Results 1 to 3 of 3
Breaking down a Jen-aire Stove
    Area67 started this thread.
    Florence,Co
    240
    93
    Well, I had some time on my hands today and decided to completely break down a Jen-Aire stove that came into the yard! I easily removed the cast aluminum trays (about3 lbs) and then removed a series of phillips scews w/ the cordless drill. The outer steel shell then came away from the inner stove allowing me to harvest 3 lbs of #2 insulated wire and 1/2 lb of #1 insulated wire. The top and the face came to 12 lbs of magnetic stainless steel. The unit also has a fan with a 11 lb electric motor (had to bash off the fan due to a nasty press fit attaching it to the motor shaft). About 2 lbs of aluminum in the burner assemblies (3 of them). I also took the motor off the clock and found a bit of brass in the gear assemblies. The whole process took about 20 minutes and it was easy to do. The only tricky part was realizing that the fan+motor comes out the side of the oven easily if you unbolt the 7/16th bolt in the center of the shaft that is hidden behind an aluminum shield (round) found on the inside of the oven unit. The motor shaft has a fan on the outside of the oven and a small fan that services the inside of the oven (all on the same shaft)...take off the on the inside of the fan and the rest falls out. If ya get one break it down, well worth it!!
  2. The Following 3 Users say Thank You for This Post by Area67:
    boise, ID
    1,605
    469
    How many pounds of shred did you end up with?
    Florence,Co
    240
    93
    I did not weigh what was left but I am going to guess about 80 lbs of shred, it was a small counter top unit. It just came apart so easy with the cordless I will do them from now on
  5. The Following User Says Thank You to Area67 for This Post:
  6. Similar threads on the Scrap Metal Forum
    1. old microwave / stove
      By geravega77 in forum Scrap Metal Videos
      Last Post: 07-18-2012, 09:31 AM
    2. Cast Iron Wood Stove?
      By Koldes in forum More than Scrap Value
      Last Post: 06-24-2012, 09:32 AM
    3. How do I prep a Washer / Dryer / Stove?
      By Backwell in forum Scrap Metal Questions and Answers
      Last Post: 02-05-2012, 04:17 AM
    4. need 4 elec stove switches
      By EcoSafe in forum Off Topic Discussions
      Last Post: 10-20-2011, 08:03 PM
    5. Is a propane stove worth anything??
      By worley76 in forum Scrap Metal Questions and Answers
      Last Post: 08-14-2011, 11:04 PM
