Results 1 to 20 of 20
    scrapping307 started this thread.
    Apr 2014
    Wyoming
    Having trouble identifying the cpu on an iMac G3 motherboard
    Hi,
    I've got about 20 of these motherboards, and the CPUs seem to be glued or soldered on. I have three questions, which chip is the CPU? Should I try to get it off? If so, how do I get it off? I tried using a flathead screw driver and prying/chiseling the chips off but just chipped the green plastic squares these chips are on. Do buyers buy these with the cpus attached? Any help would be greatly appreciated. Thanks!
    Here's what the computer looks like when it's whole (I think it's an iMac g3)
    Here's the whole mother board
    Then there are three chips on it.
    pjost's Avatar
    Apr 2014
    N & South Dakota
    994
    5,151
    The one that says rage is the video card. That's about all I know of ewaste lol
    FLimits's Avatar
    Jan 2014
    NY
    459
    654
    Oh geez, Apple and their goofy mobo designs again... OK, the ATI and the Lucent are not the CPU. It should have a PowerPC CPU, and I honestly don't know what that VLSI chip is. Was there an additional card? On some of these iMacs the CPU was on a separate card. Was there a heat sink?
  4. The Following User Says Thank You to FLimits for This Post:
    Jul 2013
    Ohio
    162
    54
    I think its on the botom. ibm chip. btw, last time I had one of those, I pulled the heavy parts off the power supply board and attached it before mailing off.
  6. The Following 3 Users say Thank You for This Post by foobar:
    Apr 2014
    Wyoming
    I think the Rage chip had a heat sink on it. I took another look at the board, and there's a small chip on a little green board on the other side. I'll try to get a picture up of it later today, but it might be a green fiber processor. Sorry I didn't see it earlier, I'm pretty new to this.
    4,985
    1,257
    Quote Originally Posted by foobar View Post
    You are correct it should be on the bottom and should say motorola (I have done 100's of these as the local school system sells them cheap)
  9. The Following User Says Thank You to mikeinreco for This Post:
    FLimits's Avatar
    Jan 2014
    NY
    459
    654
    The CPU is on the other side of the mobo? Ah, those nutty Apple engineers, what will they come up with next? What kind of heat sink do they put on it? Is there a fan down there too? Or do these mobos end up frying themselves in their own heat?
    I know in an earlier version of this same computer, the CPU was mounted on a daughter board. Those machines were upgradeable. In the later revisions, though, they just soldered the CPU right on. I didn't know it was on the bottom of the mainboard, though. Not sure I would have thought of turning it over to look for the CPU either!
    Apr 2014
    Wyoming
    Thanks mike and everyone else for the help. I think I found the processor, the first photo. None of them on the 15 or so I have say motorola or IBM, they all just have a bunch or letters and numbers. They do appear to be ceramic, though, with some sort of plastic and foam or rubber glued on top. I started to peel it off in the second photo. Should I try to detach these processors before selling? It seems like the common hot-sand desoldering method would remove all of the chips from the board, so should I just leave that to the buyer? If I sell the boards with the cpus attached, how much more should I ask for them?
    4,985
    1,257
    On the bigger Emac's the white version of this they do say motorola...........I am sure that those are basically the same chip even though they don't say it
    Mar 2014
    philly
    53
    61
    does anybody know if the yellow blocks to the right of the cpu are tantalum capacitators? they have an orange stripe on one side...or maybe the little yellow ones to the left?...thanks
    Alabama
    764
    1,067
    Yes the yellow with orange stripe of all sizes. Also, the black ones with white stripe that are the same design as the yellow ones.
  15. The Following User Says Thank You to Pnutfarmer for This Post:
    matador's Avatar
    Nov 2013
    Big Wonderful Wyoming
    2,310
    1,813
    I've done many G4s (The Successor to your iMac G3). The CPU seems to be non-removable. I've tried everything I can think of. I'm sure the older iMac G3s and the eMac are similar.
    I don't know who your buyer is, but I would assume to send them with the CPU on if possible.
