Results 1 to 20 of 23
torx bits
| Tools and Equipment
    RSComputer started this thread.
    New Mexico
    43
    80
    torx bits
    This question is mainly geared to the escrappers. I'm not sure about you guys but I go through the t7 torq bits like nothing tearing apart hard drives. Does anyone have a good brand or supplier of these? Thanks in advance.
  2. The Following 5 Users say Thank You for This Post by RSComputer:
    Eastern Ontario
    294
    139
    Same here. I think its just the nature of it. Using a small precision bit in a drill doing hundreds of screws you're going to tear them up.
  4. The Following 2 Users say Thank You for This Post by devo:
    2,864
    350
    harbor freight
  6. The Following User Says Thank You to happyscraper for This Post:
    Central Florida
    629
    117
    Get the mini screw driver set from harbor freight and go at it manually. Those screw are so short and the hex hole so small I'm not sure your saving much time using a powered tool, and it's probably causing the bits to strip by trying too work fast.
  8. The Following 2 Users say Thank You for This Post by ScrapYaHerd:
    billygoat's Avatar
    630
    99
    harbor freight
    Personally, I only go to Harbor Freight if I want to spend a little less and don't mind inferior tools. I'd rather get a good name brand like Craftsman or Klein Tools, since I know the quality is better and they will last a lot longer than the cheap stuff.
  10. The Following User Says Thank You to billygoat for This Post:
  11. #6
    danielms's Avatar
    mississippi
    133
    71
    dosent harbor freight have a lifetime warranty on hand tools?
  12. The Following User Says Thank You to danielms for This Post:
  13. #7
    18
    You might also consider getting a cheap electric screwdriver. You can get a cheap B&D at walmart for $10-15. Wouldnt have so much force behind it like a drill, but would surley beat doing it by hand.
  14. The Following User Says Thank You to CraigKapo for This Post:
  15. #8
    New Mexico
    43
    80
    Great. I didn't even think about HF. I usually pick up a couple of the combo kits at autozone. With a friends discount they are about 2 bucks a kit. I almost always (not always) go at hard drives by hand. If I'm bored ill break them down all the way. Seems like they mostly strip trying to take the screws that hold the platters down. Thanks for the ideas. I've never used a small driver before. Always used my dewalt drill. I do like that idea though. Will fit in a lot more spaces
  16. The Following User Says Thank You to RSComputer for This Post:
  17. #9
    When I strip the platter screws, I get out the Dremmel and using the thin cutting disc, cut a straight line thru the screw so I can use a small straight screwdriver to back them out. If that does not work then out comes the drill with a bit bigger than the screw, and just drill the tops of the screw off.
  18. The Following 3 Users say Thank You for This Post by Mechanic688:
  19. #10
    18
    Quote Originally Posted by RSComputer View Post
    The kind that can flex the top are usually pretty handy in tight spots. I had one like that for years until it wouldnt take a charge anymore. Now ive got a lithium powered one, and have really liked it so far. Electronic disassembly was my biggest reason for getting one. Often when im working with something small, it just seems almost harder to aim the bit on the end of a drill at a tiny screw.
  20. The Following User Says Thank You to CraigKapo for This Post:
  21. #11
    4,758
    6,037
    I think I am going to get this set... http://www.harborfreight.com/100-pie...set-91310.html
  22. #12
    NorthEast GA
    170
    162
    I like the long sets. I got one on ebay that's also good for late 90s compaq desktops. the only other thing is to avoid the security torx if possible. you are just losing strength in the bit as a result of the recess.
  23. #13
    That is identical to the set I got at Ace hardware on sale, pretty handy but be careful with them as they will strip. Work great with my little drivers
  24. The Following User Says Thank You to Mechanic688 for This Post:
  25. #14
    4,758
    6,037
    Well I got the bit set for a whopping $7.99! Well see how long it lasts!
  26. #15
    I have the same one Hobo and its ok. Harbor freight also carries others that I also bought. My biggest problem is loosing the bits. I'm going to put more of the hd magnets on my workshop wall to keep from loosing them. Mike.
  27. #16
    I picked that set up the other day too Hobo, so far-so good.
  28. #17
    6,815
    radio shack and sears usually have small tools that hold up rather well at a fairly reasonable price
  29. #18
    Those Torx screws are using to hold the Tungsten carbide tips in milling & lathe cutting tools.
    Since Sandvik & Iscar make those tips, they supply the Torx screws & bits too & I'd expect them to be of the highest quality possible.
  30. The Following User Says Thank You to eesakiwi for This Post:
  31. #19
    Victor's Avatar
    Vegas via Canton Ohio
    169
    http://www.wihatools.com/default.htm
    Some of the best made drivers period. You will not be disappointed......
  32. The Following 2 Users say Thank You for This Post by Victor:
  33. #20
    Filthy's Avatar
    Northern New Jersey
    780
    850
    i rip hard drives with hand tools. the bits i have are from some gift set i got from one of my relatives. i have no idea who makes them but they are precision/ tiny torx and they are holding up well as long as i dont put them in a power tool
    We're the renegades of Junk!
    1. what size bits do I need
      By EcoSafe in forum Tools and Equipment
      Last Post: 12-24-2012, 02:13 AM
    2. need star bits
      Last Post: 09-06-2012, 11:36 AM
    3. Replies: 3
      Last Post: 06-24-2012, 10:17 PM
    4. Screwdriver Bits
      By dmm2442 in forum Tools and Equipment
      Last Post: 04-24-2012, 02:31 PM
    5. Philips #0 Bits
      By CLR Solutions in forum Tools and Equipment
      Last Post: 10-10-2011, 07:58 AM
