Results 1 to 10 of 10
Coax cable
| Scrap Metal Tips and Advice
    ozzy214 started this thread.
    Usa
    768
    67
    Coax cable
    Curious on something. My yard said that coax cable like from the cable company, is more steel than copper. That I should throw it in the tin pile.
    Now some I agree, because a magnet will stick to them. But I have some other coax, that a magnet wont stick too. It actually has somekind of aluminum sheath under the plastic, then what appears solid copper. I even cut the wire, and still shiny copper.
    Please clarify
    Mine only goes as coax if it's magnetic. Coax price is 0.035 higher than tin. To "clarify", as you say, you'd really need to ask the yard where you go.
    Here, this might shed some light,
    http://www.scrapmetalforum.com/showt...highlight=coax
    Here's one pic. for clarity,
    Here is a site with good descriptions of the different coaxes,
    http://www.bluejeanscable.com/articles/rg6.htm
    Usa
    768
    67
    Ya I my yards around here dont have a coax price, so it all goes in the tin pile. But thanks Mechanic and the link, some higher grade coax is copper core. SO i guess I will look more carefully...thanks.
    I like to stip the copper coax. The coax that hams use and directTV(so far) is good copper in the center. The rest goes with the steel for me, Mike.
    Theres that many sorts of Coax, the newer - the worst return though.
    Hard to strip, lots wire jabs into the fingers, newer stuff is greasy.
    I scrapped the rest of a roll of satellite cable, only a sniff of copper, hardly worth it, actually I wouldn't even bother, I'd rather pick up Ali cans off the street....
    Usa
    768
    67
    Ok I did a test run. Had a bit of coax. Ran it through my wire shredding machine. Underneath insulation was some kind of shield. Im guessing braid aluminum, not sure. Maybe someone can clarify on that since I still can figure out how aluminum looking wire in tv is copper or how to prove it.
    Anyway under the shield was plastic coating and then a thin strand of copper. I ground it and heated it, since aluminum melts with mapp gas, not copper. Sure enough copper. Now as long as I can figure out what the shield is, IM golden.,
    I'm sorry to osd, but it just bugs me to know something if I don't...lol!
    Also any ideas on how to prove to my yard that the aluminum wire in the tvs is indeed copper and tin coated?
    Quote Originally Posted by ozzy214 View Post
    Scrape it, I scrape the washing & dryers motor windings before I start to pull them out.
    Just a wee scrape & you can see the difference in colour, when its copper its easy to see.
    When its anodised Ali its a bit harder to see, thats when I pick a single wire out with the screwdriver, Ali breaks, copper stretches a little before breaking.
    Then I check the broken end, Ali's silver, coppers normally a little darker or golder than the varnish coating.
    Its actually working in my favor as people must be throwing out dryers without scrapping them because they think the motors got Ali windings.
    Usa
    768
    67
    Ok thanks for the advice..makes sense. ANy what that braid is ?
  10. #10
    If the braid is silver colored and "light" weight it is Al if it is "heavy" feeling then most likely copper. If you think it might be copper cut some of the strands and look at the ends or scrape it. If it is copper it will show. Once you find Al and copper braid you will not mistake one for the other. Best of luck, Mike.
  11. The Following 2 Users say Thank You for This Post by miked:
    1. Does coax cable have any value at all?
      Last Post: 05-21-2013, 05:38 AM
    2. Attention Coax Experts - Quick Question!
      By BigRyan in forum Off Topic Discussions
      Last Post: 08-27-2012, 11:24 PM
    3. Coax
      Last Post: 02-17-2012, 11:51 AM
    4. Anyone stripped Hardline COAX before?
      By kepscrap in forum Scrap Metal Questions and Answers
      Last Post: 02-03-2012, 02:30 AM
    5. help, computer coax cable ends ?
      By EcoSafe in forum General Electronics Recycling
      Last Post: 07-03-2011, 10:32 AM
