Originally Posted by
Rich
You will get quite a bit of copper and aluminum from the monitors. You are losing money if you give them the monitors no charge. Also as far as the towers go, there is copper and aluminum in there also not to mention the mother boards which can be sold by the pound.
Rich said it. As far as the monitors go, you don't have to pull those apart if you dont want to, but you should definitely pull out the RAM, the CPU, and the wire out of the computers! These things are valuable, and can be sold online for much more than 45¢ a pound.
The motherboards are selling for close to $2.50 per pound on
ebay right now.
Check out ebay here
Also for more info on electronics scrap check this out
Good Luck. Either way you will be making money from something you hadn't planned on buying!
