Results 1 to 13 of 13
Monitor cable % copper yield
    bjybjy started this thread.
    195
    10
    In the past I've mixed in the few monitor/video cables I got in with my 55% yield wire with no issues, getting about $1/lb. But now I'm going to have at least a couple hundred pounds of this wire to turn in. Any experience with this volume? Just want to be prepared ahead of time. The next lowest grade is like 30% yield for about $.50/lb Thanks
    Usa
    768
    67
    Up here they dont deal with grades. Its either low or high grade. High being romex and low being the monitor cable. One yard is 70c/1.20 for low/high. Another is $1.00 a lb no matter what it is. Thats the best I could tell you. Personally in your case I would contact high Voltage processing on this board. Im sure he would do a shipment deal and give you far, far better than any yard around,
  3. The Following 4 Users say Thank You for This Post by ozzy214:
    High Voltage Processing's Avatar
    Allentown PA
    316
    63
    I would. Pm me with volume and I will send you price options.
    Jim Dwyer
    President/Founder High Voltage Processing
    www.highvoltagepro.com
    484-226-9323
    195
    10
    Thanks... I sent you a PM.
    Today I broke down two boxes of VGA monitor cables. Most had ferrite rings on each end, though a few only had one.
    Starting weight: 90 pounds
    End result:
    51 lbs insulated wire
    21 lbs gold plated connectors
    18 lbs ferrite rings for shred pile
    Allentown PA
    316
    63
    Those wires will be around 30-40% copper as well.
    what is the current prices for copper coax?
    195
    10
    Quote Originally Posted by zholyman2 View Post
    Most places don't buy coax, I put what little I get in with my shred.
    trashmaster's Avatar
    jonesboro, arkansas
    59
    324
    Those VGA Monitor cables sell for $24.99 each at Best Buy ....
    Might want to check on selling them ,,, as some new Monitors dont come with them,, you have to buy them extra... E-bay....
    195
    10
    Quote Originally Posted by trashmaster View Post
    Thanks for the good suggestion but I had already looked on ebay and wasn't real excited about the prices they were getting. By the time I dealt with ebay and paypal fees, shipping supply costs, etc., I don't think I'd make much more than I'll get for scrap and it would be a lot more effort. Plus it could take a long time to sell that many on ebay and I don't have a ton of storage space. I am selling a lot of other misc items from this lot on ebay though, definately a good place to sell real specific electronic items.
    If it's copper coax, I strip it; but if it's steel coated (cable co.) then in the steel pile.
    I'd cut the ends off and sell as #2 insulated at $ 1.10-1.25 lb. Or clean the ends off and sell to High Voltage. Not too many choices.
    195
    10
    Took all my wire in today. High Voltage had offered me a very competitive rate but he is something like 6 or 7 hours from me and hauling/shipping it there wasn't looking to be profitable. I still appreciate his offer though.
    My yard pays about 10% more if you have over 250 lbs and I knew i was going to be close so I was a bit nervous. I ended up with about 8 boxes, bins and trash cans stuffed full of monitor cable, usb cable, CAT5 cable, parallel port wire, and power cords. It ended up being 260 lbs at $1.08 for $280.80.
    I got a lot of other goodies in this lot including 100s of computer switch boxes used to edit video. The case is solid aluminum and has a good sized Peripheral board in each. I've broken down less than half and took in 64 lbs of aluminum at $.48/lb
    $311.50 payday for a car load or wire and aluminum.
    Add that to the $140 of little plastic fiber optic wire adapters I sold from this lot today on ebay and its been a great day. I still have maybe 150 lbs of this weird data coax like wire to deal with. Might take it in seperate and see if they give me the low wire rate for it since it is multi stranded.
  13. The Following User Says Thank You to bjybjy for This Post:
    195
    10
    Oh, and I ended up with about 55 lbs of gold plated connectors.
    nice deal my good yard here calls all computer wire com wire and pays .45
    1. How to Efficiently Recycle the Copper in the Cable Scrap?
      By amisycopperrecycling in forum Scrap Metal Tips and Advice
      Last Post: 11-10-2012, 02:46 AM
    2. Deguassing cable from monitor/tv
      By Scrappingwson in forum General Electronics Recycling
      Last Post: 03-31-2012, 05:08 PM
