Results 1 to 20 of 27
Loading Heavy Items
| Scrap Metal Tips and Advice
    KzScrapper started this thread.
    Loading Heavy Items
    Had to pick up a 100 gallon water tank and knew there was no one but left the secretaries at the pluming company when I would be getting there. Tank was over 700 pounds and there was no way I would be getting it in the van myself.
    I did have some room to work with and was in a lot covered in rock so the first thing was to tip it over and roll it behind the van. Then I used a 4 x 4 post ran thru the open windows up front for a hitching point for a come-a-long. Used the car ramps for it to inch it's way up the back, and after about 15 minutes I was on my way to the yard.
    You may want to use a beefier strap then I used depending on the weight and a towel draped over the cable/strap is a good idea in case it breaks it will slow down the whiplash.
  2. The Following 14 Users say Thank You for This Post by KzScrapper:
    Jun 2013
    Toledo, Ohio
    550
    551
    Would you have any suggestions on how to remove a 500 lb. boiler
    You might also want to be careful of bending your window channels.
  5. The Following User Says Thank You to Mick for This Post:
    Cincinnati, Ohio
    285
    271
    Whoa, what a coincidence: one of yesterday's freebies on CL was a 100 gallon water heater. Your idea is great for pulling heavy stuff up into a van, I like it.
  7. The Following User Says Thank You to Wolfwerx for This Post:
    copycat's Avatar
    South Western PA
    215
    150
    pretty crazy. If I did that it would surely bust the van up glad it worked out
  9. The Following User Says Thank You to copycat for This Post:
    99problems's Avatar
    Jul 2013
    Atlanta
    72
    hmm. i have been debating asking owners of a printing company about the engine they have sitting on pallet out back. but still have no clue how i would get it into a van, truck, or car if they said "get it out of here please" i like the idea but do wonder if it would hurt frame around window.
    99problems's Avatar
    Jul 2013
    Atlanta
    72
    if i was looking for a "come a long" what would it be listed as , and is it at part store or tool store? do they have it at harbor freight?
    99problems's Avatar
    Jul 2013
    Atlanta
    72
    is this it?
    4000 Lb. Capacity Cable Winch Puller
    funny thing is i put come a long in search and it brought it up lol
    On, Can
    101
    56
    A small ATV size winch might be a little easier than the ol' "Come a long" ... a few bucks more,esp if a remote control, but you're also not in the line of travel if a cable should happen to break.
    Mind you if if the cable is in good condition and you follow some basic winching techniques, ....ie draping the cable with something heavy, ie fabric like an old jacket or carpet perhaps can minimize the cable whipping if it breaks.
  14. The Following User Says Thank You to Jvcr1 for This Post:
    Quote Originally Posted by scrapping4ever View Post
    If you don't have to worry about stairs try a heavy duty flat dolly, if there are stairs then try and separate it into several pieces.
  16. The Following 2 Users say Thank You for This Post by KzScrapper:
    I was concerned about the window frame but they are pretty solid on my van and after checking them once the load was coming on they seemed fine and not so much as a mark when finished...Built Ford Tough.
    A "D" ring mounted to the floor with bolts run thru would be a good idea.
  18. The Following User Says Thank You to KzScrapper for This Post:
  19. #12
    Quote Originally Posted by 99problems View Post
    I do use stuff from Harbor Freight but do not like their come-a-longs. I've had mine for years and want to say they came from Home Depot.
  20. #13
    6,815
    I once used the doors of a van to tie a rope on each post, then another rope down to the tranny, and used a screwdriver to twist the ropes until the tranny was in position to stab it onto the engine.
    I'd just swapped engines, and the newer engine was out a standard tranny(had a pilot bushing in the crank) and the automatic wouldn't bolt up. I musta dropped that tranny and tried again over a dozen times, before I figured out it was the pilot bushing stopping it from fitting in there. By then I had it down to where I could completely drop the tranny and then lift and bolt it back up in about ten minutes haha, without even breaking a sweat ; )
  21. The Following User Says Thank You to Bear for This Post:
  22. #14
    On, Can
    101
    56
    I've also found that a well used come along, its assembly consists of several plates of sheet metal sandwiched to create it's gears, and under lots of use, ...they splay/separate, and I have had to hammer them back to shape and weld the sheets together to prevent that from reoccuring. So that also plays on my lack of usage of those anymore. Keep in mind that was probably like 20+ years ago that I was using comealongs. Don't get me wrong they are good in a pinch when you need them, and this is info on how to extend the life of it's main ratchet gear.
  23. The Following 2 Users say Thank You for This Post by Jvcr1:
  24. #15
    ks
    2,187
    2,513
    I thought I was the king of "making do" and finding unorthodox solutions. Til I read this post that is, I'm truly impressed!
  25. The Following 2 Users say Thank You for This Post by taterjuice:
  26. #16
    auminer's Avatar
    Allen, TX
    1,233
    579
    Simple. Ingenious.
    Kudos.
  27. The Following User Says Thank You to auminer for This Post:
  28. #17
    webuyselltradestuff's Avatar
    May 2013
    Watkinsville, GA
    950
    131
    If you have say concrete stairs out of an infinished basement (ie they can take a bit of abuse) you can always use a couple of cut sheets of plywood or a couple 2x8s..put them down on the stairs (this is assuming a straight shot out of said basement by the way) and use the come along idea hooked to either the van, truck or trailer to pull the large honking boiler/water heater or other out of the basement...it will slide right up the 2x8s or plywood...just need to guide it a bit and make sure the thing fits throught the door. Same application just using an inclined flat surface where the large object will slide.
  29. The Following User Says Thank You to webuyselltradestuff for This Post:
  30. #18
    ginofrater's Avatar
    May 2013
    506
    921
    It is a very good post ,and the pics are clear and well taken.
    It make the forum look very good.
    Thanks for sharing.
    ginofrater
  31. The Following 2 Users say Thank You for This Post by ginofrater:
  32. #19
    Turning out to be Hot Water Heater Week...#10 scheduled for this morning.
  33. #20
    TheRecycler's Avatar
    Ithaca, NY
    616
    31
    Quote Originally Posted by KzScrapper View Post
    Brilliant, thanks for sharing. Now that's working smart.
    Your Trash-My Cash
    Yours Truly, TheRecycler:
    RecycleReuseItAll@Facebook.com
  34. The Following User Says Thank You to TheRecycler for This Post:
  35. Similar threads on the Scrap Metal Forum
    1. loading items too heavy to pick up
      By iicekingg in forum Scrap Metal Tips and Advice
      Last Post: 03-28-2013, 02:29 AM
    2. Using a big area rug to lift heavy items
      By GentlemanScrapper in forum Scrap Metal Tips and Advice
      Last Post: 11-14-2012, 12:34 AM
    3. Up loading pictures to Boardsort
      By rjuliet in forum Introduce yourself
      Last Post: 10-28-2012, 07:38 AM
    4. how to drag heavy items uphill,out of ditches,etc.
      By haribobear in forum Scrap Metal Tips and Advice
      Last Post: 12-08-2011, 12:18 AM
    5. help loading photos
      By EcoSafe in forum Off Topic Discussions
      Last Post: 11-26-2011, 11:34 PM
