Results 1 to 19 of 19
Thick aluminum stock or bar
    redcrossnj started this thread.
    redcrossnj's Avatar
    central jersey
    465
    28
    I have some thick aluminum stock and I can't cut it anybody know of easy ways to bend it?
    Milwaukee Wisc.
    71
    35
    Hello, How thick is it? and whats the actual size?
    redcrossnj's Avatar
    central jersey
    465
    28
    5/8 20 feet long
    Filthy's Avatar
    Northern New Jersey
    780
    850
    try propping it up on something at a slight grade and running over it where you want to bend it. my truck can bend a lot of things that i cant
    We're the renegades of Junk!
    4,758
    6,037
    I think he can't cut it as he has no saw...
  6. The Following User Says Thank You to hobo finds for This Post:
    Hard to be a scrapper without a saw. Prolly time to buy one. Or even a grinder with thin cutoff wheel would do it.
  8. The Following User Says Thank You to IdahoScrapper for This Post:
    Milwaukee Wisc.
    71
    35
    Well it sounds as though you are quite limited for tools. Perhaps you could use a tree, place it in the base of a large branch and muscle it till it bends. Or like sombody just suggested use your car / truck, back in the day, Iv'e jambed even steel stock through my bumper and frame and bend it over, around etc. I suppose you dont have a torch? you could slightly heat it and bend it, alum heats very quickly & easily.
    I wish you Luck!
    skylinejack's Avatar
    Baton Rouge, La.
    827
    1,194
    Oh wow....nevermind. Might be another kid. Dude, 5/8 in. alum. is not hard to bend. You can even stand on one end and grab it somewhere in the middle and just pull it on over and down.
    Indianapolis
    190
    227
    You need to drop a twenty dollar bill on a cheap angle grinder and get some cut off discs for it. Also, a piece of aluminum that size might have value greater than scrap to somebody. Try to estimate the weight of it, figure out what the scrap value is, and then list it in the "Materials" section of craigslist for twice or 3X the scrap value........
    This has always worked for me.
    Take a hacksaw, or a triangle file, make a deep sharp cut where you want it to break.
    Now bend it at the break (the cuts to the outside of the bend) & it will snap cleanly.
    If it bends a bit, cut deeper.
    5/8th is 22mm. It'd be probably the perfect size to break cleanly without bending.
    redcrossnj's Avatar
    central jersey
    465
    28
    guys its actullay a heavy duty aluminunm bleacher
    Filthy's Avatar
    Northern New Jersey
    780
    850
    thats a lot of extruded.
    What did I say? 5/8 is 22mm... OMG! 7/8 is 22.22mm
    5/8 is 16mm......
  16. #14
    169
    29
    If it is a big bleacher... Either invest in a sawzall (which will pay for itself on something that big) or a gas powered cut-off saw. You don't want to be cutting up a bleacher with a hacksaw!!
  17. #15
    Skilsaw armed with a plywood blade backwards and a tube of wax to lube the blade. Will cut like butter.
  18. #16
    152
    30
    20 dollar Harbor Freight sawzall. Then go buy some decent blades.
  19. #17
    Quote Originally Posted by G_P View Post
    When cutting extruded aluminum a skill saw with a plywood blade will be the tool of choice to scrap this project. 10,000 screen room builders can't be wrong! Not sure where you are from but here in Florida it is pool cage country! Pert near every home has a screen room and they were cut with a waxed plywood blade!
  20. #18
    New York
    35
    I'm definately goin for that tomorrow, will it work on stainless too? I have some fireproof stainless pipes coming from fire boxes that are laughing at my sawzall and grinder
  21. #19
    Quote Originally Posted by Ry4nscr4p View Post
    No it will not work for Stainless! Only Aluminum!
    1. Hello from Diamond Bar, CA
      By Nubsoft in forum Introduce yourself
      Last Post: 11-05-2012, 09:13 PM
    2. Shredder stock
      By gotobey in forum Scrap Metal Questions and Answers
      Last Post: 10-29-2012, 08:02 PM
    3. Best way to strip thick wire like this?
      By Backwell in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 02-22-2012, 10:33 PM
    4. Why recycling is better than the stock market.
      By CMHN in forum Off Topic Discussions
      Last Post: 08-13-2011, 11:13 AM
    5. The bar is open
      Last Post: 02-15-2011, 12:36 AM
