Results 1 to 6 of 6
My Good Day Turns Into A Bad Day
| Scrap Metal Videos
    RLS0812 started this thread.
    RLS0812's Avatar
    Bucks County Pennsylvania
    895
    155
    Angry My Good Day Turns Into A Bad Day
  2. The Following User Says Thank You to RLS0812 for This Post:
    jimicrk's Avatar
    Sep 2013
    Tennessee
    2,826
    2,917
    I hope you're able to get it repaired without to much trouble.
    gabrielservices's Avatar
    Carson city nv
    152
    44
    Take a file. File the broken part of the pully so there's no sharp edges and throw a new belt on. Simple. As for the wire, what does it control? Also, on the tensioner pulley, there is normally a 3/8" square for a 3/8" ratchet to fit into. Or in this case id use a 3/8" breaker bar to 'loosen' it.
    Scrappah's Avatar
    1,058
    320
    Ugggh ... looks like a no-fun job. If you can afford to put it in the shop it might save a lot of hassle. A guy that works in the trade every day is more likely to know how to work in the tight spaces.
    Looks like something bad happened there. Maybe the bearing in the belt tensioner assembly seized and the whole thing smashed into the power steering pully.
    Pullies and tensioners often aren't that expensive to buy. They're common replacement parts. I would step back and re-assess the whole thing. Don't have any experience with Dodge, but would it be possible to pull the power steering pump & mounting bracket ? There might be some hidden bolts in there somewhere that would allow you to get at the tensioner mount.
    A Hayne's or Chilton's repair manual might give you a clue on the R&R procedure. Sometimes what appears to be bad design really isn't. There's often a way to do the job if you have the patience to work step by step in the tight spaces.
    t00nces2's Avatar
    Jul 2014
    Sarasota, FL
    1,707
    1,191
    I am no automobile repair expert, but I did spend the evening in an unbelievably drunken stupor last night....
    My guess would be the belt snapped and broke the pulley or something popped up, got caught and snapped the belt and chipped the pully. I would replace the belt and see how it goes before I went through the trouble of replacing a bunch of stuff that was not needing to replaced.
  7. The Following User Says Thank You to t00nces2 for This Post:
    Scrappah's Avatar
    1,058
    320
    I've done it that way before. Left me stranded on the road a couple of times. Sees like it always happens at the worst possible time.
    Found On Road Dead.
  9. Similar threads on the Scrap Metal Forum
    1. When well meaning turns painful.
      By armygreywolf in forum A Day in the Life of a Scrapper
      Last Post: 01-25-2016, 01:24 AM
    2. When trying to help out turns out to be more than you thought
      By scrapping4ever in forum A Day in the Life of a Scrapper
      Last Post: 07-31-2015, 09:03 AM
    3. Found my old CB radio, and turns out its from america O.o
      Last Post: 03-13-2012, 01:48 AM
    4. Turns out the 2 tvs i got were crap, they crapped out.
      Last Post: 03-09-2012, 12:15 AM
