Originally Posted by
taterjuice
Diesels have a ton of power, thanks to the turbo n/a diesels are helpless. I run gassers and reclaim lots of gas from junk cars. Maintainence is way too expensive for my taste. And as for these claims of 20 mpg I seriously doubt it. Find me a motor that gets 20 mpg while towing a 22 foot gooseneck loaded with 3 ton, it don't exist. I hear this 20 mpg crap from all you cummins guys, I'd like to see hardcore proof of this. How bout this drain out all the diesel and put in 1 gal then see if you make the 20 mile mark.
....damm you..you made me sign on..lmao
Ok there is alot of bad info on diesels but let me point out good and bad, facts and nothing more.
a STOCK Cummings diesel will get 16mpg to 18mpg either empty or loaded will be close to the same.
A NON stock cummings can get well above 20mpg, Mods needed, 5inch no muf or cats (delete pipe) has to be the 5.9 not the newer crap (can do it with the newer ones but takes ALOT more work/mods) water-methanol injection on the air intake as this will help to supper cool the air and the water part of it will turn to steam taking less fuel to have more "bang" and a good programmer that you can tune the truck in (not hard) and you HAVE to put gag's on. The mods here will give you around 23mpg and you will have low EGT's (high EGT will kill a diesel motor fast as hell) if you want to scrap another 1 to 2mpg add another turbo as this will also give you MORE air = power. Having two turbos will drop your EGT even more.
if you want to make a race motor and "blue print" the motor you can add bigger valve springs to make it close tighter and change out the head bolts on the motor before you try to run high boots with the twin turbo's or you will blow the top of your motor off and some other small odds and ends like that.
A well built diesel motor will run for a long time. Also the older 12 valve cummings will run on pure veg oil or motor oil with little to no mods to the truck the 24 valve ones need a few small mods to run that type of fuel.
Bad part about diesel cummings take 12 quarts of oil but this can be burned as fuel (only need to change it every 5k miles tho) higher diesel price but the truck wont let you down when your working...upfront cost on the truck...costs of upgrades but...low repair bills...things DONT brake often.
Best thing about a diesel....park it for 10years...change the batteries find the key and she will start right up....gas motor...good luck as its going to take some work and poking around.
Anyway..I will poke around alittle bit but I have been very busy and about to roll something else out that could very well be 10times bigger than Easy Recycle I have a few meeting to be in this month to get the ground work done.
Hello all the old regs I know.
