Results 1 to 20 of 23
Are some things always shred?
    TXf250 started this thread.
    TXf250's Avatar
    39
    25
    My yard tickets are hard to read and material just shows s. I'm getting 12.5 cents/pound and have been removing all contamination. I've been doing grills, smokers, washers, dryers, bed frames and so on. Does this sound like I'm getting shred? Are these items considered shred since its non structure steel? What have you guys been getting for this stuff? Thanks
    SuperDave's Avatar
    May 2012
    Usa
    448
    526
    Well if you figure .125 x 2000 you are getting 250/ton thats pretty good.
    boise, ID
    1,605
    469
    Light gauge metals and appliances always go as shred. I wish I was getting 250 a ton!
  4. The Following User Says Thank You to freonjoe for This Post:
    ks
    2,187
    2,513
    Me too Joe, I'm only at 8 cents a pound on shred
    boise, ID
    1,605
    469
    I think I'm at 145 a short ton, will find out today.
    Took my tickets in today and shred is down to 130 a ton. Isulated wire is down just a little and aluminum radiators and cast aluminum are actually up a couple of cents. Go figure that one!
    BroJer's Avatar
    Phoenix-West Valley
    1,004
    3,210
    depending on your yard, you may be working harder than you need to. May be a good idea to ask them, or pay close attention to others unloading, just how "clean" it needs to be. ie, i take loads of pc cases in. i get the same price regardless of if I leave the plastic fronts on or not. saves me having as much plastic to deal with and the time to tear it all off to take it someplace else. (I have a place that I can take it free, that is a mile from home, so NO... I am not just putting it in the trash) ;-) my 2 BroJer
    TXf250's Avatar
    39
    25
    Wow! I had no idea I was getting such a good price. I hope it stays that way. Well thank you so much for the replies.
    submarinepainter's Avatar
    1,025
    1,230
    My shred I leave the micro doors on and stuff them with 5 cents a pound stuff !!
    6,815
    The yards here use 1/8" as the separation point ( some others I've read about use 1/4" ) No thickness at any point can be under that, or it is light/long iron/tin/shred (all same price)
    From what I read - Shred, Tin and Light Iron are used to refer to the same thing. White goods would also be included with any of these, although "White Goods" usually refers to appliances. Bed frames, Bicycle frames and similar would go there too. Small tires, such as lawn mower and bicycle tires are usually ok. Generally, anything that is usual to the primary thing being scrapped is ok (ie: plastic trays in dishwashers and refrigerators (from which freon has been evacuated)). Generally, this category will be priced the lowest of all metals (excluding cars). Basically, throw all your magnetic scraps in this pile.
  12. The Following 3 Users say Thank You for This Post by Mick:
    1,878
    1,642
    My yard calls it sheet iron scrap. As of yesterday ( 6-14 ) it was at 220 a ton. Was at 245 a ton before it dropped on the first of june
    boise, ID
    1,605
    469
    Greytruck, is that for a short ton or a gross ton?
    6,815
    The yards here use 1/8" as the separation point ( some others I've read about use 1/4" ) No thickness at any point can be under that, or it is light iron/tin/shred
    $9 a hundred here today
  16. #14
    Russell's Avatar
    Chicago,Il
    815
    495
    I'm suprised you're still getting that price, greytruck. Being that you're relatively close to me. As of the 1st of June, up north, they dropped the price from 210 220 per ton to 170 ton.
  17. #15
    The most I've ever gotten was $210/ton (heavy iron). Currently down to $150 for shred as of my last trip on Monday.
  18. The Following 2 Users say Thank You for This Post by IdahoScrapper:
  19. #16
    USA
    436
    104
    I have gotten anywhere from $130-$210 (closer to $130 lately) for tin. It sounds like you are getting "#1 Unprepared". That is what I usually get when I clean things up and cut the metal to under 4ft. If it is 1/4inches or more in thickness and cut under 4ft. my yard will give me "#1 HMS" price which is around $260-$290/ton.
    My advice to you is if you are getting tin price, dont bother to clean things up. My yard takes whatever as long as it has some metal on it (within reason). I have taken in metal christmas trees, old baby strollers, and appliances with lots of plastic on them. Make sure that it is worth your while in time to get a better price. For me, to clean up steel sometimes isnt worth it because I only get an extra 3-4 cent per pound. Also keep in mind that you loose weight from the plastics and other materials that you remove making it less than 3-4cent per pound more. Who knows you might even make more if you dont clean it up and dont get the upgrade in price because of the extra weight. If it is quick and easy and im not loosing a lot of weight I will go ahead and clean it up. If not, I will save my time and just load it into my truck.
    With steel my yard isnt that concerned about contamination, as long as it is mostly cleaned up I will get the "#1 unprepared" price. Opposed to other metals that are non-ferrous my yard will downgrade the price even if there is just a little bit of contamination. So, with non-ferrous metals it seems to be worth it to spend a little time to clean them up. Ferrous dont spend too much time to cleanup for an upgrade in price.
  20. The Following 2 Users say Thank You for This Post by mrsamsonite:
  21. #17
    USA
    436
    104
    oh, I forgot to mention I usually put any Coaxial cables in an appliance to get tin price instead of .02/lb.
    When I do a load of #1HMS I usually throw in any small metal scraps and any copper breakage (I try to get most of the copper out of the breakage but, whatever is too hard to get out I put with the #1HMS).
  22. The Following User Says Thank You to mrsamsonite for This Post:
  23. #18
    1,878
    1,642
    Joe, That would be for a short ton or 2000 lbs
  24. #19
    little726's Avatar
    74
    1,377
    My yard will deduct for any amount of plastic and rubber left on the metal.
  25. The Following User Says Thank You to little726 for This Post:
  26. #20
    DevinThaScrapper's Avatar
    Nebraska
    588
    120
    My yard will give 10 Cents a pound on shred, It has to be 75% Metal and the rest can be whatever like plastic or wood so i usally do not strip the chairs of fabrics or strip plastic off of brooms ETC.
    1. Shred
      Last Post: 10-24-2012, 06:50 PM
    2. wheels, shred or more?
      By TXf250 in forum Dismantling, Breaking Down & Maximizing Scrap
      Last Post: 08-24-2012, 06:18 AM
    3. alum or shred??
      By mongo in forum Scrap Metal Questions and Answers
      Last Post: 03-06-2012, 12:21 AM
    4. What goes in your shred pile?
      By jonnyjeb in forum Misc. Metal Recycling
      Last Post: 01-27-2012, 09:08 PM
    5. Denver shred price is?
      By PartTimeScrapper in forum Scrap Metal Prices
      Last Post: 12-22-2011, 12:28 AM
