Results 1 to 10 of 10
How to tell if it's brass or plated?
| Scrap Metal Tips and Advice
    gravygrabber started this thread.
    Montana
    99
    Found a table lamp today. Looks like a cast brass body so I grabbed it out of the dumpster. Someone cut the cord off already but that's pretty common. Seems like they don't know there is more copper in that TV yoke then the power cord but that's fine with me I'll come pick the meat off the ribs! Anyway the body of the lamp is heavy but it doesn't stick to a magnet. It has a marble base to it. Anyway to further confirm what it is?
    Phantoms001's Avatar
    556
    167
    The only way I know how to check is put a grinder to it. If it's yellow inside it's brass, if not, it is mostly "pot metal".
  3. The Following User Says Thank You to Phantoms001 for This Post:
    MetalEarthRecycling's Avatar
    Wichita, Kansas
    201
    Grinder or file works well or really anything that can scratch it deep enough. Sometimes they are made of cast aluminum with a goldish surface coating to make them look like brass.
    3,436
    Going to be zinc.
    Nebraska
    512
    521
    I grew up using the term 'puter' when identifying some type of junk metal. This thread mentions 'pot metal' and 'zinc'. I've sold stuff as cast aluminum when I would have called it 'puter' many years ago. On the other hand, I took apart what appeared to be a brass bearing off a shaft the other day and the center of it was WOOD !!
  7. The Following User Says Thank You to Yunkman for This Post:
    Wichita, Kansas
    201
    Going to be zinc.
    I agree with that. I rarely Get Die cast zinc, if i have a piece i Usually throw it in with cast aluminum. I should probably stop doing that and make a pile since it is different and worth a little less.
    Montana
    99
    Quote Originally Posted by Phantoms001 View Post
    I hit it with the grinder and it looks like aluminum to me and doesn't stick to a magnet. Could it be cast alum. ?
    Wichita, Kansas
    201
    I would take a sledge hammer to it and break it into some pieces. Might help you to see the metal a little better and help you determine. Or just ask your yard/buyer if its okay if 1 piece of die cast zinc goes in with your cast aluminum load.
    4,758
    6,037
    Die Cast zinc is a lot less than cast aluminium by me. .10-.15 vs .50 - .55 lb
    BigTime's Avatar
    NationWide
    10
    And to know the difference between the two, THE WEIGHT. Zinc is a lot heavier than aluminum.
    BBS
  13. The Following User Says Thank You to BigTime for This Post:
    1. Is it Stainless Steel, Chrome-plated Brass or Aluminum?
      By Mick in forum Scrap Metal Tips and Advice
      Last Post: 09-26-2014, 09:12 AM
    2. Another one :) Brass plated towel bar
      By Gord in forum Scrap Metal Questions and Answers
      Last Post: 03-01-2014, 07:46 AM
    3. brass ends on powercords, brass connectors on crimped wires in monitors & tvs
      Last Post: 06-17-2013, 09:09 PM
    4. This thead is a question - Brass fittings and nickel plated plug ends
      By 41haikuwarriors in forum Scrap Metal Questions and Answers
      Last Post: 05-06-2013, 08:51 PM
    5. Silver Plated Silverware & Dishes can be Brass or Nickel
      By BiggerHammer in forum Scrap Metal Videos
      Last Post: 01-13-2012, 07:34 AM
