Results 1 to 20 of 25
    wdaddy started this thread.
    224
    More money from Hard Drives - Data recovery boards
    OK... Thought it was time to share another little gem here.
    If you are contracted to destroy all hard drives you get in and do not have permission to sell them as working drives (which would be the better option), consider testing and then selling the printed circuit boards for data recovery.
    You can get from $10-$50 for these boards, depending on how rare they are and who is looking for them. If you get newer drives or server drives you will be able to sell the boards for good money. Put them on Ebay and see what happens... that is, if you have some of your free listings left.
    It will be very hit or miss... but it may be worth it.
  2. The Following 2 Users say Thank You for This Post by wdaddy:
    AuburnEwaste's Avatar
    Metro Detroit
    773
    32
    You might also be selling them to people who are using them for illegal purposes. Be careful.
    224
    Explain that? How would they use a recycled pc board illegally? Not that it bothers me that you said that, just strange concept to me.... that's all.
    Metro Detroit
    773
    32
    To recover information from a hard drive... Isn't the reason for destroying them to ensure that nobody can recover any data from them? Someone who knows what they are doing could potentially recover sensitive information.
    Metro Detroit
    773
    32
    I'm not saying we should be paranoid but the potential is there.
    directrecycle's Avatar
    520
    95
    no info is stored on the board, only the disk inside
    6,815
    It's common practice to change a HD board in efforts to retrieve data. There are many bonafide companies who charge absorbitive rates to do so. Last I checked rates for this sevice(several years ago) a basic charge was in the $800-$1000 range. If you are not restricted in reusing the complete drive, old drives can be sought after for just this purpose (if they are hard enough to come by), it just depends on what drive they are attempting to repair, and which parts they need to do so. You will however, find more drive failures are due to mechanical malfunction by far, than are due to a bad board.
    224
    Yeah, the data is on the platters and the platters should be physically destroyed... no data on the pcbs...
    I have repaired 2 that had the boards fry and we used a donor drive to get them up and running... about the only repair you can do without opening them. I have tried a platter swap and had very bad results. We have sent drives into recovery shops and spent over $2000 for the service...
    The best bet you will have with these are newer drives... like 100GB or better... it's a shame killing drives like that...
    Jeremiah's Avatar
    Virginia
    437
    147
    I believe this is incorrect. Most hard-drive PCBs have between 2mb-16mb of memory stored in a cashe. 2mb is nothing in terms of pictures, vid, etc, but is plenty of space for documents containing SSN, credit cards, etc. If what i said is correct, than information could be accessed via the pcb. I always drill a hole in them before recycling. Here is a link that may help http://www.ehow.com/facts_5137741_cache-hard-drive.html
    Metro Detroit
    773
    32
    I'm not talking about taking information off the PCB. I meant they could use it to recover information from another drive with it. I didn't mean to cause a fuss about it, just something to think about.
    Jeremiah's Avatar
    Virginia
    437
    147
    No fuss here. I would just caution the OP from selling HD PCB's from drives they promised to destroy the infromation from within. More than likely nothing would ever come of it. But when dealing with information one needs to hedge from liability.
  13. #12
    jghilino's Avatar
    KANSAS CITY
    2,672
    1,429
    my 44 magnum works every time on these, puts a nice big hole thru all of the platters
  14. #13
    6,815
    Quote Originally Posted by Jeremiah View Post
    I believe this is incorrect. Most hard-drive PCBs have between 2mb-16mb of memory stored in a cashe. 2mb is nothing in terms of pictures, vid, etc, but is plenty of space for documents containing SSN, credit cards, etc. If what i said is correct, than information could be accessed via the pcb. I always drill a hole in them before recycling. Here is a link that may help What Is a Cache on a Hard Drive? | eHow.com
    Trying to recover data from a HD buffer would equal trying to remove information from a stick of RAM. Both are emptied with each power down. This is why in a system crash everything you'd been writing is lost, due to it having been stored in RAM (either on the main boards RAM or the HDs RAM makes no difference), it's gone.
  15. The Following 3 Users say Thank You for This Post by Bear:
  16. #14
    York, PA
    45
    19
    Correct...if there is a residual data left in memory on power down (like a ghost stuck in time), it is totally gone when renergized on power up in my opinion. So, maybe CIA or FBI could do something, but I doubt if a random drive from a random unknown sorce would have money thrown at it to see if they had a SSN that had good credit or a bank account that had money in it. But, the chance is there. Technally a platter with a hole on it still has 95% of its data on it. THey might not spin up, but you can extract the data from it by pulling a magnetic image of what is left. That would cost a lot, but the chance is there.
