Results 1 to 18 of 18
Watch out for this motherboard!
    FLimits started this thread.
    FLimits's Avatar
    Jan 2014
    NY
    459
    654
    Exclamation Watch out for this motherboard!
    This is an ASUS motherboard that supports a pair of Pentium Pro or Pentium II processors. The CPUs are mounted on a daughterboard that connects to a slot near the center of the main board. It's a valuable board, so if you're lucky enough to find one, don't scrap it!!
    Name:  ASUS P65UP8.jpg
    https://www.loom.com/s/3c79a6b7c0451...388de2184ddc2f
    Edit: Board ID no. is P65UP8. Thanks for answering that, ryanw!
    ScrappinRed's Avatar
    texas
    709
    319
    Do you have the number for the motherboard? Would it be possible to find this board with other cpu's mounted on it, or only pentium pros? Thanks for your help, AGAIN!!
  3. The Following User Says Thank You to ScrappinRed for This Post:
    ryanw's Avatar
    TX
    1,312
    526
    Quote Originally Posted by FLimits View Post
    From the link provided - Asus P65UP8, but quick check says P65UP5 supports these CPU cards as well.
  5. The Following User Says Thank You to ryanw for This Post:
    jimicrk's Avatar
    Sep 2013
    Tennessee
    2,826
    2,917
    I have 62 old PC's I've picked up in the last 2 days and they are all old. Some have the old 5" floppy drives. I haven't been able to look at all of them yet but I did look at a few and found a Pentium Pro. I'm hoping I'll find more as I go through them. Maybe I'll find one like the one above.
    My first.
  7. The Following 2 Users say Thank You for This Post by jimicrk:
    texas
    709
    319
    Quote Originally Posted by ryanw View Post
    Thanks but I'm looking for the number off the board, not the card... unless you're saying the motherboard and card have the same number?
    ryanw's Avatar
    TX
    1,312
    526
    Quote Originally Posted by ScrappinRed View Post
    Those are the motherboard numbers.
  10. The Following User Says Thank You to ryanw for This Post:
    texas
    709
    319
    Thanks ryanw! Just wanted to make sure I had the right numbers. Motherboards all start to blend together after a long day of pulling stuff apart!
    Wisconsin
    159
    140
    Quote Originally Posted by jimicrk View Post
    My first.
    Before tearing down shoot FLimits a p.m. From all the reading she knows her **it about the older stuff and can possible purchase it for more than scrap value.
  13. The Following 2 Users say Thank You for This Post by johnuppy:
    jimicrk's Avatar
    Sep 2013
    Tennessee
    2,826
    2,917
    These computers had been stored in a semi trailer since the early 90's or longer with rain leaking in on them and God only knows what living in them. I pulled a good part of them out of the construction dumpster after they were thrown in from the back of the trailer. These things are bent broken and funky funky funky!! They are currently in my driveway getting rained on because they ain't coming in the garage. I will have some more stuff coming in soon from several other contacts so maybe it will be in good shape and can be sold.
  15. The Following 2 Users say Thank You for This Post by jimicrk:
    armygreywolf's Avatar
    Germantown, WI
    1,084
    193
    Let me expand on where you MIGHT find these dual socket boards. Sun Microsystems Workstations, Silicon Graphics Workstations and Workgroup servers. BUT The number one find and most likely is the IBM Intellistation 6899 or Z Pro. It will have a Pentium Pro sticker right on it and will be a "full tower" case instead of the then common mid tower. There are others, the MPC Client Pro and Dell GX Pro DOES NOT have an asus board, so far as I know the aforementioned are the ONLY P Pro Dual Processor ASUS Mobo systems. Good luck on the hunt, even AsusTek admits they made less than ten thousand. (In a time when the Pentium II and AMD K6 were over 233 Mhz)
  17. The Following User Says Thank You to armygreywolf for This Post:
  18. #11
    Electrowaste's Avatar
    NE Alabama
    279
    622
    At Electrowaste Recycling, any man who finds a Pentium Pro gets lunch on me, if they find this, breakfast and lunch!
    Jeremy Burrage - Founder & CEO
    Electrowaste Recycling LLC, Guntersville, AL
    https://www.facebook.com/pages/Elect...31655806922157
  19. The Following 4 Users say Thank You for This Post by Electrowaste:
  20. #12
    msmoorad's Avatar
    Durban, South Africa
    690
    715
    im in South Africa but im sitting with a Pentium Pro & ( i think ) a few 486 chips
    dont know what to do to get max money out of it.
    should i sell it to u guys?
    post it in a box?
  21. #13
    grouchyolddude's Avatar
    CO
    209
    792
    I sold a cpl of 486 boards with cpus on ebay for way "better than scrap". UNTESTED ..AS IS.. FOR PARTS ONLY
    "Some people try to turn back their odometers. Not me, I want people to know WHY I look this way. I've traveled a long way, and all of those roads weren't paved"-Will Rogers
  22. #14
    mudlight2's Avatar
    Memphis TN
    254
    179
    I got a board that has 2 Pentium pros in it. It doesn't have a daughter board in it. But its dual socket. I need to look the motherboard up. I reckon.
  23. The Following User Says Thank You to mudlight2 for This Post:
  24. #15
    Melk's Avatar
    Feb 2015
    Charlotte
    11
    What's so special about Pentium Pro's ??? (apologies, noob)
  25. The Following User Says Thank You to Melk for This Post:
  26. #16
    NewbyScrapper's Avatar
    Northern California
    262
    1,480
    Quote Originally Posted by Melk View Post
    G O L D
  27. The Following 2 Users say Thank You for This Post by NewbyScrapper:
  28. #17
    Mar 2016
    Se Iowa
    18
    i can't seem to open the link? What is the non scrap value of this MB?
  29. #18
    Quote Originally Posted by MetalIsMoney View Post
    Old thread and Flimits is no longer an active member. Mike
