SMF Buyer Finder - Click an item below to find a Scrap Metal Forum buyer that buys what you're selling.
Page 14 of 22 FirstFirst ... 41213141516 ... LastLast
Results 261 to 280 of 426
Tantalum capacitor scrap - Page 14
| Scrap Buyers & Sellers
  1. #1
    TantalumRecycling started this thread.
    TantalumRecycling's Avatar
    Last Online: 07-31-2024
    SMF Badges of Honor
    Member since
    Dec 2013
    Location
    Doral, Florida USA
    Posts
    207
    Thanks
    96
    We purchase all types of Tantalum Capacitors Scrap
    Current Pricing is:
    Epoxy/Ceramic Capacitors - $11/Lb
    SMD/Molded Capacitors -- $11/Lb
    Axial/Hermetic A Size Capacitor - $7/Lb
    Axial/Hermetic B Size Capacitor - $8.00/Lb
    Axial/Hermetic Capacitors C&D - $10/Lb
    Tantalum RED Capacitors - $30/Lb
    Wet Tantalum Capacitors - $42.50/Lb
    Ag/Ta Capacitors - $55/Lb
    RED Top Ag/Ta Capacitors - $20/Lb
    Tantapak/Wets Capacitors - $6/Lb
    Tantalum Foil -- $6/Lb
    Tantalum Bullets -- $6.50/Lb
    We purchase all quantities small and large
    Tantalum Recycling
    2101 NW 93rd Avenue
    Doral, Florida 33172 USA
    T: 1.800.805.9150
    E: info@tantalumrecycling.com
    W: Tantalum Scrap Metal Recycling | Tantalum Recycling
    More Information & Photos about our Company: https://www.facebook.com/tantalumscrap/
    Attached Images Attached Images
  2. #261
    ScrappinRed's Avatar
    SMF Badges of Honor
    Member since
    Jan 2012
    Location
    texas
    Posts
    709
    Thanks
    316
    Are the yellow caps in these photos tantalum? They are a different shape than I usually see the drop style and some have 3 legs instead of 2. There are 3 different types in these photos that have me scratching my head. Lots of photos but couldn't get focused well enough on some. Different angles of the same board...
  3. The Following User Says Thank You to ScrappinRed for This Post:
  4. #262
    bigburtchino's Avatar
    SMF Badges of Honor
    Member since
    Mar 2011
    Location
    California
    Posts
    1,643
    Thanks
    4,369
    Red - TantalumRecycling will need to tell you yea or nae on what is or isn't a tantalum capacitor. I do believe the three lead yellow epoxy resin dipped capacitors are indeed tantalum capacitors. They look to me to be Vishay-Sprague Solid Tantalum Capacitors, specifically 299D - Solid-Electrolyte TANTALEX®:Tripole®, triple lead. Resin-coated - conformal coating, miniature size, combined with high performance features. The anode lead is in the center while both outside leads are cathode leads. The three-lead design makes backwards insertion impossible (polarized, but you would have to work at making a bad connection), this is a time saving option, enabling assembly without having to visually determine polarity. This also helps prevent damage to circuit board and components that may result from incorrect installation.
    KEMET also makes a three lead epoxy dipped tantalum capacitor T396, Here is a picture of the T396 KEMET Tantalum capacitor.
    Vishay-Sprague marks there capacitors with a number 2 inside a circle and KEMET marks their capacitors with a K with a line above and below the K. The capacitor in the picture is a 100uF capacitor,max operating voltage of 10 volts and the second "K" is a tolerance indicator of ±10%.
    Hard to see the other ones, how are they marked?
  5. The Following 4 Users say Thank You for This Post by bigburtchino:
  6. #263
    SMF Badges of Honor
    Member since
    Jan 2012
    Location
    texas
    Posts
    709
    Thanks
    316
    Thanks so much for all the info Burt!
    There are two sizes of the larger ones with 3 leads. Super hard to read all these little guys!
