Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 241 to 260 of 266
A Scrapper's Dream - Page 13
| A Day in the Life of a Scrapper
  1. #241
    Patriot76 started this thread.
    Patriot76's Avatar
    SMF Badges of Honor
    Member since
    Dec 2012
    Location
    Buffalo Commons
    Posts
    2,955
    Thanks
    10,578
    This series of pictures are of two sets of coils. 12 ft. in diameter and eight feet deep, the air cooling fins had to be cut out in 2 ft. x 2 ft. sections working down. The last layer of coils provided exposure of eleven stories to the basement. The center hub is estimated to weigh about 2 1/2 tons and was dropped in one piece. It was a work of art watching the crew dismantle two of these.
  2. The Following 7 Users say Thank You for This Post by Patriot76:
  3. #242
    Patriot76's Avatar
    SMF Badges of Honor
    Member since
    Dec 2012
    Location
    Buffalo Commons
    Posts
    2,955
    Thanks
    10,578
    The challenge is slowly coming to an end. We are six months ahead of schedule and should be done at the end of September. A series of pictures will document the rest of the project. When completed I will be returning to the ranch to continue cleaning up farms. This is a series of pictures from an elevated point of our scrap yard. Notice the scrap truck, a little Patriotic.
  4. The Following 8 Users say Thank You for This Post by Patriot76:
  5. #243
    DakotaRog is offline Metal Recycling Entrepreneur
    DakotaRog's Avatar
    SMF Badges of Honor
    Member since
    Aug 2014
    Posts
    1,611
    Thanks
    602
    WoW Patriot, you make SD proud!!
    Too bad you weren't around back in the early 1960s when they scrapped the USS South Dakota out east. Maybe we would have gotten more of the ship out here!!
  6. The Following User Says Thank You to DakotaRog for This Post:
  7. #244
    sawmilleng is offline Metal Recycling Entrepreneur
    sawmilleng's Avatar
    SMF Badges of Honor
    Member since
    Feb 2013
    Location
    Central Kootenays, BC, Canada
    Posts
    859
    Thanks
    712
    Hi, Patriot,
    I got a chuckle out of the garbage truck as well...your comment about patriotic caused me to look closely at the first photo...I figured that seeing "Abe" on the door of that truck brought a vision of Old Abe driving it. I saw the paint on the scrap trailer a minute later in the next photo.
    6 months ahead of schedule!! That's incredible. So I guess you'll be home before snow flies?
    Without mentioning actual dollar numbers, would you be willing to divulge the following percentages?
    1. Scrap revenues divided by cost of removal, as a %. So a 50% number would mean that you made about 1/2 of the removal costs.
    2. Of the scrap removed, what are the % of the different sorts you are being paid for? In other words, how much copper, brass, aluminum, steel, exotic alloys, items sold as goods rather than for scrap metal? Of course, the above sorts may not be how you actually did it.
    Item 2 would be interesting in both % by weight, but also by % of the dollars received for a particular sort. So if you did only copper/steel you might have 10%Cu/90%Fe by weight and maybe 20%Cu/80%Fe by dollars. I'm sure the prices you are getting for metals, due to the volumes, are in the clouds compared to what us schmucks on the curbs can achieve!!
    Not sure how secretive your boss wants the job to be, but the % would be interesting to say the least.
    Did you pick up any interesting souvenir(s) from the job you'd care to share with us?
    Best of luck to you and I hope the conclusion of the job is done safely!!
    Jon.
  8. The Following 2 Users say Thank You for This Post by sawmilleng:
  9. #245
    Patriot76's Avatar
    SMF Badges of Honor
    Member since
    Dec 2012
    Location
    Buffalo Commons
    Posts
    2,955
    Thanks
    10,578
    Saw, since you were the previous poster, I will not respond with your quote. For now I can tell you we are shooting for a salvage operation that cost less than the metal recovered. Not quite there, but close. Given the quotes to scrap this plant we have saved the owner a lot of money. Although it is the intent to help everyone on the forum, I am no at liberty to share other details. Let it be said, this was a free education for this neophyte.
