this may sound dumd but at my job they through foil like its candy. Can you scraoe that after all it is aluminum and that could be money in the bank
my yard doesn't take it. You need to call the yard's in your area.
Aluminum foil is not aluminum, it's tin foil.
Mine does. It is aluminum indeed, but it is the lowest paying grade aluminum there is, other than alum/steel breakage. Call and see. It take's quite a bit of it to make any real weight, but if it's clean and you can get it in quantity for free at a place you are already going to be anyway, go for it.
While we are on the subject, what catagory does alum pie tins fall under, same as cans?
Nope. You got it bass-ackwards.
At one time, tin foil might've been tin, but today it's generally a misnomer. Tin foil is not tin, it's aluminum:
http://en.wikipedia.org/wiki/Tin_foil
