Results 1 to 6 of 6
| Misc. Metal Recycling
    VERYOLDGUY started this thread.
    MISSISSIPPI
    172
    97
    Not sure if this is in the right place
    Not been on here long. Thanks folks learning a lot.
    Wish me luck making my first test run.
    Will update when i get the numbers.
    Taking
    shred
    ss
    copper #1 bright
    copper#2
    yellow brass
    red brass
    alum can
    alum mixed (extrusion, and heat sinks) (yard pays same called to check)
  2. The Following User Says Thank You to VERYOLDGUY for This Post:
    Good luck and don't get discouraged. Lot of times, the first run is a "learning experience".
  4. The Following User Says Thank You to Mick for This Post:
    RustyDollars's Avatar
    Central Wis
    426
    438
    Good luck!
    Being your first run, don't be intimidated. Don't let them downgrade your aluminum for example if there's a single piece that's dirty. Instead just throw that piece back in the truck for your next run.
  6. The Following User Says Thank You to RustyDollars for This Post:
    Do your yards 'add' the scales weights together or do they 'Zero' the scales between weights.
    My yard has just started to 'add' the weights up, it means more $$ for me & I get paid for every gram now. I think its because I only go there now.
    Before it was,
    5 1/2 #2Copper, scales read [5Kg] Zero scales.
    then 5 1/2kg Brass, scales read [5Kg] Zero scales
    then 5 1/2kg domestic Copper, scales read [5Kg] Zero scales
    then 5 1/2 Ali, scales read [5Kg] All up 20Kgs metal
    This is what happens now......
    I put up 1/2Kg #2Copper, scales reads [5kg]
    then 5 1/2kg Brass, scales read [11kg]
    then 5 1/2kg domestic Copper, scales read [16Kg]
    then 5 1/2 Ali, scales read [22Kg]
    So theres a extra 1Kg brass & 1Kg Ali that I get paid for.
    Its also a reason to put up the cheaper metals first,... but I don't.
    Just FYI, most heat sinks are extruded, other random alum. is usually listed as old sheet or something like that.
    and then there is cast, cans, etc.
    NHscrapman's Avatar
    new hampshire
    1,582
    4,076
    my yard doesn't separate aluminium either. cast extrude and sheet are one price cans are another. this can be discouraging at times but they have never put a magnet to my aluminum so i guess those few dirty pieces that slip through are the price paid.