  10. The Following 3 Users say Thank You for This Post by Patriot76:
  11. #246
    sawmilleng's Avatar
    SMF Badges of Honor
    Member since
    Feb 2013
    Location
    Posts
    859
    Thanks
    712
    Patriot, I understand.
    I realize I was asking for info akin to the length of ones dong!
    Its cool, though, that you are able to shoot for breakeven. I had the opportunity to demolish a large sawmill and later, a large planermill, and those were my same goals. We were able to pay for most of the environmental cleanup, too.
    Jon
  12. The Following User Says Thank You to sawmilleng for This Post:
  13. #247
    Patriot76's Avatar
    SMF Badges of Honor
    Member since
    Dec 2012
    Location
    Buffalo Commons
    Posts
    2,955
    Thanks
    10,578
    Wanted to tie up loose ends on this thread. These are some pictures after removing the exhaust system seen on post # 235. This is on the 10th floor of the boiler room.
  14. #248
    Patriot76's Avatar
    SMF Badges of Honor
    Member since
    Dec 2012
    Location
    Buffalo Commons
    Posts
    2,955
    Thanks
    10,578
    It has been pointed out how everything had to be moved by hand. These pictures show one person moving a 500 - 1,000 lb. piece of pipe and dropping it into a chute to fall 10 stories to the basement. The walls on the pipe are 2 in. thick.
  15. The Following User Says Thank You to Patriot76 for This Post:
  16. #249
    Patriot76's Avatar
    SMF Badges of Honor
    Member since
    Dec 2012
    Location
    Buffalo Commons
    Posts
    2,955
    Thanks
    10,578
    Another picture of moving metal by hand. Notice the solid steel hub in the center of the piece. A square foot of 1/4 in. steel weights 10 lb. The piece is 2 1/2 ft. tall and 3ft in diameter. Guessing it well over a ton, but calculating the exact weight would make my head hurt.
    You will also notice they are on grating that extends all the way down 10 stories. Looking down 10 stories is not a good feeling when you hate heights.
  17. #250
    Patriot76's Avatar
    SMF Badges of Honor
    Member since
    Dec 2012
    Location
    Buffalo Commons
    Posts
    2,955
    Thanks
    10,578
    We had to move a huge generator into and out of the building every day. This was my creation to allow us to do it quickly without devoting the skid steer to this job alone. The receiver was removed during the day to move metal and hooked up to move the generator in the evening and morning.
  18. The Following User Says Thank You to Patriot76 for This Post:
  19. #251
    Patriot76's Avatar
    SMF Badges of Honor
    Member since
    Dec 2012
    Location
    Buffalo Commons
    Posts
    2,955
    Thanks
    10,578
    These pictures show the last metal coming down. It is the bottom of one of the boilers.
    These are the end result.
  20. #252
    Patriot76's Avatar
    SMF Badges of Honor
    Member since
    Dec 2012
    Location
    Buffalo Commons
    Posts
    2,955
    Thanks
    10,578
    A view of the bottom of the boilers in the basement where all the metal was thrown. From here skid steers were used to move the metal to the hole where the excavator loaded it into the trucks.
  21. #253
    Patriot76's Avatar
    SMF Badges of Honor
    Member since
    Dec 2012
    Location
    Buffalo Commons
    Posts
    2,955
    Thanks
    10,578
    This is the second exit point in the turbine hall. The giant turbines pictured earlier sat up above and to the right.
  22. The Following 5 Users say Thank You for This Post by Patriot76:
  23. #254
    SMF Badges of Honor
    Member since
    Nov 2012
    Location
    Aussie
    Posts
    3
    Thanks
    0
    I'm really enjoying this thread, thank you Patriot76
  24. The Following User Says Thank You to Lukey for This Post:
  25. #255
    Patriot76's Avatar
    SMF Badges of Honor
    Member since
    Dec 2012
    Location
    Buffalo Commons
    Posts
    2,955
    Thanks
    10,578
    Found a few more pictures to share. To much time stuck at the cabin and ready to get back to the real world at the ranch and scraping to the heart's desire. The first picture is the bottom of the boilers prior to removal. The next picture is of the hangers that held the boilers up and supported by the roof.
  26. #256
    Patriot76's Avatar
    SMF Badges of Honor
    Member since
    Dec 2012
    Location
    Buffalo Commons
    Posts
    2,955
    Thanks
    10,578
    Exposure was an understatement on this project. Here is one perspective. This is the inside of the old freight elevator. We cut the cables and then hooked them up to an electric chain hoist. I built a cart to fit inside the elevator frame, attached the cables to it, and this was used to move propane, oxygen, and materials up eight floors.
    Communication (challenge) and safety was paramount and constantly discussed. The miracle was only a couple of twisted ankles and one minor burn. Someone was watching over us.
  27. The Following 3 Users say Thank You for This Post by Patriot76:
  28. #257
    ruben23's Avatar
    SMF Badges of Honor
    Member since
    Jan 2012
    Location
    RI
    Posts
    40
    Thanks
    5
    This has to be one of the most interesting threads ive found on smf. It would have been pretty amazing to be in that building while it was still operational as a power plant. Any idea how many people it employed?
  29. The Following User Says Thank You to ruben23 for This Post:
  30. #258
    Patriot76's Avatar
    SMF Badges of Honor
    Member since
    Dec 2012
    Location
    Buffalo Commons
    Posts
    2,955
    Thanks
    10,578
    A couple hundred was the number given to me just prior to shutting it down. This included some of the engineers for the Ft. Calhoun Power Plant that replaced it. Ft. Calhoun has over 800 employees on site as of today.
  31. #259
    ruben23's Avatar
    SMF Badges of Honor
    Member since
    Jan 2012
    Location
    RI
    Posts
    40
    Thanks
    5
    wow! hope you kept a few cool momentos out of the deal!!!
  32. #260
    NobleMetalWorks's Avatar
    SMF Badges of Honor
    Member since
    Sep 2012
    Location
    East Bay California
    Posts
    687
    Thanks
    301
    Just like being a Parent, it's not how good you are, it's how good you want to be. If that is the case, as it sounds like it is, you will do very well indeed and accumulate experience on a scale that you otherwise would not. I haven't read through the entire thread, but it seems to me that you are not only on the right path, but excelling at doing so.
    Congrats, love seeing old buildings saved instead of being destroyed. What an amazing project to be involved in!
    Scott
    At the heart of science is an essential balance between two seemingly contradictory attitudes--an openness to new ideas, no matter how bizarre or counterintuitive they may be, and the most ruthless skeptical scrutiny of all ideas, old and new. This is how deep truths are winnowed from deep nonsense. -- Carl Sagan
  33. The Following 2 Users say Thank You for This Post by NobleMetalWorks:
  34. Similar threads on the Scrap Metal Forum
    1. scrapper's dictionary
      By MattInTheHat in forum Off Topic Discussions
      Last Post: 12-23-2014, 07:35 PM
    2. This thead is a question - Your Dream Find While Scrapping?
      By DJWhiteGuy in forum A Day in the Life of a Scrapper
      Last Post: 03-23-2014, 12:40 PM
    3. Dream Machine Wiring Stripping Like The Pro's
      By theelectronrecycler in forum Scrap Metal Videos
      Last Post: 10-01-2012, 09:41 AM
Thread Information
Users Browsing this Thread
There are currently 3 users browsing this thread. (0 members and 3 guests)
Browse the Most Recent Threads
On SMF In THIS CATEGORY.
OR
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
The Scrap Metal Forum
    The Scrap Metal Forum is the #1 scrap metal recycling community in the world. Here we talk about the scrap metal business, making money, where we connect with other scrappers, scrap yards and more.
SMF on Facebook and Twitter
Twitter Facebook