    Looks like the two larger:
    476 6k
    475 10k
    smaller 2 leads types:
    k5u 105m
    k5k 104
    k1k 103
  7. #264
    SMF Badges of Honor
    Member since
    Mar 2011
    Location
    California
    Posts
    1,643
    Thanks
    4,369
    Red - Hard to say with 100% accuracy, but with just your markings I would say all are made by KEMET. The 476 6K and 475 10K are KEMET T396 Tantalum capacitors.
    Based on the marking info. only the K8U 105M, K5K 104, and K1K 103 are also made by KEMET, but are not Tantalum capacitors. They are ceramic radial capacitors similar to this one.
  8. The Following User Says Thank You to bigburtchino for This Post:
  9. #265
    SMF Badges of Honor
    Member since
    Jan 2012
    Location
    texas
    Posts
    709
    Thanks
    316
    That makes sense, because the small ones didn't seem to be the right shape. The larger ones looked similar to other tantalum epoxy I had but that third lead and odd shape threw me. Thanks Burt
  10. #266
    SMF Badges of Honor
    Member since
    Dec 2013
    Location
    Doral, Florida USA
    Posts
    207
    Thanks
    96
    Quote Originally Posted by bigburtchino View Post
    This indeed are Tantalum Capacitors --- Again a very small amount of these are produced annually. But, we will take this type of capacitor. If you would like please send us a sample of two of these capacitors and we will have them tested at our facility.
  11. The Following 2 Users say Thank You for This Post by TantalumRecycling:
  12. #267
    SMF Badges of Honor
    Member since
    Dec 2013
    Location
    Doral, Florida USA
    Posts
    207
    Thanks
    96
    Big is absolutely right these are NOT Tantalum Capacitors.
  13. The Following 2 Users say Thank You for This Post by TantalumRecycling:
  14. #268
    SMF Badges of Honor
    Member since
    Dec 2013
    Location
    Doral, Florida USA
    Posts
    207
    Thanks
    96
    Quote Originally Posted by ScrappinRed View Post
    Yes the larger ones look like a thicker egg drop shape capacitor but indeed the inside of the capacitor is the same as regular Epoxy Capacitors.
  15. #269
    sledge's Avatar
    SMF Badges of Honor
    Member since
    Nov 2012
    Location
    Central Indiana
    Posts
    2,716
    Thanks
    4,531
    ScrappinRed: Not to hijack thread: But if you are gutting that board.. be sure to pull those socketed PROMS and/or possibly E-Proms (The ones with stickers may have a window underneath)
    Ok. Back to Tantalum Talk!
  16. The Following 4 Users say Thank You for This Post by sledge:
  17. #270
    SMF Badges of Honor
    Member since
    Mar 2011
    Location
    California
    Posts
    1,643
    Thanks
    4,369
    Red - I always use a magnet as one method of identifying tantalum capacitors. Almost all tantalum capacitors seem to have some magnetic properties, Tantalum is not a magnetic metal (does not generate a magnetic field), it is a paramagnetic metal, it will react to magnetic fields. Most tantalum capacitors (95%+) that I have encountered have a strong magnetic pull. I suspect most of the "magnetic pull" has to with the manufacturing process and the other materials used to make tantalum capacitors. Many TC's have a pure nickel wire welded to a tantalum wire on the anode portion of the capacitor. The cathode connection can also be a nickel, or kovar wire both of these type of leads and the glass‑to‑metal seal are highly magnetic. Quoting a NASA document that specifies the material requirements for building spacecrafts, "Non‑magnetic tantalum capacitors are difficult to find". So I use a scrappers best tool, a magnet to help quickly ID tantalum capacitors. They do make non-magnetic TC's, so I'm not saying all TC's are magnetic, just most of them are!
    Red - Can you check the three lead TC's with a magnet, confirming as I'm sure they will also be magnetic. Now for "$hits & giggles" check the ceramic capacitors on your circuit board, are they magnetic?
