Originally Posted by
Ballymoss
Those long cards are ISA's not PCI.
Higher scrap value than PCI where I come from.
There are about 10 main grades of motherboard scrap..Dose not always mean its worth grading to that point.
We grade our motherboards to 4grades and that's about as far as we take it. Going beyound that and you have to many gaylords taking up alot of floor space...alot of errors going into the wrong box when tossing things where they need to go and so many other factors.
Back (not all that long ago) they HAD to be graded on the "long" grade as I like to call it because the AMOUNT of time it took to do all the grading and regrading and ect. But over time and since the rise of gold the grading has become more slack and faster to do as the refiners want more scrap faster and not caring as much as grade...so prices have been adjusted to the fact that pci and isa boards are now mix.
In short...if you grade your PCI cards and ISA boards out and fill a gaylord of each..you will get less on your PCI but get a little more for the ISA....when in fact you could of gotten just about the same as a mix load that you did not need to spend the time in grading and you can sell sooner as you don't have to fill the whole box....hope this is easy to understand...its late and i'm pretty sleepy but you get the jest
