Results 1 to 8 of 8
IC chip or processor?
    jimicrk started this thread.
    jimicrk's Avatar
    Sep 2013
    Tennessee
    2,826
    2,917
    I'm not sure what this came out of but it was from the last load of telecom equipment I brought home. I'm wondering what the large square thing that says Broadcom on it is. I have been scrapping a lot of Nortel phones and all of the boards have these also.
    There is one phone jack on that board. Phone related.
    jimicrk's Avatar
    Sep 2013
    Tennessee
    2,826
    2,917
    Yeah, I just looked at the board again and it came out of a NEC IP phone but what about the Broadcom chip. Is that an IC chip or some kind of processor.
    Scrappah's Avatar
    1,058
    320
    The large square thing with Broadcom on it is more likely a processor for a couple of reasons.
    See the gold colored arrow ? That tells the assembler how to orient the chip on the board. You see that same thing with a lot of processors on computer motherboards.
    If you take a heat gun and desolder it there are lots of tiny contact points just like on a processor. If i'm breaking down boards i usually group them as: solder in, green fiber, capless processors. Where it takes so much time to break down a board it's probably better not to mess with breaking them down. That's more along the lines of being the refiner's job.
    You might try Googling the name & part number. Sometimes it will tell you what it is and even the specific thing it was used for.
  5. The Following User Says Thank You to Scrappah for This Post:
    3,436
    Its a northbridge chip. Not really a processor, it communicates with the other chips on the board. Find them on mobos, fingercards and telecom boards. Some boards may have two, a northbridge and a southbridge. Where they are positioned on boards in relation to the rest of the chipsets is how they get the name. Good for gold recovery and easily removed with a spackle knife or thin flathead screwdriver. If removed it will downgrade the price you receive from a buyer.
  7. The Following 4 Users say Thank You for This Post by BRASSCATCHER:
    I bend the board right under that chip, then again at right angles to the first bend, then slip a flat blade blunt knife under its edge, then bend it in the other direction.
    They normally pop off then.
    I save them up and expect to sand the solder spots off, incinerate them and remove the Gold plated Copper part inside it.
    Then somehow remove the Gold from the Copper.. But thats for another forum...
  9. The Following 4 Users say Thank You for This Post by eesakiwi:
    webuyselltradestuff's Avatar
    May 2013
    Watkinsville, GA
    950
    131
    what brasscatcher said is correct...I have a buyer that would give between $20-30/lb for those chips....HOWEVER, they are very light. Desoldering or using a board preheater to loosen the solder is the easiest way...other than that, chisel around the edges and then pry it up....other option would be to use a vibrating cutting tool.
    I just end up leaving mine on and getting full or better value on the whole board itself....time and effort vs return you know.
  11. The Following 2 Users say Thank You for This Post by webuyselltradestuff:
    armygreywolf's Avatar
    Germantown, WI
    1,084
    193
    I wasn't positive what it was at first so I looked it up. It's an on-die multiplexer. IP phones use these so they can use a common line for multiple phones running duplex communications... The chip receives multiple signals and reassembles the pieces meant for it, outbound is the opposite it cuts up its signal, compresses and sends them out in packets. Broadcom is a maker of these and they can be found in various configurations on everything from network finger cards to wifi cards from laptops...even on board networking have these in smaller sizes.
  13. The Following 3 Users say Thank You for This Post by armygreywolf:
    1. Server Processor
      By Abshere in forum Computer Recycling
      Last Post: 12-22-2013, 01:31 AM
    2. Here the Chip THE PURPLE RARE CHIP
      By pcscrapper in forum A Day in the Life of a Scrapper
      Last Post: 11-11-2013, 02:08 AM
    3. processor w gokd fingers?
      By sirex in forum General Electronics Recycling
      Last Post: 05-11-2013, 10:42 PM
    4. This thead is a question - Processor Heat Sink
      By GWOTTO in forum Scrap Metal Identification
      Last Post: 03-22-2013, 08:35 PM
    5. Question about processor
      By drozenski in forum General Electronics Recycling
      Last Post: 11-06-2011, 02:13 PM