  18. The Following 6 Users say Thank You for This Post by bigburtchino:
  19. #271
    SMF Badges of Honor
    Member since
    Jul 2011
    Location
    Jacksonville, NC
    Posts
    4,918
    Thanks
    15,581
    bigburtchino, that was very helpful for me. I was going to waste my time and others, photoing some caps asking if the were good or not. Now I know for certain they are not. Mike
  20. The Following User Says Thank You to miked for This Post:
  21. #272
    SMF Badges of Honor
    Member since
    Dec 2013
    Location
    Doral, Florida USA
    Posts
    207
    Thanks
    96
    Absolutely 100% True.
  22. The Following 2 Users say Thank You for This Post by TantalumRecycling:
  23. #273
    SMF Badges of Honor
    Member since
    Dec 2015
    Posts
    4
    Thanks
    2
    Good day, using a scrapper sound the best way. I am mew to this i tried scrapping a pc board and alot of very tiny brownish capacitors stuck to magnet. Marking next to these are c then number also cb, L, yellow and black square one i know from above pictures but there is also a square black one positive marking but that has a d and number marking on board. If Anyone can help thank you. I have 1437 grams of the square black and yellow ones and 356 grams ( tear drop?) ones.
  24. The Following User Says Thank You to Smb for This Post:
  25. #274
    SMF Badges of Honor
    Member since
    Dec 2013
    Location
    Doral, Florida USA
    Posts
    207
    Thanks
    96
    Quote Originally Posted by Smb View Post
    Can you please provide us a picture of what type you are speaking about. This would be the easiest way to check if it is Tantalum or Not.
  26. #275
    kane333 is offline Metal Recycling Entrepreneur
    kane333's Avatar
    SMF Badges of Honor
    Member since
    Aug 2012
    Location
    Kearneysville, WV
    Posts
    120
    Thanks
    69
    Here's a Video showing how to help identify SMD (Surface Mount Device) and other Tantalum Capacitors. It's a bit lengthy video but informative. Hope this helps.
  27. The Following 6 Users say Thank You for This Post by kane333:
  28. #276
    SMF Badges of Honor
    Member since
    Dec 2013
    Location
    Doral, Florida USA
    Posts
    207
    Thanks
    96
    Quote Originally Posted by kane333 View Post
    This is a good video -- And is correct.
  29. The Following 2 Users say Thank You for This Post by TantalumRecycling:
  30. #277
    jiffy117 is offline Metal Recycling Entrepreneur
    jiffy117's Avatar
    SMF Badges of Honor
    Member since
    Feb 2014
    Location
    Central NY
    Posts
    287
    Thanks
    220
    Found these boards loaded. Its from a Dell laptop docking station. Had about 5 of them, wish I had more...
  31. The Following 2 Users say Thank You for This Post by jiffy117:
  32. #278
    jiffy117's Avatar
    SMF Badges of Honor
    Member since
    Feb 2014
    Location
    Central NY
    Posts
    287
    Thanks
    220
    should have waited to post. have a question on these. are they wet tant? or just electrolytic. they came out of the housings shown, looked through all pics couldn't find similar:
  33. #279
    jiffy117's Avatar
    SMF Badges of Honor
    Member since
    Feb 2014
    Location
    Central NY
    Posts
    287
    Thanks
    220
  34. #280
    SMF Badges of Honor
    Member since
    Dec 2013
    Location
    Doral, Florida USA
    Posts
    207
    Thanks
    96
    Quote Originally Posted by jiffy117 View Post
    I do not believe these are Wet Tantalum Capacitors - However it is very weird because they most definitely look like wet capacitors other then the two wires sticking out of the top.
    The Black capacitors are SMD;s the yellow ones are not
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Browse the Most Recent Threads
On SMF In THIS CATEGORY.
OR
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
The Scrap Metal Forum
    The Scrap Metal Forum is the #1 scrap metal recycling community in the world. Here we talk about the scrap metal business, making money, where we connect with other scrappers, scrap yards and more.
SMF on Facebook and Twitter
Twitter Facebook
