Results 1 to 14 of 14
    gagneet23 started this thread.
    Oregon
    31
    20
    Scrapping a Direct Tv Box (Please Subscribe)
    Please rate and subscribe and ENJOY
    DiamondN's Avatar
    912
    2,150
    What you are referring to as 'copper motors' are transformers. Rather than trying to just rip them out, which resulted in breaking the board and cutting yourself, try heating up the solder connections on the back side with a small butane torch or a soldering iron. I've also used my heat gun to loosen components without any resulting damage. There won't be much value to the card slot assembly as they are so common, but you should be able to sell the DTV card (aka CAM) on eBay, if they don't cancel your auction first.
    Good Luck...
  3. The Following User Says Thank You to DiamondN for This Post:
    Oregon
    31
    20
    thanks
  5. The Following User Says Thank You to gagneet23 for This Post:
    2,864
    350
    Those are not high grade boards. In my book they are low grade, braking a board dose not down grade the board, taking things off a high grade board will down grade the board. If your getting high grade price for those boards I would like the name and address of your buyer.
    BurlyGuys's Avatar
    Waterford Michigan
    1,591
    1,109
    Wasnt there a post that these were able to be sold for more than scrap value?
    John Terrell (248) 224-2188
    Burly Guys Junk Removal LLC
    http://www.burlyguys.com
    DiamondN's Avatar
    912
    2,150
    Quote Originally Posted by BurlyGuys View Post
    It depends on the model of receiver box. I'm more familiar with DN receivers, but as with most items, I always run the model numbers thru eBay and then make the decision.
    Oregon
    31
    20
    I just starred scrapping a month ago and so far i have never went to the scrap yard and im hoarding up for the scrap yard next month and dont high grade boards have gold on thme
    jghilino's Avatar
    KANSAS CITY
    2,672
    1,429
    The access cards go for $2 each on ebay. The smart card slot is worth taking apart for gold plated metal recovery. The board itself is midgrade once all of the excess transformers and shred has been removed, also all the capcitors. Once the board is clean it can be sold as midgrade. AS-IS the main board is low grade. If you see any gold plated metal on the main board go ahead and remove it and sell it separately. Just be aware that brass looks the same a gold plated to an untrained eye.
    Oregon
    31
    20
    well im going to sell the card on ebay mines is old so it might go for less
    Gravitar's Avatar
    Central Texas
    1,086
    1,258
    Quote Originally Posted by gagneet23 View Post
    Yes, but I toss the DirectTV ones in my mid grade box. There are so many different grades of "Higher Grade Boards." Telecom, Motherboard, Ram, Hard Drives, etc just to name a few. I leave the transformers, aluminum, etc on. I don't want to degrade the board. Knock off the aluminum and transformers with a carpenters hammer. Quicker than channel locks, and cleaner.
    jghilino's Avatar
    KANSAS CITY
    2,672
    1,429
    Low grade boards can have gold on them a great example is hot swap power supply board where the only gold is a gold finger. No buyer is going to call it high grade. I have some videogame console boards that are motherboard/high grade boards. But the satellite receiver and cable box boards are mid grade at best from my experience.
    2,864
    350
    I'm not saying that you can't get mid grade for those boards but I have never gotten mid grade for them.
    All day long at Ohio. You might need to check out different buyers, there's quite a few out there.
  16. The Following 2 Users say Thank You for This Post by Mechanic688:
    silverZ's Avatar
    La Pine, OR
    66
    340
    I included 5 or 6 of these boards in a load I just sent to ewasted and got motherboard price for all of them.
    1. Every Door Direct Mail results day 1
      By thirsty in forum General - Let's talk business
      Last Post: 08-11-2012, 02:30 PM
    2. Direct tv dish
      By Jonniebrass in forum Scrap Metal Tips and Advice
      Last Post: 03-13-2012, 08:18 PM
    3. CPUs: eBay vs selling direct?
      By ilyaz in forum General Electronics Recycling
      Last Post: 11-09-2011, 03:20 PM
    4. Direct TV Access Cards
      By rca987 in forum General Electronics Recycling
      Last Post: 06-30-2011, 10:31 AM
    5. Direct core
      By Motörhead in forum Vehicle Recycling
      Last Post: 03-29-2011, 07:57 PM
