappers, scrap yards and more.
SMF on Facebook and Twitter
Twitter Facebook
