Results 1 to 20 of 30
Scrapping out of a car 101
| Scrap Metal Tips and Advice
    andrew1990 started this thread.
    Bourbonnais IL
    129
    I have been seeing more and more post on how some people do not have access to a truck. As some of you already know, I scrap out of my small Saturn Sl2, which is a pretty tiny car. Is it my most ideal vehicle to use for scrapping, far from it. I have made it work for me most of the time and Im going to tell you new as well as old timers how I have done it.
    PROS
    First thing I want to cover is, dont feel like you can't haul much or the guys in big trucks will outhaul you every time. There are many advantages to using a car rather than a truck. Here is my list off the top of my head,
    1) Gas Mileage- Larger trucks can sometimes see single digits when it comes to miles per gallon. All the trucks that I have owned in the 5 cubic liter range got 18MPG Max on a good day while cruising the highway. A small car such as mine can get as high as 42mpg, although 30mpg is a safer estimate especially around town.
    2) Under the Radar - Where I live, the cops always harass scrappers. They see that old pick up truck going down the street and they are instantly on your butt for miles. A car fares quite a bit better and almost always seems to slide right under the radar. I advise no tint on the windows as that does draw some attention.
    3) Storage - Scrap is easier to lock up inside your car vs the back of a pick up truck. Most scrap thieves dont expect to find any in a parked car, and normal car thieves dont want to deal with the scrap.
    Cons
    Now obviously there are some negative qualities to using a car for scrapping out of. Im going to list what I have come across and how I overcame these issues.
    1) Space - A car has a lot less room to fit scrap into. Its a tight fit and sometimes you may have to give up on larger items such as washers and dryers.
    My Thoughts - Watching other scrappers at the yard as well as my dad, the likeliness that you come across something too big to fit is pretty small. The scrappers I see usually have less than 1000LBs worth of steel in their truck and if I tried I could usually fit that in my car with a little work. You also use much less gas so even if you have to make 2 or 3 trips to the yard to carry as much steel as a larger truck, you make about the same amount of money at the end of the day. You can also focus on Non-Ferrous and Escrap which I usually try doing. If you have a little money you can also purchase a hitch and trailer for most cars.
    2) Maintenance - A car is not designed to carry such heavy loads. They have weaker parts which need to be replaced a lot more often if the car is abused. Tie-rods, brakes, CV Axles,struts, etc....
    My Thoughts - I drive a lot so I keep up on maintenance anyways. Cars need more attention to details more often in my opinion, especially if your hauling a lot of weight. I have done many dangerous loads in my car and I strongly advise against weighing your car down over the manufacturers limits.
    3) Public View - This might not be a limitation of the vehicle, but rather the driver. When I first started scrapping out of my car, I felt like a homeless person or something. People will give you weird looks when you jump out of your car and load a water tank in the truck, or strap a grill on top of your roof.
    My Thoughts - I overcame all the bad things I thought about myself and realized "I just made a $20 bill of that". At the end of the day, the main priority is putting food on the table, and don't forget that.
    This isnt a complete guide, but I hope to add more tips and advice in the future.
    Scrap Yards call me crazy when I pull up with a ton of steel in my Saturn sl2.....
  2. The Following 12 Users say Thank You for This Post by andrew1990:
    corycouch's Avatar
    jonesboro ar
    1,405
    3,766
    There's a guy here that uses a escort zx2, I'm amazed at what he crams in that thing
    cory couch
    c & c recycling
    JUNKERS AND CLUNKERS
    (870) 897-6484
    waredu's Avatar
    309
    95
    As far as your point 2 under Pros goes - it really depends on where you are. In the North and East areas of the US, this may be the case. Down here in rural central Texas - not so much. 1 in every 3 vehicles is a pickup, and 2 of every 3 is a pickup, van, or SUV. Even in the cities and suburbs, it's about a 50/50 mix. A beat-up old truck doesn't even draw a second glance.
    And while you may not come across something too big to fit in your car very often - you will have to turn it down when you do. And that could lead to a permanent lost opportunity. Plus, when you have a truck, you will find those large loads more often because you are looking for them.
    Don't get me wrong - scrap with what you have. I used a 98 Honda Accord till I totaled it. For the past year I've had a half-ton Chevy. Just this weekend, I was wishing for a 3/4- or 1-ton. I just couldn't justify overloading it by close to 1,000 pounds. The truck is rated to carry 1,594 lbs of passenger and cargo. That leaves me a bit more than 1,300 lbs cargo capacity and I need to move 2,200 lbs. So, I will need to make two trips
    6,123
    11,885
    Go to the darkside...get a mini-van!
