Results 1 to 20 of 35
Cutting power supply wires
| Computer Recycling
    Riverside started this thread.
    CT
    14
    I was looking for a tool to cut power supply wires without spending a lot of money.
    Here is what I found:
    Finger Release Ratcheting PVC Cutter
    It does not always cut all the way thru due to it's design but a few twists usually seems to cut the stragglers.
    3,419
    Straight tin snips are ok, two snips and its off. I also use a small set of cable cutters which are really good.
    https://www.google.com/search?q=klei...22799152420380
    The high leverag ones for $26
    AuburnEwaste's Avatar
    Metro Detroit
    773
    31
    Everyone should do a cost/benefit analysis on cutting the wires off. It sounds crazy, but you are loosing money cutting them.
  4. The Following 2 Users say Thank You for This Post by AuburnEwaste:
    When I was doing a bunch at a time I used a limb trimmer or lopper as their also called. Very quick to lop all wires at once.
    jimicrk's Avatar
    Sep 2013
    Tennessee
    2,804
    2,902
    Yes the high leverage cutters are a good investment. I've had the same ones for almost 20 years and they work as well now as when I bought them.
    Full article at Scrap Metal Forum: http://www.scrapmetalforum.com/compu...#ixzz3DEpSSdjB
    That might be true for you but it's not for everybody. Power supplies here sell for 10 cents a pound with or without wire. Same as shred, motors and transformers. Same as the low grade board inside them. Sucks. I process a lot of PC's and I don't have the time to remove the power supplies and process them. I don't even remove the power supplies anymore. Cut the wires, remove the mother board and gold finger boards, fill the PC case with any scrap metal I have, put the cover back on and move on to the next one.
  7. The Following 2 Users say Thank You for This Post by jimicrk:
    3,419
    Depends on what you get for wire. Ps without wire i get .20#. The wire I sell at romex pricing1.25-1,30#
  9. The Following 3 Users say Thank You for This Post by BRASSCATCHER:
    ryanw's Avatar
    TX
    1,317
    535
    The best tool for cutting PS wires I have found so far is one of these:
    https://www.google.com/search?q=repl...2F%3B550%3B411
    I don't have one of those exactly, but a home depot husky brand one. Blade lasts a long time if you're just cutting PS wire. Slices through it like it was butter, and can easily handle the base of the bundle in one clip.
  11. The Following 5 Users say Thank You for This Post by ryanw:
    4,918
    15,581
    Angle grinder is what I have used in the past. Its quick and easy. Mike
  13. The Following 2 Users say Thank You for This Post by miked:
    Chesaning
    472
    24
    Definitely losing money cutting them
    Metro Detroit
    773
    31
    The wire portion weighs so little that the extra money you get from the wire is not enough to cover what you loose from not having the wire attached. In the case where the local yard only pays 10 cents per pound, you may come out a little bit ahead. You still have to account for the labor involved.
  16. #11
    CA
    145
    871
    At 1.40# there's not much to lose especially if you wait till you have a nice gaylord full and do them all at once.
    Here is a quick breakdown of 5 random power supply's I cut the wires from. I'm not the best at math late at night so I might be off a little.
    Ps #1- 10.4 oz
    Ps#2- 6.6 oz
    Ps#3- 7.0 oz
    Ps#4- 5.4oz
    Ps#5- 8.2oz
    Total weight 2.35#. I'm rounding down so at $1.40#. That is $2.80. For 5 random ps. I did those 5 in 1 min which is not very fast. But say you do 5 a minute for an hr you will have done 300 ps
    Now 300 divided by 5 is 60 times $2.80 is $168.00 an hr and that's rounding down.
    Now let's say you only get half which is 0.70# you still make $84.00 an hr
    I don't know about you but i sure wouldn't mind making that an hr.
    Oh and at $1.40# with 300 I could pay someone to help and still make money.
    And yes it would be hard to do 300 hr anyways you get my point for me it's well worth cutting the wires off.
  17. The Following 4 Users say Thank You for This Post by unitsngold:
    kcscrapper is offline Metal Recycling Entrepreneur
    585
    76
    I keep my power supplies for when I have slow days. But I break them all the way down.
    4,978
    1,244
    I am currently getting .16/lb locally and that price has fallen from .20/lb in the last two years over time.......THey don't care if I cut the wire they pay the same.......They don't do a lot of ewaste anymore at this company so I'm glad they are still giving me a little better than shred for these........They are paying .11/lb for shred so I just include a couple of totes of these everytime I go dump shred......Makes it worth the 20 mile round trip as there is a yard a lot closer but they don't buy the power supplies..........And yes I try to cut the majority of the wire off and am getting .80/lb for that so it is worth it to me
  20. The Following 3 Users say Thank You for This Post by mikeinreco:
  21. #14
    jimicrk's Avatar
    Sep 2013
    Tennessee
    2,804
    2,902
    It all depends on where you live and how much your yard is paying.
  22. The Following 3 Users say Thank You for This Post by jimicrk:
  23. #15
    May 2014
    New Brunswick, Canada
    346
    206
    I use bolt cutters for mine, can cut through all the wires in one cut
  24. #16
    1956's Avatar
    Fort lauderdale FL The Venice of The USA
    642
    399
    Well this is a important question for me as I am getting a lot of power supply's, it's Sunday and I am home so I can't do the numbers, but like a few guys say you are losing money cutting the wires and I believe them to be right, Now for the guys that sell to a yard that does not pay you more for the wires on or off same price, it's just common sense to snip the wires basically because the value of the wire is more that the power supply, but has any one done a comparison of getting 20 assorted power supply's weighing them with the wire on and then cut the wire off and done the numbers, I will do this tomorrow just for my own knowledge, you have to use twenty to get a true a picture.
  25. The Following User Says Thank You to 1956 for This Post:
  26. #17
    3,419
    Quote Originally Posted by ResourcefulRecycling View Post
    Not true, as was stated numerous times it all depends on what pricing you are getting. Anything over $1 a pound for the wire makes it worth it to take 30 seconds to cut the wire. It is on a rare occasion when I am backed up with other things that I sell them with the wire for a nickle more per pound.
  27. The Following 2 Users say Thank You for This Post by BRASSCATCHER:
  28. #18
    I use 12" or 18" bolt cutters...kinda awkward at first but it gets pretty smooth going before long
  29. #19
    MattyNoNeck's Avatar
    May 2014
    Upstate NY
    345
    140
    The yard I take mine to buys them as steel-cased batteries (Yes, that was my reaction too) with or without the wires so I snip them. I haven’t brought in the computer wire to a yard yet but I may throw them in with my next batch of low-grade wire. I don’t think the place I bring my insulated COPPER wire will take it but I’ll have to see.
    The power supply wire is usually not copper, correct? Or am I confusing myself?
    "Don't try to be a great man, just be a man. Let history make its own judgments"
  30. #20
    MattInTheHat's Avatar
    rock hill, sc
    1,464
    1,140
    power supply wire is generally tin coated copper. easily confused with aluminum if you are not looking closely. if you strip it, it should be #2 copper.
  31. The Following User Says Thank You to MattInTheHat for This Post:
    1. Uninterruptible power supply
      By Scrapette in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 12-26-2013, 10:56 AM
    2. This thead is a question - Power Supply Value
      By WolfredBromley in forum Scrap Metal Questions and Answers
      Last Post: 08-27-2013, 01:48 PM
    3. Anyone Use A Power Supply Tester?
      Last Post: 05-26-2013, 01:15 PM
    4. computer power supply
      By ozzy214 in forum General Electronics Recycling
      Last Post: 04-24-2012, 11:52 PM
