Results 1 to 15 of 15
Identifying Aluminum & Stainless Steel
| Scrap Metal Identification
    Meadowview started this thread.
    Oct 2010
    24
    I have a big old hunk of what I think is stainless steel in the form of swimming pool stairs. I thought I would try to apply the grinder spark test to confirm that it is stainless. The problem is that the amount of sparks created is very little and less than I would see with regular steel. I have to look very hard to see them. Is this normal for stainless?
    I tested some material I know is aluminum and could see no sparks at all. So I have reached the following preliminary conclusion regarding the grinder test:
    Regular steel = lots of sparks
    Stainless steel = just a few small sparks
    Aluminum = no sparks at all
    Is this right?
    Thanks!
    4,758
    6,037
  3. The Following User Says Thank You to hobo finds for This Post:
    Basically, yes.
    47
    I have found that Aluminum is very light in comparison to stainless steel so its pretty simple for the most part..
    165
    23
    All you could need when it comes to the spark test.
    I never have really had a problem seeing sparks off of stainless steel. I don't consider it normal, and you should check to be sure of the type of alloy you have. If you were outside in bright sunlight, but if you were in a normal lit space it should be clear.
    It wouldn't surprise me if the pool latter is 316 stainless steel, because a pool latter is constantly in a chlorine environment, and so it needs the chlorine fighting Molybdenum of 316 stainless, aka Marine Stainless. At my yard 316SS pays $1.30 per pound, so it is worth checking out if your yard does the same.
  7. The Following User Says Thank You to TheMetalizer for This Post:
    Quote Originally Posted by TheIrrationalist View Post
    I'm tearing down some restaurant equipment. I cut a panel off and on the other side it said it's 316. How do I know what the other stuff is?
    Yard said he'd give me 80 cents/lb. If you're getting 1.30, I am thinking I should look around some more.
    Oct 2010
    24
    Thanks to everyone for your help!
    165
    23
    Yeah, thats probably a good idea. I'm getting 80¢ per pound for 304.
    jeb1212's Avatar
    Suburban Philly
    72
    Thanks for that post.
    Last year I sold a pool ladder as 304 stainless. I didn't even consider that it might be 316 stainless.
    Don't know if I'll ever come across another pool ladder.
    Youngtown,Arizona
    38
    47
    pool acid is a good tester. put a drop on metal, if it bubbles its aluminum, if not, its stainless.
  13. The Following User Says Thank You to trashman for This Post:
    165
    23
    Quote Originally Posted by trashman View Post
    Pool acid works as it is Hydrochloric acid. But for a more available source of Hydrochloric acid, I buy concentrated cement cleaner: Its usually a few dollars cheaper, and it can be found year round. Pool acid is only a seasonal item here. Read the ingredients to be sure of what you are buying.
    andyheim's Avatar
    Feb 2015
    North Jersey
    123
    88
    What are the different types of stainless steel and how do you tell them apart? Im sure there is a different thread for this but couldnt find it. Any help appreciated.
    Quote Originally Posted by andyheim View Post
    Stainless Steel Information Knowledge | 18-8 | 304 | 316
  17. The Following 3 Users say Thank You for This Post by Mechanic688:
    Sep 2013
    95
    The easiest way to tell is the gouging. Scrape it on some rough concrete or find a good tool to make some scrapes...Al gouges much deeper...SS is not as deep and much finer width scratches.
    JnJunk's Avatar
    Oct 2014
    188
    34
    I notice that when I hit stainless with a grinder they seem to be finer "lighter" sparks (if you will) than normal steel
    1. Is it Stainless Steel, Chrome-plated Brass or Aluminum?
      By Mick in forum Scrap Metal Tips and Advice
      Last Post: 09-26-2014, 09:12 AM
    2. Is it Stainless Steel or Aluminum?
      By Mick in forum Scrap Metal Questions and Answers
      Last Post: 08-16-2012, 08:21 AM
    3. Tool for identifying stainless steel and aluminum
      By wayne1956 in forum Scrap Metal Identification
      Last Post: 07-02-2011, 08:03 PM
Tags for this Thread