    No Seriously...good post!
    Sirscrapalot - Mmmmini-vans
  6. The Following 2 Users say Thank You for This Post by Sirscrapalot:
    waredu's Avatar
    309
    95
    LOL - that's what the better half drives. She doesn't like me getting it dirty on the inside though.
    6,123
    11,885
    It's well worth it Waredu! Just let your wife use the one she's got an pick ya up an older one.
    I use a 99, an I love it. Wife loves it when we go on trips, plenty of room for her stuff, an still room for the dogs!
    I rented a car last year, to go to FL, cause the van was having some work done, an let me tell you..I don't know who was madder over lack of room, the dogs, or the wife cause she couldn't bring as much stuff. Lol.
    Sirscrapalot - Time is a circus, always packing up and moving away. - Ben Hecht
    6,815
    #3 Pro was pretty slick (theft) "Most scrap thieves dont expect to find any in a parked car, and normal car thieves dont want to deal with the scrap"
    I had one pickup in my life until about 94/95, and didn't have it long. First it was cars, then a van, then a car, then a truck, which I promptly covered up with a topper, which I thought worked well too, until I had to haul some bigger loads, so I did just what those city folk do, haha, headed up^^ ; ) Built a little ladder/lumber rack onto the top of that topper. I put some loads on top of that thing that I wasn't sure I was going to be able to stop, but only put that part into the equation when it came time to do so.
    After that it was a lil truck again, which I also built a rack onto, this time without the topper. By now I'm totally convinced, the last vehicle I bought was the first one in my life that I had actually known what it was going to be before I even started looking, a truck. Due to having a trailer I'm yet to add the rack, but that day may yet come, I've already got a sideboard set built but seldom need to use it.
    The point I'm actually trying to make is to do what you gotta do with what you've got, always with all possible safety in mind. And if no other option exists, use a rack. Buy it, build it, anything that works. There's roof racks, trunk racks, maybe even others. Too bad I didn't have one in the 77 Delta I moved everything I owned at least a half a dozen times in, not to mention all the wood and building materials I hauled around so many times, sometimes having to strap it through the windows onto the side of the car.
    Until you guys with cars can get a trailer, or a truck, good luck with your cars
    1,159
    I think it is a waste of time myself.Yeah you get better mileage but have to make 2-4 trips then there goes all of your time when you could be looking for more stuff.Yeah for little stuff here and there then not so bad or if you have to drive 15 miles for a battery or 2 then yeah.But if i did that i would use the car to get the little stuff take it home and stock pile it then have a big load to haul in with a truck.
    Carhuntr's Avatar
    Dumont MN
    90
    when it comes to hauling scrap with a car i do it like this
    If im heading into town i stop my one of my contracts that usually only had a few towers a week and i will toss them in the back seat and bring them home
    then when i am done sorting my ewaste since i have a local buyer that pays decent price on some stuff so i haul it my good bang for buck stuff mobo finger cards ram processors etc never really much weight or space but good price and since neaerest bank is 20 mile from him it makes a big differance on gas but if i got iron tin or appliances the suburban comes into play and its alot or bigger stuff then the trailer gets to come out to play
    luniticfriend's Avatar
    Minnesota
    58
    31
    In my opinion if you are hauling non ferrous I can see where a small vehicle would be a good idea (weighs good but doesn't take a lot of room). I run a bigger truck and it has 2 locking boxes on the sides (about 4x2x2) for the non ferrous things. I normally load 5-6 1/2 ton a trip though (no sense in wasting fuel).
    F350scrapper's Avatar
    May 2014
    Minnesota
    156
    71
    Sounds like you live in a sketchy area if the cops hate trucks and scrapper that much and you have scrap thieves???? Also My F-350 gets only gets 12mpg but i can pile appliances grills up in there where you can only get one appliance. I also have the ability to haul any trailer and load 20 appliances to your one.
    72
    I also scrap out of my car and one thing I do to make my trips to the yard more efficient is break things down to their smallest component in order to make them fit. I can give 3 quick examples. I put a post up yesterday regarding how I was able to make the hood of a car fit into my Hyundai accent, it took me a little while longer than I wanted but I was on a mission to make it fit. This morning on my way to the yard I found a metal pipe that was about 15 feet long and 5 minutes with a hacksaw and my problem was solved. Last but not least, this afternoon I found a dishwasher at a house that was being remodeled. Once I was done pulling the motor out of the bottom, the guy working on the house was nice enough to let me use his sawzall, 2 vertical cuts later(about 5 minutes) and I was able to fold the sides over and make it flat. I don't do enough volume to warrant having a truck yet, but its on my wish-list. I lose a little bit in time, because it would be easier to just toss things in the bed of a truck. But I feel like I gain some of it back with regard to gas mileage. I also get a strange look every once in a while but I'm more concerned with the financial goals I've reached and the goals I'm striving for now than what other people may think of me.
