Results 1 to 5 of 5
carbide removal from sawblades
    tdean started this thread.
    Upstate NY
    44
    23
    I had some dado inserts without the outside blades, with 2 large carbide teeth on them. I dont have a torch so I put the tooth in the vice and sort of snapped the braised joint, though some of them crumbled a bit. Does anyone use a torch to take off the carbide inserts off of sawblades? Is it worth it? There were some high prices advertised months ago.
    Saint Louis, MO
    762
    When I was 14 I scrapped a truckload of them 40,000 lbs of blades took a week to clean them. We took a metal table and welded a piece of pipe on it put the blade on and a metal bucket under it. lit the torch heated up the carbide hit it with the hammer. carbide falls into bucket. repeat. repeat. repeat. We just scrapped 214 lbs of carbide last week though. 9 dollars a pound. Couldnt tell u what it was on though just came in the yard in a mixed load was some sort of paddle though.
    Upstate NY
    44
    23
    I meant to ask if you need the heat from an oxy acetylene torch, or propane/O2 ? Is it worth trying with a regular propane plumbers torch?
    Saint Louis, MO
    762
    it needs to get it hot enough to break the silver soder betwwen the steel and the carbide no clue if a regular plumbers propane torch would work. try it and see if it works if not try the regular oxy/propane torch.
  5. The Following User Says Thank You to PistoneScrapProcessing for This Post:
    Flint, Mi
    51
    You can also try a plumbers style torch with map gas. Gets way hotter faster than propane.
  7. Similar threads on the Scrap Metal Forum
    1. National - Scrap carbide / tungsten
      By DAVECCT in forum Scrap Buyers & Sellers
      Last Post: 08-15-2019, 09:17 PM
    2. Tungsten carbide drill teeth
      By ParkerFlyer4 in forum Scrap Metal Tips and Advice
      Last Post: 04-22-2014, 03:25 PM
    3. Hello from SC Carbide recycling facility
      By DAVECCT in forum Introduce yourself
      Last Post: 10-08-2012, 06:48 PM
    4. carbide.
      By sipper1210 in forum A Day in the Life of a Scrapper
      Last Post: 09-19-2012, 07:23 PM
    5. Carbide Recycling
      By CAS in forum Scrap Metal Questions and Answers
      Last Post: 07-13-2011, 09:36 AM
