Results 1 to 20 of 28
Am I done with these?
    Julie started this thread.
    Julie's Avatar
    Grass Valley California
    420
    432
    I need a little help here - Is there any more that i need to take off of these boards or am I done with them?
    And the things in the picture below... I am about to throw at the wall! Anyone care to tell me how to get them open before they start flying across the room?
    Sorry for the bad quality pics!
    Thank you in advance for anyone willing to help me out here!!
  2. The Following User Says Thank You to Julie for This Post:
    Jeremiah's Avatar
    Virginia
    437
    147
    You need to take the plastic off the slot-card CPU. You could take the fingers off the finger cards if you wanted to max $. Also, remove the Al heat sink
  4. The Following 2 Users say Thank You for This Post by Jeremiah:
    corycouch's Avatar
    jonesboro ar
    1,405
    3,766
    im glad you asked this ive been wondering if i needed to do anymore to mine, jeremiah are you refering to the heatsink on the video card im assuming u are, the ones i have so far i have left them on
    Julie's Avatar
    420
    432
    Quote Originally Posted by Jeremiah View Post
    I understand that the plastic needs to be off of the slot processor it's getting it off that i am having a problem with...
    is the Al sink that silver one in the 1st pic? What if the heat sink won't come off?
    Jeremiah's Avatar
    Virginia
    437
    147
    It may depend on your buyer, the ones I've used so far will not pay slot-card price for the total weight with the Al heat sink on. I was told by one that if he has to remove it remove it he will pay less. You may want to check with some of the awesome buyers in the electronic recycling threads.
    199
    Julie,
    Get a large flat head screw driver and just get to prying. Just slide the screw driver between the plastic and the board and pry.
    My 4 S's
    S**T, Shower, Shave...and Scrap
  9. The Following 2 Users say Thank You for This Post by Pcbmine:
    On the slot processor, pentium II, just shove a flat head screw driver in there and twist. In the picture the lower right is what it will look like when you've gotten rid of all the junk. On the heat sink remove or not check with your buyer for the correct answer. Mike.
  11. The Following 3 Users say Thank You for This Post by miked:
    Julie's Avatar
    420
    432
    Thanks for all the help! Does anyone normally remove the thing that the CPU sets in?
    Julie's Avatar
    420
    432
    Oh another quick question... I don't have any way to weigh the stuff that I have. Any suggestions?
    LadyScrappers's Avatar
    Lakes Region, NH
    163
    339
    Quote Originally Posted by Julie View Post
    I use a cheap kitchen scale that weighs in ounces up to 2 lbs. Anything heavier than that and you can use a bathroom scale. They might not be completely accurate but at least can give you an idea, especially if you don't have anything else to use.
  15. The Following 2 Users say Thank You for This Post by LadyScrappers:
  16. #11
    6,815
    i think that tiny heatsink on the motherboard is ok, and i've seen most buyers say just leave the little strip of steel on the add in boards
  17. The Following User Says Thank You to Bear for This Post:
    thortek's Avatar
    Scrap biz in OHIO, but I live in south Florida!
    513
    153
    i pull the aluminum heatsink off the board..if I'm bored. Split the cpus out of the plastic. I leave the plastic guides for the slot processors on the boards, just because It takes too much time to remove. They typically break off when I slam other boards on top of them. Leave the metal guides on the other cards...
    “Most people miss opportunity because it wears overalls and looks like work .” ― Thomas A. Edison
    www.thortekrecycling.com
  19. The Following User Says Thank You to thortek for This Post:
  20. #13
    Cincinnati, Ohio
    286
    52
    when you say remove the fingers, are you cutting off the finger portion of the board, or actually desoldering/scraping/pulling them off?
  21. #14
    boise, ID
    1,605
    469
    Cut or break them off. Worth about 70 bucks a pound.
  22. #15
    BUT, fair warning, not all the buyers will buy the cards with fingers removed. Might end up double shipping.
    Check with your buyer you normally use.
  23. The Following 3 Users say Thank You for This Post by Mechanic688:
  24. #16
    Waterford, WI
    78
    179
    Pry off AL heatsinks with flathead screw driver and pop plastic cover off slot processor (dont worry about damage to CPU). Leave face plate on PCI cards. Cutting fingers off cards is worthwhile if your buyer pays premium for fingers and still buys fingerless cards otherwise leave them on.
  25. The Following User Says Thank You to duece2000 for This Post:
  26. #17
    Julie's Avatar
    420
    432
    Quote Originally Posted by duece2000 View Post
    What's a Face plate? I was thinking about trying to pry the heat sinks off of the boards but what if i damage the board itself?
  27. #18
    Recycing REALLY damages the boards, so don't concern about damaging the boards. Mike.
  28. The Following 2 Users say Thank You for This Post by miked:
  29. #19
    GeorgeB's Avatar
    Manassas Park, VA
    2,919
    462
    I could be wrong, but buyers do not car of the condition of the boards (aside from gold fingers being cut off). They buy pc boards to melt them down to harness the gold content from them.
    That is why PC scrap is valuable. If it wasn't for the gold in them, the only thing be worth anything scrap wise, would be the metal carcasses.
    Then for the still working stuff like power supplies, pc chips, memory sticks, etc then you could try ebay or even craigslist.
  30. The Following User Says Thank You to GeorgeB for This Post:
  31. #20
    Julie's Avatar
    420
    432
    Ahhh I see... Duh! I guess I was thinking that the buyer would test them to see if they worked or something but now that I think about it that would be way more involved and time consuming.
  32. The Following User Says Thank You to Julie for This Post:
