So I have a lot of motherboards that have gold plated CPU's soldered on. I removed the onces that could be removed, and now I am left with a high grade board...what can I expect these to be worth?
Not CPU's...but a lot of pins.
The board on the left above and the one on the top below: they are very heavy and seem to have 2 gigantic gold plated pins on the one side.
Also, on occasion, I come accross what seems to be slot processors, but bigger. They have a CPU soldered to them, but its not the type of CPU that I would go crazy over. Here's an example:
So, in this case, I guess if I remove the bracket...I could get slot processor grade for it, correct? In the situation where it is on a motherboard (and not a small card) what could I expect for that? Server grade? What if it is on a dual socket board already...server grade still?
Thanks!
