SMF Buyer Finder - Click an item below to find a Scrap Metal Forum buyer that buys what you're selling.
Results 1 to 18 of 18
We buy scrap copper wire!! Eastern PA
| Scrap Buyers & Sellers
    High Voltage Processing started this thread.
    High Voltage Processing's Avatar
    Last Online: 02-25-2013
    Allentown PA
    316
    63
    As requested in my welcome thread, here is my current price list for copper wire. I have also included what the local scrap yards here are paying for comparison. All prices are per pound of course.
    Type Scrap Yard High Voltage Processing
    Romex, THHN: $1.57 $1.70
    Extention/Phone/Misc $1.30 $1.40
    Shiny Copper $3.50 $3.60
    Again my number is 484-860-9454 and if you have over 100 pounds I will pick up for free.
    Allentown PA
    316
    63
    New Price for limited time only!!!
    I am in need of Romex and THHN wire badly. I will buy as much as you can at higher then board prices. Right now, I will pay $1.75 for Romex and $2 for THHN.
    Send PMSend PM
    I know what Romex is but for us uneducated ones, what is THHN???
    Dallas TX
    1,979
    158
    Its a solid wire size being 12AWG used for building.
    That's what I call Romex,
    Never mind, I'll WiKi it!
    Thermoplastic High Heat-resistant Nylon (THHN)
    That tells me the difference between that and regular old Romex,,, thanks
    Allentown PA
    316
    63
    Thank you for pointing that out. I have attached some images below. Basically, THHN is the wire that is inside the Romex outer shell coating. It is much easier for my machine to process so I will pay more for it then Romex. Also it will not have twine or paper coating thus making it easier to separate the copper from the plastic.
    Send PMSend PM
    Allentown PA
    316
    63
    Updated price list!
    Bare Bright $2.90 Bare Bright Copper
    #1 CU $2.70 #1Copper shall consist of clean wire that is free of lead, paint
    *or solder (may contain tarnished or green copper)
    #2 CU wire $2.60 #2 copper Tin coated shall consist of copper wire and/or bussbar*
    LG $0.80 Low grade wire is all wire that are fine strands, tin coated,
    Extension Chords, etc
    TELCO $1.00 TELCO wire shall be free of tin coated wire and braided coax wire.*
    ( add .05-.15 cents if closer to the larger range)
    Alarm $1.16 Alarm wire shall be solid 16awg or greater
    *(Red wire) containing 2 or more solid conductors*
    ROMEX $1.38 ROMEX wire shall be #14 awg-#8awg ( add .10-20 cents if larger)
    THHN $1.56 THHN wire shall be #16awg-#8awg free of thick jacket insulation
    MED THHN $1.97 MEDIUM THHN wire shall be #6- 400 mcm*
    (add a .05-.15 cents if its closer to the larger range)
    Big THHN $2.25 BIG THHN wire shall be 500 mcm or greater*
    (add .05-.15 cents if closer to the larger range)*
    Med TIN-C $1.60 MEDIUM TIN COATED wire shall be #6-400mcm*
    (add .10-20 cents if closer to the larger range)
    Big TIN-C $1.86 BIG TIN COATED wire shall be 500 mcm or greater
    ( add .10-.20 cents if closer to the larger range)
    AL-BX $0.64 ALUMINUM BX Wire shall consist of aluminum casing and copper conductors*****
    Inside, free of tin coated wires (add.10-.20 cents if closer to the larger range)
    ST-BX $0.35 STEEL BX wire shall consist of steel casing and copper conductors inside,
    Tin coated conductors aloud*( pay only .10 cents if there is boxes in the mix)
    INS-AL $0.25 INSUATED ALUMINUM wire (pay.05-.10 cents more if closer to the larger range)
    BA $0.50 Bare Aluminum
    BRASS $1.20 BRASS shall consist of yellow or white brass free of steel fittings
    (pay .05 less if some steel* Use discretion) We only Buy only brass if*
    its from wire exuggs connectors etc.
