Results 1 to 9 of 9
Aluminum capped ceramic CPU's
| Computer Recycling
    Victor started this thread.
    Victor's Avatar
    Vegas via Canton Ohio
    169
    Any good tips on popping that aluminum cap off? I've popped a few that weren't glued very well just using a small flat blade screwdriver. A few others are on so good I am cracking the corners off the chip and they are still glued tight. Didn't want to heat them for fear of turning the ceramic brittle.
    3,436
    Try a sharp wood chisel. Can you post a pic of the chip u are working with. Are you using a torch or a heat gun?
    6,123
    11,885
    I'd like to know to, I had some I believe that were Green fiber with the alum cap on top. Bloody thing wouldn't come off with a screwdriver, wood chisel..feh. I finally just got fed up with the lot of them, an said to he ll with it. Lose a couple bucks but better then wasting time an patience on the things. I lack a access to a heat gun, etc. Now those KMD ones..the cap popped right on off with minimum fuss.
    Sirscrapalot - If a croc loses a tooth while hunting, it'll grow back. - Nat. Geographic website.
    6,815
    i lay em agin a door stop and pop em off with a hammer and chisel. Turn the bevel on the chisel down and you'll have just the right angle to pop it off with ease
    6,123
    11,885
    Not doubting you Bear, or BC but the ones I had..didn't want to come off. Hope it works better for Victor then it did me.
    Sirscrapalot - I sometimes talk to my tools, it's when they talk back I get worried.
    Jun 2013
    Toledo, Ohio
    550
    551
    This might be a little out there but maybe you could heat up a junk knife and go between the cpu and the heatsink
  7. The Following 2 Users say Thank You for This Post by scrapping4ever:
    CA
    145
    881
    I use a razor knife to cut the glue and it just pops right off ill post a vid later it goes rather quick and smooth.
    2,416
    667
    If you remove them, touch them to a grinder. I think some are copper. I could be wrong.
  10. The Following User Says Thank You to parrothead for This Post:
    CA
    145
    881
    The ones on the green fibers are copper and have good weight to them.
  12. The Following User Says Thank You to unitsngold for This Post:
    1. Home Made Aluminum Car Plaques - Casting from Aluminum Cans
      By losthope in forum A Day in the Life of a Scrapper
      Last Post: 06-15-2013, 06:18 PM
    2. Telecom boards with gold-capped CPU's on board Value?
      By Pnutfarmer in forum E-Waste Grading and Identification
      Last Post: 06-05-2013, 12:52 PM
    3. Ceramic cpu
      By Jonniebrass in forum General Electronics Recycling
      Last Post: 11-14-2012, 07:03 PM