    If you use a large buyer, they'll probably be able to give you a value, or some advice.
    webuyselltradestuff's Avatar
    May 2013
    Watkinsville, GA
    950
    131
    ATi chip is the video card GPU
    VLSI chip is an IC chip basically (integrated circuit)
    Lucent chip is another Ic (integrated circuit) chip
    CPU is on the bottom of these...yes I know WEIRD....and Motorola made them all I believe up until the deal with Intel happened and you could finally dual boot (that happened in 2005)...these are POWER PC chips...they are soldered onto the board. Send them to Ewasted or whomever and just let them know (separate it form the rest of the motherboards)....they generally pay a bit more for these type of motherboards.
    any yes, the little yellow boxes are Tantalum...they can be the larger ones that are pictured and smaller almost square ones as well
    My experience with those **** tings are the older apples like that are a PITA...the cases are WAY WAY overbuilt and are just tough to get into...way more work than should be needed.
    Hope that clarifies and adds to what other have said above.
  18. The Following 5 Users say Thank You for This Post by webuyselltradestuff:
  19. #14
    armygreywolf's Avatar
    Germantown, WI
    1,084
    193
    I use a hammer to get into those... pull the board, hard drive, etc...rest is junk...thankfully I don't get many of them.
  20. The Following 2 Users say Thank You for This Post by armygreywolf:
  21. #15
    Quote Originally Posted by webuyselltradestuff View Post
    I just finished taking one apart, I started at 8:20 and just now finished to come here and ask if there was a CPU chip as well.
    NA's take on imac's - ''Grrrrrrrr.....''
    Lol
  22. The Following 3 Users say Thank You for This Post by newattitude:
  23. #16
    ChildhoodDream's Avatar
    Mar 2015
    Minnesota
    1,368
    1,677
    I like those see through Apple computers. I have 2 of the older ones. I got them years back and kept them as I liked the way they looked and that they talked.
    I sort of view them in much the same way that I would view a Nintendo 64 system that was clear green or blue. They just look real cool for a larger paper weight as they are not "very smart",lol...
  24. #17
    Scrappah's Avatar
    1,058
    320
    Lol
    BIG X2 !
    #$@!&&^ Macs !
    The easiest way i found for breaking them down was to go on-line and find the step by step dis-assembly instructions. The first few breakdowns are slow but once you get the knack of it they aren't all that bad. The trick is to focus on the bottom part where all the goodies are. There's some aluminum & copper up in the CRT assembly but you have to work for it. Then you're left with dealing with a CRT that's out of it's protective case. Maybe not worth the hassle ?
    I tried breaking down the main board for the processor & the other goodies but it doesn't seem to be worth it. You might get more value from selling it whole.
  25. #18
    ^^I did the same thing, went online!! When I have a CRT tube left open like that which is rare, I wrap newspaper around the top part of the tube and tape the heck out of it so its not as dangerous.
  26. #19
    Scrappah's Avatar
    1,058
    320
    Same here NA.
    I avoid the TV's & CRT's as much as possible but someone asked me to break down an I Mac so that they could use the plastic for an art project last month.
    Disposal really isn't a problem because the state sponsors e-waste collection sites where you can drop them off for free but that exposed end is a concern. I had some bubble wrap so i duct taped that to the end and put the whole thing in a box & packed crumpled up newspaper around it. I probably worry too much but someone down the e-waste line is gonna have to handle it.
    Ohh well .... at least they have one less Mac to break down.
  27. The Following User Says Thank You to Scrappah for This Post:
  28. #20
    matador's Avatar
    Nov 2013
    2,310
    1,813
    I hate them! You spend a ton of time for no more money, and you're left with a CRT. The outer shells make a cool cat bed, though.
    For the time spent, I won;'t do much on a G3 or G4- I'll just take the easy stuff.
    1. This thead is a question - Advice needed for the removal of CPU/RAM/VIDEO slots on a motherboard.
      By Polecat in forum Scrap Metal Tips and Advice
      Last Post: 02-24-2014, 11:10 PM
    2. Help with identifying a CPU
      By billygoat in forum Computer Recycling
      Last Post: 07-21-2013, 09:54 AM
    3. Motherboard with Solder on CPU
      By ron22 in forum General Electronics Recycling
      Last Post: 10-18-2012, 09:17 PM
    4. cpu soldered to motherboard?
      By phildogg in forum General Electronics Recycling
      Last Post: 06-12-2012, 11:22 PM
