Results 1 to 16 of 16
    Metalbestos started this thread.
    Metalbestos's Avatar
    Mar 2014
    Baltimore md.
    987
    3,114
    Original Xbox console breakdown first edition black unit
    Ok here is a detailed list on how to properly dismantle a original Xbox system . Some of these units can be used for modification but the resale value is next to nothing for these units . The components inside this one we're all faulty . It had some exsposure to the elements.
    Send your assistant for a Alan key set and a flathead , he may have to make 2 trips
    Flip the console over and remove the 4 rubber grip plugs . Here is a before and after
    Use t20 torq or 3 mm key to remove the 4 screws , these screws can be used to peel up the area around the hidden screws . there are 2 more hidden under stickers . See below
    Pop the top , should just lift off .
    The sheet metal on the plastic outer case is steel as well as all of the screws you will remove . There is a screw in the center in between the cd/dvd drive and the hard drive . Remove this with a t9 or 2 mm key
    Hard drive plastic housing lifts off , use the flat head to guide it up if it's being stubborn .disconnect wire from hard drive and remove hard drive from plastic rail using a t15/2.5 mm key .
    the cd/DVD drive is being held in by two screws , remove them using t10 . The drive and the plastic frame will come out . The screws are on the front towards the lower left . The plastic rail comes out simillar to the hard drive .
    At this point disconnect all wires , t10 the screws to remove the motherboard 12 screws and the power board 2 screws.
  2. The Following 14 Users say Thank You for This Post by Metalbestos:
    Mar 2014
    80
    71
    as a video game collector and original xbox die hard I guess you could say I cringed at this faulty or not
  4. The Following User Says Thank You to Mvpvlad for This Post:
    logansryche's Avatar
    Sep 2014
    Jamestown, TN
    1,215
    1,043
    nice breakdown, you break em down the way I do(the proper way).
  6. The Following User Says Thank You to logansryche for This Post:
    Mar 2014
    Baltimore md.
    987
    3,114
    here you can see the rust on the inside of the heat shield .
    Remove the 4 screws in the front of the console t10 to remove controller ports and eject board.
    Pull off sheet metal from outer case , use gloves for safety , this can be sharp metal . Here is what you should have left.
    Here is the motherboard , weighing in at .55 #'s
    Steel scrap 1.15 #'s
    Plastic abs 2.3 #'s
    Dvd cd drive weighing 1.7 #'s
    Hard drive weighs a pound , this can be further broken down .
    You can also get the transformers and aluminum from the power strip and break down the dvd cd drive as well.
    Additional items that you will have . .25 #'s wire , .45 #'s extruded aluminum , .45 #'s power board
    Controller ports ,fan, and eject board did not register on my scale .
    I did not include prices or board grades in this post as these will ultimately be determined by your buyer. Thanks for viewing and throw me a thanks in my initial post if you would like to vote for me . Keep scrapping !
  8. The Following 4 Users say Thank You for This Post by Metalbestos:
    Mar 2014
    Baltimore md.
    987
    3,114
    Quote Originally Posted by Mvpvlad View Post
    Don't worry I have another 10 or so laying around . some function fully others are just part machines .
    Sep 2014
    Jamestown, TN
    1,215
    1,043
    Where'd you get your scale from and what's its max weight? The small one I use is slowly dieing from overuse.
    Mar 2014
    Baltimore md.
    987
    3,114
    Quote Originally Posted by logansryche View Post
    Max weight is 150 lbs , I like it because it is easily portable and not too heavy .
    150 x 0 05 lb Digital Shipping Scale 12 x 12 Tray Postal Postage UPS FedEx USPS | eBay
  12. The Following User Says Thank You to Metalbestos for This Post:
    Jacvip's Avatar
    Jul 2014
    Cincinnati - ish, Ohio
    19
    50
    Quote Originally Posted by Metalbestos View Post
    I got a brand new one just like it for Christmas!
  14. The Following User Says Thank You to Jacvip for This Post:
    bigburtchino's Avatar
    California
    1,647
    4,388
    I like the scale as well, will used the one I have. If a replacement is needed that's one I will definitely consider. Never tore into a Xbox so thanks for the peak inside.
    Hope you pay the assistant better than minimum wage. Looks like a keeper and a go fetcher!
  16. The Following 2 Users say Thank You for This Post by bigburtchino:
  17. #10
    elkton,md
    1,062
    8,524
    Great breakdown. Its nice to know torque screw sizes before hand thanks.
  18. The Following User Says Thank You to junkfreak for This Post:
  19. #11
    1,159
    ok how much was all of that worth?
  20. #12
    Mar 2014
    Baltimore md.
    987
    3,114
    [QUOTE=Focker;230127]ok how much was all of that worth?[/QUOTE
    I did not include prices as they will depend on market conditions, location and buyers grading .
  21. #13
    1,159
    what is your estimate of what that stuffs worth?
  22. #14
    Mar 2014
    Baltimore md.
    987
    3,114
    Quote Originally Posted by Focker View Post
    Not trying to dodge your question but it's worth more than a rusted out broken Xbox . I'm going to further breakdown the cd/DVD drive and hard drive here in this thread . The pictures should give you a good idea what's what . It's also hard for me to give a estimate on this breakdown thread because not all of the items have enough substantial weight to register on this scale . If I were to break down 10 it would be a easier calculation on material and I could simply divide by the number of units . I will continue to provide weights and pictures , hope my next post in this thread helps clarify some of your questions .
    I would guess at this point $2.32. Upon full breakdown I think we can double that . The cd/DVD drive and hard drive have boards , we can get the hard drive down to cast . There is some copper coil aluminum and transformer on the power board .
  23. #15
    Mar 2014
    Baltimore md.
    987
    3,114
    Here is the dvd drive , remove the four screws holding on the cover with a Phillips head screw driver.
    Remove the top board , should pop out . There is also a few motors inside , be sure to check for a disk . I'm not removing the other components , I will put the top back on at this point on its way to the shred pile .
    Onto the hard drive .
  24. #16
    Mar 2014
    Baltimore md.
    987
    3,114
    Using a t8 tore bit remove the screws holding the board on .
    Flip it over and remove the 7 screws holding on the cover .
    Nothing special to these , just like computer components , just wanted to add the info to assist anyone tearing one down for the first time . I get the the hard drive down to cast aluminum and save the magnets and aluminum platters . Here is a picture of everything , sorry it's so dark baby fell asleep before I could snap the last pic .
    Some of the dvd/cd drives you may encounter have 2 recessed screws holding them together . Just as easy to dismantle . Hope this helps and feel free to pm me with any video game related questions or to request another break down if you have one in mind .
  25. The Following 2 Users say Thank You for This Post by Metalbestos:
    1. This thead is a question - Scrapping a Dukane phone console?
      By bscrapper in forum General Electronics Recycling
      Last Post: 09-03-2013, 05:04 PM
    2. Record Player console
      By caseter in forum Scrap Metal Questions and Answers
      Last Post: 02-12-2013, 01:07 AM
    3. Game console values?
      By ScruffyJoe in forum General Electronics Recycling
      Last Post: 11-16-2012, 07:58 PM
