Results 1 to 14 of 14
what do i do with this
| Scrap Metal Tips and Advice
    johnyor29 started this thread.
    Jan 2014
    powell, tn
    79
    I got this winding from an old hand held buffer. Do i need to get copper windings out or just sell ad is. I wanted to just get copper to add to my bucket but have cut and beat and still stuck to shaft and caseing. Any tips or tricks to get copper. Thanks
    Jan 2014
    powell, tn
    79
    sorry app will not allow me to upload picture or link
    jw7783's Avatar
    Jan 2014
    Northern CT
    205
    250
    Is it worth the time you're spending trying to get it off? Don't undervalue your time, could you be making more money somewhere else? You should be able to just sell it as electric motor if it won't come apart.
  4. The Following User Says Thank You to jw7783 for This Post:
    Jan 2014
    powell, tn
    79
    thanks i think that is what i will do it was good size and was wanting to throw in with my good copper since i have a big bucket full of it and no other motors to make alot of pounds
    Maybe yes maybe no. Tear one apart and see for yourself. The more you do the quicker you will recognize when you should scrap it whole or break it down.
    "Is it worth it for me to break down, strip etc" has to be the most popular question asked on the forum. The short answer normally ends up being: it might be. Mike.
  7. The Following 5 Users say Thank You for This Post by miked:
    2,864
    350
    Are you talking about the armiture from the middle of the motor? If so then you can cut it in half and using a small steel rod and hammer knok the copper out. Or you should just put it in with electric motors (that's what I do).
    Jan 2014
    powell, tn
    79
    yeah thats what it is i tried to cut and beat it out earlier but did not work so i am starting a bin of electric motors since i found a few more broken drills can i throw it in with my scrap from tvs like the things cable from tube plugs into
    6,815
    Quote Originally Posted by johnyor29 View Post
    That's actually a question for your yard john, they all vary a bit
    Jan 2014
    powell, tn
    79
    i finally got a chance to ask this particular yard what to do with those. they said they would consider it as copper bearing.
    Jan 2014
    powell, tn
    79
    i guess i will do that since i had tried grinding them and still never came loose lol
    Copper Head's Avatar
    Up North
    1,883
    579
    Choice 1 - sell as motor
    choice 2 - deal with it & with saw cut half copper out pull rest with vice grips pliers
    choice 3 - with saw cut only end copper both sides as tight as possible sell off steel chunk with copper center as copper bearing
    Over all removing copper from motors is what it is . Most likely your a mechanical person so you see what has to be done
    if you can't get all the copper get what you can
    My yard just dropped copper prices to $2.57 yet motors are still at .28 lb that is probably the spread that
    allows for selling as is .
    Before copper dropped a typical motor with copper removed was around $1. 25 to 1.50 per motor gain
    I have not recalculated new pricing but I know in a day or two motors could go lower, whats holding them tight is my yard wants steel for now.
    Some motors like a ceiling fan have such weight with low copper, better as is
    in time once you realize removing copper is not like doubling your money, you will pick the easy copper removal motors and leave others be.
    I am seeing vacuum motors these days with plastic cases there lighter so motor price is lower yet after dismantling less to scrap also .
  14. The Following 2 Users say Thank You for This Post by Copper Head:
    Jan 2014
    powell, tn
    79
    thanks ch lots of good info i appreciate it
    Mar 2014
    South Central Utah
    37
    Good advice so far especially since your time is what's the most valuable. Generally when I get something that I've not dealt with before I take it apart to see what's inside and if it is worth the time or effort to take it apart if I find another one.
    Hope this helps.
  17. The Following 2 Users say Thank You for This Post by Haztech5:
    Jan 2014
    powell, tn
    79
    thanks everything helps
  19. The Following User Says Thank You to johnyor29 for This Post:
