I bought one on ebay for 89. I may not get my $$$ back right away but I consider it another tool that I own that will make my life easier. It makes it alot easier too. One slip with a razor blade and it would of paid for itself many times over.
Let SMF Help YOU Grow Your Business - Click to Learn More
Connect with SMF on social media! Follow SMF on Twitter - Like SMF on Facebook
Click Here For The Scrapper's Guide to Refrigerant Recovery
Get on the #1 Newsletter for Metal Recyclers - Subscribe to the SMF Newsletter
Do not PM me for support - Open a support ticket
I do not know who i got the idea from on here but i use a 2x4 with holes drilled in it for wire sizes, and screws screwed into the sides so the screw tip cuts the insulation. it works soso, but i will buy a good wire stripper eventually.
I made one of these last night to try it out. I only got to use it on some house wire (I dont know what its called, but its used for house wiring I think). The wire had a clear easily broken covering over the insulation & it kept breaking & jamming up inside the tunnel. I have yet to try it on wire that just has the regular insulation though.
I tried it again last night on some regular insulated wire (the kind without the clear, easily breakable coating over the insulation) and it worked surprisingly well. Just gotta get the depth of the screw exactly right.
edit: I just had an idea. If I took a really thin blade & cut a thin line down the block of wood to the hole..... I bet I could stick a boxcutter blade in there at just the right angle & then clamp the wood (in a vice or clamp).... it may hold the boxcutter blade in place good enough to cut the insulation once passed thru.
