Results 1 to 18 of 18
Various Star Bit screwdrivers
| Tools and Equipment
    ComputerScrapper started this thread.
    ComputerScrapper's Avatar
    Portland, Indiana
    497
    18
    When we first started scrapping computers we were selling the hard drives whole but we found out that we were losing money on them as a whole. So we started tearing them down...The lid is generally sheet aluminum and the rest of the case is cast aluminum, while the disc itself is plated in platinum.
    The problem is that nearly every hard drive maker uses different sizes of star bit screws....Some of them have three different sizes in one hard drive...The more hard drives we got the more runs to the hardware store I had to make for more star bit drivers.
    rca987's Avatar
    938
    About a month ago, Home Depot had a Husky 3 set ratcheting drivers with about 80 bits for $7.00. Includes the small bits,. In all, I believe there are about 20 different stars in all sizes.
    The set includes stars, hex, torx, phillips, flat heads, and a few converters.
    It was on clearance, so there may be a chance it's sold out by now (I believe it a sale from Christmas)
    Miles City, MT
    158
    50
    I ran into that also. I lucked out and found a nice set on sale that I use.
    Portland, Indiana
    497
    18
    Thanks I will check into that....It never fails that I find something that I do not have in the way of tools. Started tearing down the first of 30 monitors today and several of them have a screw on the collar that holds the copper yoke in place that I do not have a bit for. I managed to get a few of them done by jamming a small flat head into them but that started to fail so I guess it is off to the hardware store for me until I can get to one of the big box stores. *sigh* the life of a scrapper :-)
    TJMETALRECYCLERS's Avatar
    South Carolina
    93
    Yup!
    I run in to that on several things with Computers and monitors. Be sure and check that steel collar. Most of them are stainless and I save them up and take them in about once a month. The screw itself maybe stainless and may not be, but most often, the one closest to the bottom WILL BE stainless.
    South Carolina
    93
    BTW, what are you doing with the circuit board from your hard drive?
    Portland, Indiana
    497
    18
    I seperate the hard drive boards from the rest...They are worth about $9.00 a pound so I keep them in a different area....They do pretty decent on Ebay...They refer to them as hard drive logic boards.
    wavecrazed's Avatar
    219
    hf tools
    Harbor frieght has a security bit set. 10 dollars or so. has about 30 bits.
    Here's the one I bought to go with my cordless screwguns. I think there is just about every bit available right now and the set was $9.95. I have seen them at Menard's. The screwguns have paid for themselves 10 times over. They will last a full day of breaking down smaller stuff before they need a charge.
  10. The Following User Says Thank You to Mechanic688 for This Post:
    stephenholseberg's Avatar
    Berkeley County, South Carolina
    39
    194
    NorternTool has the best security set ,that i have found on the market.
    Torker Man's Avatar
    Melbourne, Australia
    381
    Just buy the ones you need, I would never use small bits like Phillips #00, #0, #1, or T5, 6, 7, 10, 15 Torx sizes on a screw gun, they are far to fragile!!
    Buy quality!!!!!!!!!!!!!
    After spending the past 12 odd years in the tool game, if you take no other piece of advice from me, take this!!
    BUY THE BEST TOOLS YOU CAN AFFORD!!!!
    Not the cheapest you can find.
    Example. A T10 Torx screwdriver from Snap-On or Stahlwille etc might cost about $25, but you could get one at lowes for $10. That is no good when you break the lowes one 4 times a year caus its made from chees now is it?? LOL
    Cheap tools get very expensive in the long run!
    Just My $2.95
  13. The Following User Says Thank You to Torker Man for This Post:
    4,758
    6,037
    Quote Originally Posted by wavecrazed View Post
    Are the security ones the torx with the dot in the middle of it? I need to get this set!
    3,400
    1,004
    YES it is.
  16. #14
    Hobo, just look for one like I posted, their in the box. There's over 90 bits and adapters in it.
  17. The Following User Says Thank You to Mechanic688 for This Post:
    3,400
    1,004
  19. #16
    Torker Man's Avatar
    381
    Thats correct, but I say again, they are fragile. The security bits (with the hole) are much weaker (less metal) than the others, therefore, ONLY use the security ones when you need to.
  20. The Following User Says Thank You to Torker Man for This Post:
  21. #17
    There's all kinds of security screws out there. I used to run a vending business and some of the screws were a round flathead with 2 holes. Looked kinda like a snake bite.
  22. #18
    If you look in the set I showed up above on the upper left, 2nd row down there is the bits for your screws with two dots. Tork, you might hollar quality but most of this breaking down with the smaller bits I have used with one of the two screw guns like I showed and the torque on the screws was not tight enough to break any of them so far. If you get a super tight screw, you'll just stall the small motor in the gun.
    1. bit of help here, guys?
      By throwstuff in forum General Electronics Recycling
      Last Post: 11-22-2012, 06:36 PM
    2. need star bits
      By EcoSafe in forum Tools and Equipment
      Last Post: 09-06-2012, 11:36 AM
    3. i think i bit ot off more than i can chew!!!
      By zsandru in forum A Day in the Life of a Scrapper
      Last Post: 08-20-2012, 11:37 AM
    4. reputation star
      By freonjoe in forum Off Topic Discussions
      Last Post: 06-07-2012, 08:52 PM
