Results 1 to 9 of 9
got a sweet pick up Friday
| TV and Monitor Recycling
    Chrissm14 started this thread.
    Jan 2014
    Allentown, PA
    57
    A guy called me to pick up a flat screen tv, and when I get there, it's a Westinghouse 46" led tv that looked brand new. I thought the screen would be smashed or something. I didn't ask what was wrong with it, and when I got it home I plugged it in and it works fine. Only thing wrong is the screen is a little dim on the bottom left hand side, anyone know what could cause it or how I could fix it? I haven't gotten a chance to take it apart and look at it yet. I'd I can get it working its going on the wall to replace my 42" lcd
    Also went and to the yard and made $250 the same day. And got some cabinets that I built at work installed in my basement. Finished refinishing my floor in a bedroom, cleaned the lawn mower carb and got the yard mowed, fixed the leaking garden hose, and got rid of the last 6 monitors hogging up space in my basement. I must say it's been a productive weekend
  2. The Following 4 Users say Thank You for This Post by Chrissm14:
    PickerBenny's Avatar
    Erie, PA
    255
    Sounds like a good time. I found a vizio flat screen, but it didnt turn on. The fuse wasnt broken or anything that was fried, so im at a standstill. Good for you bud!
    Watch my scrapping videos on YouTube! Like, Subscribe & Comment! Videos Daily!
    https://www.youtube.com/channel/UCFF...V2NnBiOukrn6Mg
    Quote Originally Posted by PickerBenny View Post
    Here Benny, This forum deals with bad caps. which is a common cause for failure in flat screens and computers, also they have parts kits and mucho info available. If your hands on then this might be a simple fix.
    Badcaps Forums - Salvation For Your Hardware!
    Badcaps.net - Badcaps Home
  5. The Following 3 Users say Thank You for This Post by Mechanic688:
    Mar 2014
    80
    71
    there is a big warning that nobody knows about with flat-screens you aren't supposed to lay them down with the screen facing down this could have been the reason
    Jan 2014
    Allentown, PA
    57
    I just took it apart and the sheets of plastic between the screen and the glass were not flat in that corner they were kind of scrunched up. not sure if I did it while taking it apart, but it happens to be in the corner that isn't working right. I'm putting it back together now, I'll post back with my results
    Rollyrogers33's Avatar
    Columbus, Ohio
    284
    1,493
    Got a 60" LED that was sitting in the trash with the stickers still on the screen. Plugged it and it worked great. Turned around to find a remote in my garage. Started to smell smoke. Turned around and white smoke was pouring out the back.
    "It's not the years, honey, it's the mileage." Indiana Jones - Raiders of the Lost Ark
  9. The Following User Says Thank You to Rollyrogers33 for This Post:
    Jan 2014
    Allentown, PA
    57
    **** probably a short somewhere. just got mine put back together and still the same problem. I'll try it again someday and take it completely apart
    Quote Originally Posted by Rollyrogers33 View Post
    In the CB radio world we would tell them; "Man, you let the factory smoke out of it."
    That was probably a surface mount transistor or IC
  12. The Following User Says Thank You to Mechanic688 for This Post:
    snapperhead's Avatar
    Auckland, NZ
    64
    37
    A couple of months ago, a friend asked me if I wanted a big industrial monitor, naturally I said yes. Turns out to be a 40" high def lcd monitor, a special one that is meant for commercial use like factories, bars, shops, etc. Only catch was that it was meant to be wall mounted and weighed in at over 40kg. $4 worth of box section steel and some left over plywood, and hey presto, I now have the best computer monitor I could have imagined. Its shock, smoke, dust, and waterproof (6" deep all aluminium case with no vents) and I have thrown things at the screen to test it. I checked up it's specs, and it retailed at over $7000 new. Only problem I see in the future is if it ever packs out, how can I go back to a normal sized computer monitor again. I'm a spoiled rotten happy scrapper.
    1. Good Friday
      By kcscrapper in forum A Day in the Life of a Scrapper
      Last Post: 04-29-2014, 03:03 PM
    2. Black Friday TV's
      By hobo finds in forum A Day in the Life of a Scrapper
      Last Post: 11-30-2013, 06:25 PM
    3. black friday
      By tsmith53149 in forum Off Topic Discussions
      Last Post: 11-24-2013, 03:36 PM
    4. This Sweet TV!
      Last Post: 03-03-2012, 04:05 AM
    5. sweet dumpster find
      By bluemeate in forum Off Topic Discussions
      Last Post: 12-01-2011, 05:22 AM
