Results 1 to 5 of 5
    Bear started this thread.
    6,815
    Yet another Degaussing strip tip ( Method # 479.5 )
    After accumulating a number of degaussing cables, and attempting several somewhat awkward approaches to stripping them, I was considering ripping a V-groove into a 2x2/2x4 about 3 ft long, hanging it on the wall, and using a clamp at the top to hold the cable.
    Here's a simpler method, running a screw into a corner stud, and just putting a bend in the cable at the top to hold it on the screw. It's working great so far, and the plastic wrap I hung last fall in the workroom makes the cutting go that much smoother. The cable stays right in the corner and makes cutting the wrap a snap.
    One thing I'd suggest if you try this method, be careful where you have your other hand while cutting ; )
  2. The Following 8 Users say Thank You for This Post by Bear:
    Jeremiah's Avatar
    Virginia
    437
    147
    Do you loose alot of time when transitioning, hanging, from wire to wire? Seems like it would work well. I guess the method I've come to use is with a mallet. Flaten out the degausssing wire by hitting it, and use a box cutter knife. By being flat it prevents the blade from slipping off. Also, pressing too hard causes much more work and slipping. You only need a tiny amount of pressure to cut through the slim tape.
  4. The Following User Says Thank You to Jeremiah for This Post:
    6,815
    I didn't try flattened but that would help. I did wind up cutting the smaller ones on the worktop, and flattened would be good there. Today I stripped a bunch of old battery cables and just did em on the work bench.
    Hanging in the corner worked good, but needs a plastic corner angle about 3 inches on each side and 3 ft or so. It keeps them in place and saves having to flatten them to keep it lined up.
    Thinking even now on a good flattening process though, how do you flatten yours ?
    Maybe a ringer assembly off of a ringer washer, or some of the workings off of a treadmill??
  7. The Following User Says Thank You to Mechanic688 for This Post:
    6,815
    haha, that crossed my mind Mech, I've got 3 of them here but none with a good wringer assembly. I was at a cousins house one time and they had one set up to shell purple hull peas, just feed the peas into it and crank ; )
  9. The Following User Says Thank You to Bear for This Post:
    1. tv degaussing cable colors
      By jbravo54 in forum Scrap Metal Questions and Answers
      Last Post: 01-04-2016, 11:57 PM
    2. Idea for Degaussing Cables
      By BRASSCATCHER in forum Scrap Metal Tips and Advice
      Last Post: 03-05-2013, 04:55 AM
    3. Degaussing Wire - Aluminum?
      By chaseonthego in forum Scrap Metal Questions and Answers
      Last Post: 09-29-2012, 03:12 AM
    4. tv degaussing cable
      By GeorgeB in forum General Electronics Recycling
      Last Post: 03-20-2012, 02:33 PM
    5. simple wire stripper for tv degaussing coils?
      By ilyaz in forum Scrap Metal Questions and Answers
      Last Post: 02-15-2012, 09:55 PM
