Results 1 to 20 of 37
todays com wire experment.
| Scrap Metal Tips and Advice
    EcoSafe started this thread.
    weighed out 10 # of computer wire including ribbon. and chemicaly stripped it to find the difference in weight, and profit potential.
    I get .40 for com wire
    I get $3 for #2
    I ended up with 2.7 lbs of #2 out of 10 lb of com wire.
    10 lb x .40 = $4
    2.7 x $3 = $8.10 or a $4.10 gain
    now to find an econimical way to strip it.
    don't like burning and MEK is $18.00 a gallon. go to work folks lets figgure this out.
  2. The Following 4 Users say Thank You for This Post by EcoSafe:
    billygoat's Avatar
    630
    99
    Since computer wire is tinned, did it separate the copper from everything else?
    2,416
    667
    granulator
    If you burned it you would lose some because it will crystalize. Now I was thinking if you built a fire AND SAY A 5 GALLION TIN BUCKET with hot water from the house put the bucket on the fire put a old Grill grate over the fire and let the steam do the work for you Use some good gloves and pull the insulation off that may work.
    Interesting. I've got a big heavy grate I was told was a welding table out on the #1 iron pile. I've got four totes full of various wire I thought is too small for stripping, including computer wire. I think I've still got a copper kettle that should work as well and several cords of wood that's cut/split and dried. I'll have to give this a try but I'll have to wait for a couple weeks till some of the stuff is unburied from the snow.
    Dunemaul's Avatar
    East Orlando FL
    1,064
    157
    How many times can you use a batch of MEK? And could you outline the process vaguely? might have to get a few 50 gallon drums and the right container and do it in decent size batches....preferably using the same solution and just removing the waste to create more room as you go.
    Victor's Avatar
    Vegas via Canton Ohio
    169
    Not trying to start anything but:
    Burning = enviromentally bad
    MEK = turns brain into swiss cheese over time
    Sell it as is and put your time into increasing your working capitol in better ways
  8. The Following 3 Users say Thank You for This Post by Victor:
    granulator. hoo hoo hoo hoo hoo ha ha ha ha ha thanks for the thought tho ):< }
    Victor it was a one time experment. MEK is not practicle @ 18 bucks a gallon.
    I have read something about a lye mix some where I will try to find it.
  10. The Following 4 Users say Thank You for This Post by EcoSafe:
    I have tried the boiling thing it works but not very well.
    Otto's Avatar
    Ottawa, Ontario
    335
    494
    Safety
    Before a bunch of people run out to get some MEK, read the following wikipedia entry - especially the Safety section. It also may bring some unwanted attention from drug enforcement folks.
    http://en.wikipedia.org/wiki/Butanone
  13. The Following User Says Thank You to Otto for This Post:
    2,416
    667
    Yeah that would work how much a Granulator cost?
    here is one for sale. http://www.ebay.com/itm/C1-Copper-Wi...item2a10519bc4
    just 65k
  15. The Following 2 Users say Thank You for This Post by parrothead:
  16. #11
    let me be clear about this, I did not nor do I reccomend using MEK, IT WAS A ONE TIME EXPERMENT AS STATED. becides as I also stated MEK is not practicle because of the cost.
    Im thinking an old smoker, with a chimney, then two five gallon buckets filled with granulated charcoal to get the crap out of the smoke. any Ideas on this ?
  18. #13
    Charcoal Same as Coal same thing Obama wants to shut down as a matter of fact in NY they going to shut 4 plants down in NY this year and they have scrubbers in them.
    One thing I always said I know everybody disagrees But everything and I mean everything that was ever made has come from the ground.
    If I may extend that thought: polution is just material that is out of place. put it back where it belongs.
    Back on topic: how about soaking wire in old oil?? Mike.
  19. The Following User Says Thank You to miked for This Post:
  20. #14
    directrecycle's Avatar
    520
    95
    find a new buyer
    were getting .85 for #3 insulated
  21. #15
    where do you live dr ?
  22. #16
    520
    95
    mid michigan
    old dude ... i dont know how far it is for you but arcoa in orlando is buying mixed computer wire for .86 / lb
  23. The Following User Says Thank You to directrecycle for This Post:
  24. #17
    ste. gen missouri
    278
    112
    My yard gives me 1.00 for insulated and doesnt differentiate between different grades. Guess im lucky. turned in 180 lbs of computer and appliance wire tues @ that price.
  25. #18
    I've wondered about using MEK to dissolve the glue on TV yokes.
  26. #19
    Hammer's faster,,,
  27. The Following User Says Thank You to Mechanic688 for This Post:
  28. #20
    3,400
    1,004
    We use to use MEK when I was in the airforce to strip the paint off of the airplane. Man that stuff worked awesome. Does it turn the rubber insulation into a goop like it use to do to the paint?
    1. Todays pickup
      By wescrapmetal in forum A Day in the Life of a Scrapper
      Last Post: 04-12-2012, 07:21 PM
    2. Todays booty!
      By thirsty in forum A Day in the Life of a Scrapper
      Last Post: 02-26-2012, 11:03 AM
    3. sort, cleanup and experment day today.
      Last Post: 11-06-2011, 10:06 PM
    4. Todays finds
      By wavecrazed in forum A Day in the Life of a Scrapper
      Last Post: 10-11-2011, 01:09 PM
    5. Todays Load!
      By Changeme9a in forum A Day in the Life of a Scrapper
      Last Post: 07-28-2011, 09:37 PM
