Results 1 to 9 of 9
    copycat started this thread.
    copycat's Avatar
    South Western PA
    215
    150
    tip for removing copper from steel layered transformers.
  2. The Following 6 Users say Thank You for This Post by copycat:
    barndogusn's Avatar
    Gulf Coast
    That's some patience that I don't have
    Jul 2014
    Oregon
    Nice
    jiffy117's Avatar
    Central NY
    286
    220
    Unless you have a use for the wire like this guy I'd say not even close to being worth the trouble. Good video! I have to UPS's to take apart, now I know whats in them.
    jimicrk's Avatar
    Sep 2013
    Tennessee
    2,826
    2,917
    After you've taken a few hundred transformers apart you figure out easy ways of getting the copper out. You can make good money with little trouble with transformers.
  7. The Following User Says Thank You to jimicrk for This Post:
    I
    Stand on transformer with my left foot and run 9inch angle grinder with cutoff disc down one side of the transformer, cutting off all of one end of the loops off.
    Then I use a hammer and steel punch to punch out the rest if the coil.
    I scopp up all the loose copper wire, then bash the bigger end flattish to loosen the plastic and the tape and pull out the rest of the copper coil in two goes.
    That's it.
    But, I get to sell all those I,s and E's whole as 'heavy metal insize'.
    I put the smaller ones into the larger 1/2 of the fridge compressor cases and tack weld the two larger parts together into one large peice that you can still see inside of.
    Same with the microwave transformer peices.
    But, if I could pull out all the I's and E's that fast, i'd do it his way......
    Robbie2Scraps's Avatar
    Mar 2014
    Ohio
    24
    19
    What is a mosfit?
    Quote Originally Posted by Robbie2Scraps View Post
    What is a mosfit?
    That is a style of transistor. This is compliments of encyclopedia.com;
    MOSFET (MOS transistor) Acronym for metal oxide semiconductor field-effect transistor. A type of field-effect transistor that has an insulating layer of oxide, usually silicon dioxide, separating the gate from the drain-source conduction channel in the semiconductor. In an NMOS the channel is formed between n-type source and drain by negative charge carriers (i.e. electrons). In a PMOS the channel is formed between p-type source and drain by positive charge carriers (i.e. holes).
    MOSFETs require no gate input current, other than a pulse to charge or discharge their input capacitance. They can operate at higher switching speeds and lower currents than bipolar transistors.
  11. The Following 2 Users say Thank You for This Post by Mechanic688:
    british's Avatar
    ENGLAND UK
    105
    236
    Just about to say that.........NOT!!
    Thanks Mech...
    British - Some people go the extra mile......Mech and Sir are just two of them ...SMF and it's enhabitants go 23,000,000 miles more - british
    Please take my thanks .....It's the least i can give (and heart felt)
    Last edited by british; 07-25-2014 at 04:07 PM. Reason: Not in enough respect shown on my behalf
    1. removing copper from UPS battery backup transformers
      By azgard in forum Batteries, Capacitors, Heat Sinks
      Last Post: 06-17-2013, 10:02 AM
    2. Removing the metal from stainless steel sinks
      By bb3p in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 03-14-2013, 12:37 AM
    3. Tip for removing copper from a electric motor stator.
      By Metalman65 in forum Scrap Metal Tips and Advice
      Last Post: 02-08-2013, 08:37 PM
    4. Tip for breaking down transformers
      By copycat in forum Scrap Metal Tips and Advice
      Last Post: 05-17-2012, 09:44 PM