  15. The Following User Says Thank You to gueroinchicago for This Post:
    AdmiralAluminum's Avatar
    Jan 2014
    Ontario
    737
    824
    I say KUDOS to you andrew and guero! (we need a thumbs up emoticon, IMO). For my first 6 months, I was on foot (in Canadian Winter, no less), I would just walk around my suburb and pick up anything I could carry in a back pack. I didn't get rich and couldn't really even take anything to the yard...but I knew access to a car was coming...and then I scrapped with a 98 Lumina for over a year, the pile of metal at the side of the house disappeared and all my aluminum, copper rode in the front with me. I'm proud to say that the side of the house didn't stay empty for long! In May, the wife got a new van, so I got the old one, SOOOO MUCH BETTER. But I don't forget how I got there and I encourage you NOT to be discouraged, by anyone here or on the street. (insert thumbs up emoticon here). Your doing good for the planet and yourself, so keep at it!
    METAL IS MY MISTRESS...PLEASE DON'T TELL MY WIFE!
    Fubar701's Avatar
    Sep 2014
    Ellsworth Maine
    78
    10
    All i can say is my truck is a 1/2 ton, I get about 20MPG (gota love cylinder deactivation) and the max payload is 2108lbs
    Mar 2014
    South Central Utah
    37
    Currently I'm using my wife's 2002 Windstar for scrapping, it has drawbacks however it is what I have until I can get bills paid off and save up enough to buy something better. I'm not going into any more debt to buy another vehicle. Sometimes getting stuff in the van takes some creativity. My biggest problem is the distance from the yards, the 3 closest yards are all 50-60 miles away one way, so I try to make every load count. In the future I'm planning on getting a trailer then eventually a truck.
  19. #16
    4,985
    1,257
    I feel bad for you guys that have to drive 50 miles to a yard.........I can count at least 10 yards within 25 miles of my house......... I sell stuff to about 4 diff ones depending on what I have
  20. #17
    Patriot76's Avatar
    Buffalo Commons
    2,949
    10,591
    Respect the fact that others can make money scrapping out of a car, van, or even a truck. With the distance involved, 1 ton truck and 26 ft. trailer is the minimal transport system. In Omaha I saw scrappers hauling metal in a trailer attached to their bike and in shopping carts. To each their own.
  21. The Following User Says Thank You to Patriot76 for This Post:
  22. #18
    charn's Avatar
    Anywhere But Here
    250
    As poverty rises, more people scrap their own junk instead of having it hauled away. With less scrap to get and higher fuel prices, big trucks will be less affordable. Scrappers could be in the first wave of Grapes of Wrath bodywork: modifying cars to use as trucks.
  23. #19
    ks
    2,187
    2,513
    Very good points by all. Being a guy who started his scrap career out of a rx-7, which will haul 750# of cast if you take out the pass. Seat, I got mad respect for y'all.
    As per fuel mileage, the peak number is really worthless, a real world AVERAGE of all your combined driving habits is the important part. My 6.0L could get 25 mpg going down a 6% grade but that number is really irrelevant unless you never have to drive uphill, Wait in traffic, or crawl thru 2 miles of stoplight drag racing, you get the point.
    And a lot depends on how you acquire scrap, if you buy like me, mileage is usually less important, than someone who might drive 50 miles or better a day shopping curbco.
  24. The Following User Says Thank You to taterjuice for This Post:
  25. #20
    charn's Avatar
    Anywhere But Here
    250
    Cars are lower than trucks. A pickup car would be ideal for the quantities I get. I have passed some items because I didn't want to lift them up to my truck bed.
    1. scrapping a car I have
      By captainrandom in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 06-13-2013, 06:20 AM
    2. Need Advice - Scrapping/parts car
      By street_sweeper in forum Scrap Metal Tips and Advice
      Last Post: 12-28-2012, 12:28 AM
    3. Scrapping For A New Car ... Scrap the old cash for the new
      By Redmetal in forum Introduce yourself
      Last Post: 07-29-2012, 07:01 AM
    4. Advice 101
      Last Post: 01-04-2012, 10:46 AM
    5. scrapping part-time w/ small car?
      By dustmuffin in forum A Day in the Life of a Scrapper
      Last Post: 06-06-2011, 10:20 PM
