Results 1 to 19 of 19
other boards
| Computer Recycling
    Scrapette started this thread.
    Scrapette's Avatar
    Kentucky USA
    942
    2,392
    other boards
    I know computer boards, satellite and cable box boards are usually high grade, but what about boards from miscellaneous household consumer items like radios, heaters, fax machines and printers. Are they worth keeping? Thanks.
    195
    10
    It really depends on what is on the boards... generally if the board is green on both sides and has a bunch of Integrated Circuit (IC) chips on it, or Flat Pack chips, it is probably worth saving. The value probably falls between about 1/2 the value of motherboards as a peripheral board, or closer to the full motherboard value depending on the chips. If it only has a few of these chips and is mostly other stuff it may qualify as mid-grade board and be worth about $.50/lb
    IC Chips
    Flat pack chips:
  3. The Following 7 Users say Thank You for This Post by bjybjy:
    Scrapette's Avatar
    Kentucky USA
    942
    2,392
    Quote Originally Posted by bjybjy View Post
    IC Chips
    Flat pack chips:
    Thanks for that info. They don't seem to have many chips and some are very old with all kinds of doodads on them. And many are brown -should I just pitch them?
    Low grade prices run anywhere from .05 lb to about ,15 lb.
  6. The Following User Says Thank You to Mechanic688 for This Post:
    wavecrazed's Avatar
    219
    Are those round holes gold plated?
    195
    10
    The low grade brown boards I will rip all the good stuff off like transformers (sell for same as motors), aluminum heat sinks, wire, etc, then the rest of the board goes in with my shred.
  9. The Following User Says Thank You to bjybjy for This Post:
    195
    10
    Quote Originally Posted by Scrapette View Post
    Also the easiest thing is to post a quick picture and you'll get a definate answer.
    Filthy's Avatar
    Northern New Jersey
    780
    850
    Quote Originally Posted by wavecrazed View Post
    yeah, are they? that would make me think twice before mixing it in with brown board or pulling the IC's
    We're the renegades of Junk!
  12. The Following 2 Users say Thank You for This Post by Filthy:
    Scrapette's Avatar
    Kentucky USA
    942
    2,392
    Thanks, still working on that picture thing.
    This might help, I don't know,,,
  15. The Following 3 Users say Thank You for This Post by Mechanic688:
  16. #11
    Aug 2013
    38
    21
    what if the boards are broken or in pieces do you loose out? I am new and this is hard to keep all these things sorted. I almost need a laminated picture to tape to the box. So if its green on both sides its worth more, and if its full of chips its worth less but not as little as tv boards? Where can I drop off in Maine or ship to get best prices for low grade, I have a 55 gallon trash can full?
    jeremy
    Quote Originally Posted by purenergypro View Post
    jeremy
    There's at least one scrap yard in Portland buying eWaste and another in NH. You'll need more than one 55 gallon can to be worth it, though. Call around for prices before settling on a yard. Read the electronics recycling section, You won't become proficient in grading overnight but you'll get good information to get started.
  18. The Following 2 Users say Thank You for This Post by Mick:
    Alabama
    764
    1,067
    Scrapette- The printer, fax, some telephone, and some tv (usually the new stuff) will be worth separating from low grade. The heater, most tv, vcr, stereo, radio are usually not. Mechanic's picture of low grade is a good example of those. However, there are exceptions to almost every rule. There are high grade boards in some of the newer TV's that can even have a DLP chip like a CPU that brings good money per lb. There are really good but small thin boards around the edges of flat screens. Don't forget modems and game consoles (xbox, playstation, etc). Those usually are motherboard grade and some of them even have a hard drive in them. I even found a microwave oven that had a nice gold board for the keypad, all the places where the buttons touched were gold. The more you tear apart, the more you'll learn about it. Even boards that don't have visible gold will have good value if they are packed with chips.
  20. The Following User Says Thank You to Pnutfarmer for This Post:
  21. #14
    Cincinnati, Ohio
    285
    271
    From the pieces that I've taken apart, I don't think I've ever seen a "good" board in a radio or heater or fans or dehumidifiers or other electronic controlled appliance. Sometimes a bigger radio might have a heavy transformer in them or some other copper coils/chokes, but the boards are usually pretty much junk.
    Fax machines and the "all in one" type printers (with the scanners built on) sure do have good stuff in them sometimes. Definitely worth a look, IMO.
  22. #15
    Alabama
    764
    1,067
    Wow, I gotta read the date on the original posts!! I bet Scrapette knows all that and more by now.
    Purenergypro- It usually won't matter if the boards are broken, but it's safer to ask the buyer.
  23. The Following User Says Thank You to Pnutfarmer for This Post:
  24. #16
    Quote Originally Posted by Pnutfarmer View Post
    I know my yard will take them anyway you bring them in, just don't crush them on purpose.
  25. #17
    Aug 2013
    38
    21
    i downloaded iscrap.com application for my cell phone. that helps alot. I also met with chris today, nice guy in Windham told me more about things.
  26. #18
    Aug 2013
    38
    21
    they got pulled apart when removing aluminum heat sinks and other metal.
  27. #19
    pcscrapper's Avatar
    623 s Lyon st Suite 200 Sioux Falls SD 57104
    657
    576
    we are buying low grade at this time for 20 ship. per pound.
    only this month.. I've a supplier that needs a few thousand pounds.
    Please Add Us On FaceBook, PC SCRAPPER Sioux Falls SD
    also our Prices are listed here http://pcscrapperS.com
    PC Scrappers LLC
    623 S LYON ST SUUTE 200Sioux Falls, SD 57104
    1-605-271-2616
    1. Help me out on these boards please.
      By illete in forum More than Scrap Value
      Last Post: 10-12-2012, 03:14 PM
    2. Brown Boards, green boards
      By DESCRAPPER in forum Scrap Metal Questions and Answers
      Last Post: 05-21-2012, 03:13 PM
    3. Hard drive boards & Laptop Boards
      By drozenski in forum Computer Recycling
      Last Post: 09-26-2011, 09:08 AM