    Send PMSend PM
    Allentown PA
    316
    63
    New Pricing
    Bare Bright $2.60 Bare Bright Copper
    #1 CU $2.52 #1Copper shall consist of clean wire that is free of lead, paint
    #2 CU wire $2.42 #2 copper Tin coated shall consist of copper wire and/or bussbar*
    LG $0.62 Low grade wire is all wire that are fine strands, tin coated,
    TELCO $0.82 TELCO wire shall be free of tin coated wire and braided coax wire.*
    Alarm $0.98 Alarm wire shall be solid 16awg or greater
    ROMEX $1.20 ROMEX wire shall be #14 awg-#8awg ( add .10-20 cents if larger)
    THHN $1.38 THHN wire shall be #16awg-#8awg free of thick jacket insulation
    MED THHN $1.79 MEDIUM THHN wire shall be #6- 400 mcm*
    Big THHN $2.07 BIG THHN wire shall be 500 mcm or greater*
    Med TIN-C $1.42 MEDIUM TIN COATED wire shall be #6-400mcm*
    Big TIN-C $1.68 BIG TIN COATED wire shall be 500 mcm or greater
    AL-BX $0.46 ALUMINUM BX Wire shall consist of aluminum casing and copper conductors*****
    ST-BX $0.17 STEEL BX wire shall consist of steel casing and copper conductors inside,
    INS-AL $0.07 INSUATED ALUMINUM wire (pay.05-.10 cents more if closer to the larger range)
    BA $0.32 Bare Aluminum
    BRASS $1.02 BRASS shall consist of yellow or white brass free of steel fittings
    Send PMSend PM
    Allentown PA
    316
    63
    Bare Bright $2.97 Bare Bright Copper
    #1 CU $2.77 #1Copper shall consist of clean wire that is free of lead, paint
    #2 CU wire $2.67 #2 copper Tin coated shall consist of copper wire and/or bussbar*
    LG $0.87 Low grade wire is all wire that are fine strands, tin coated,
    TELCO $1.07 TELCO wire shall be free of tin coated wire and braided coax wire.*
    Alarm $1.23 Alarm wire shall be solid 16awg or greater
    ROMEX $1.45 ROMEX wire shall be #14 awg-#8awg ( add .10-20 cents if larger)
    THHN $1.63 THHN wire shall be #16awg-#8awg free of thick jacket insulation
    MED THHN $2.04 MEDIUM THHN wire shall be #6- 400 mcm*
    Big THHN $2.32 BIG THHN wire shall be 500 mcm or greater*
    Med TIN-C $1.67 MEDIUM TIN COATED wire shall be #6-400mcm*
    Big TIN-C $1.93 BIG TIN COATED wire shall be 500 mcm or greater
    AL-BX $0.71 ALUMINUM BX Wire shall consist of aluminum casing and copper conductors*****
    ST-BX $0.42 STEEL BX wire shall consist of steel casing and copper conductors inside,
    INS-AL $0.32 INSUATED ALUMINUM wire (pay.05-.10 cents more if closer to the larger range)
    BA $0.57 Bare Aluminum
    BRASS $1.27 BRASS shall consist of yellow or white brass free of steel fittings
    Send PMSend PM
  10. #10
    ScrapperStoke's Avatar
    Hamilton, NJ
    49
    35
    I take it TELCO would include twisted pair patch cable?
  11. #11
    Allentown PA
    316
    63
    you are correct.
    Send PMSend PM
  12. #12
    cgraz1187's Avatar
    Scranton, PA
    17
    Are the prices posted above current?
  13. #13
    sjones99's Avatar
    iowa
    266
    26
    i bet not
  14. #14
    Stroudsburg PA
    25
    Hey,
    High Voltage, I sent you a private message I'm not sure if you saw or not. Could you check it out and let me know what you can do for me? Thanks
  15. #15
    Dunemaul's Avatar
    East Orlando FL
    1,064
    157
    Jim could you update your price list. I need to check on logistics but i think i might start shipping my BB to you among other copper.
  16. The Following User Says Thank You to Dunemaul for This Post:
  17. #16
    4,758
    6,037
    Are you still buying Cu wire? If so can we get some prices? Thanks!!
  18. #17
    4,985
    1,257
    If I remember correctly this company went bankrupt
    http://www.freecourtdockets.com/dock...rt-docket.html