    I hope I am not sounding smarty pants, but I am trying to indicate the statistics behind data destruction. Plus I had a kinda crappy day, so sorry.
    Pulling the control board and deguassing, or shredding is the best bet for data destruction. It leaves the most useless or unpredictable intact remaining data. Also, software triple write stuff if you think it has a resale value.
  17. The Following 2 Users say Thank You for This Post by Whm1:
    224
    Hmmm... From what I remember, volatile hard disk drive cache is used as a buffer. Without being powered up this will be empty. Non-Volatile memory on the hard drive board tells the board how to read that platters... this info is locked in and can't be overwritten without knowing what you are doing and it doesn't hold any user data... just machine code... just like the bios on the motherboard.
    I am contracted to destroy hard drives, first I do a wipe on the drive, then I disassemble them, then I degauss the platters, and finally I shear the platters into at least 4 parts. All the platters are mixed together in a tote and taken in for aluminum scrap... Yes, if someone could find all the parts of the platters and study them under an electron microscope, and they can reverse all the other things I do, they may be able to pull data... but not likely. I have no worries about the PC boards leaking anything...
    If a data thief were to gain access to personal data with my boards it wouldn't be because of anything I did, it would be because of the person who thought all they had to do was pull the pc board off a drive to make it secure. That would be a very bad practice. I hope no one here does that and thinks it's sufficient... at least hit the drive with a sledge if you don't want to open them... just to screw up the bearings and bend the platters...
  19. #16
    Rochester NY
    615
    19
    Quote Originally Posted by wdaddy View Post
    Hmmm... From what remember is volatile hard disk drive cache system is used as a buffer. Without being powered up this will be empty. Non-Volatile memory on the hard drive board tells the board how to read that platters... this info is locked in and can't be overwritten without knowing what you are doing and it doesn't hold any user data... just machine code... just like the bios on the motherboard.
    You are going way over board and wasting time and money. With todays technology a single deep level wipe is enough to erase all data on a hard drive permanently as long as all sectors were written over. Because data on drives is so condensed even using an electron microscope data will be almost impossible to recover (cost prohibitive).
    The current DOD specs have not been updated since the 80's when this type of recover was possible. On magnetic tapes and smaller drives.
    Degassing the platters isn't necessary if you sheer them. Neither is sheering them if you Degas them.
    Simply taking the drives apart and either sheering or degassing is more that enough to destroy the data beyond recovery. Hell your finger prints on the patter are enough to destroy the data beyond readability with out FBI/NSA level equipment and your every day identity thief will not have access to the millions for that equipment, the knowledge of how to use it or access to the labs at the FBI/NSA.
    http://reclaimtech.com/
    We pay you to recycle!
  20. #17
    What are you using to shear the platters ?
  21. #18
    224
    Hospitals and clinics want to make sure... so yep, it's overkill. Enough to satisfy Hipaa.
    I use a bench mounted metal shear to cut them. It goes through them very easily. Also works good on your gold fingers and ide cables.
    Like this
    http://www.ebay.com/itm/Northern-Ind...item4d04693366
  22. #19
    3,436
    Maybe a stupid question but want to make sure what I am doing is ok. I hit the hd with a ballpein cracking the alum case and breaking part of the platter. Then I take a chunk of the platter and throw in my alum bucket and then turn in the hd to my buyer. I do this so I am not losing too much weight from the hd. By doing this am I doing enough to ensure that the platter is made unreadable because of the missing piece? I don't get a large volume of hd's when I get towers and servers so this is the quickest way for me to ensure that the hd's are unreadable.
  23. #20
    jghilino's Avatar
    KANSAS CITY
    2,672
    1,429
    arnt there companies out there that shred drives that would pay you for them or take them for free, they have to be making a killing on the scrap hard drive boards plus all the aluminum and stainless they generate? i would have a few guys tearing boards off and another one feeding the shredder
    1. Hard Drives: what do you do?
      By Ecycle Atlanta in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 12-26-2014, 07:31 PM
    2. Hard Drive Erase Software. Requirements For Selling Hard Drives
      Last Post: 08-23-2013, 04:30 AM
    3. hard drives
      By asandahl in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 11-17-2012, 06:18 PM
    4. Scrapping Hard Drives/cd/dvd drives?
      By dustmuffin in forum A Day in the Life of a Scrapper
      Last Post: 06-13-2011, 09:41 AM
