Results 1 to 15 of 15
Has this ever happened to anyone else?
    JunkmanDan started this thread.
    Pinellas County, FL (formerly Long Island, NY)
    87
    I ask this for guys who have pickups that they use to haul their scrap with. While unloading some old grills at the scrapyard recently, I accidentally shattered the rear window in the cab of my s10. I pulled up to the pile with my window intact, but at some point after loosening my tie down strap that held the grills together, the front-most one must have somehow shifted and hit the back window, taking out about a 2 inch chunk and shattering the remainder. I didn't see it until after the bed of the truck was empty. There's broken glass all over the ground near the pile, which can either be from unloading appliances or from other guys who had that happen to them. I have glass coverage through my insurance policy, so thankfully I didn't have to pay anything out of pocket. Has this happened to anyone else here?
    Green Bay, WI
    377
    38
    i worked in an auto salvage yard for awhile. Had steel racks to put cars up on to drain fulids/pull parts/whatever. Also had a big Dodge panel van with our torch set in it. Backing down an alley one day I wasn't paying attention and BAM drove a corner right through the door window (while my boss was with me). I got a stern talkin' to about that one.
    1,209
    Quote Originally Posted by JunkmanDan View Post
    Yup many times, I bite the bullet and replace the window on my nickel. A sheet of plywood keep the wind and rain out until a donor is found.
    Victor's Avatar
    Vegas via Canton Ohio
    169
    Time to think about one of these....BackRack Safety Racks
  5. The Following User Says Thank You to Victor for This Post:
    brandon's Avatar
    North Carolina
    787
    I use a piece of 1" foam that covers my back glass, after i unload it goes into the bed of the truck and my side boards lay on top of it.
    My fortune cookie said:
    87
    Quote Originally Posted by Victor View Post
    Maybe, but I am looking into building an easily-removable wooden box for the bed so the front plank of it should fulfill that need...
    Chesaning
    472
    24
    I only use trailers. Never have any issues with that.
    Otto's Avatar
    Ottawa, Ontario
    335
    494
    Could be a life saver. A sudden stop could send a piece of scrap right through you if you don't have a decent barrier between you and your load.
    Central Florida
    629
    117
    I have a topper that folds up against the back window made out of aluminum, saved my window many times.
    ilovejunk's Avatar
    163
    112
    yep i did that twice on an old s-10 as a matter of fact ( it was from loading fourwheelers in the truck), after the second time i went to ace hardware an got a sheet of 3/8" lexan (plexi-glass) and put that in now if something hits it it may scratch it up but it doesnt shatter and cost me another 100 bucks at the pick a part.
    Scrapette's Avatar
    Kentucky USA
    942
    2,392
    Once after I had locked myself out of my car, I tried to get to the lock using a flat head screwdriver. I was very surprised when the window glass suddenly broke into a lot of tiny pieces - I was told by the insurance company (that paid for the repair since I hadn't broken it intentionally!) safety glass shatters if you touch metal to it with even a small amount of pressure. That was good to find out!
  13. #12
    177
    Pretty common for moving firewood too. It seems that the new guy in the group will be the one that tosses the wood with a little too much enthusiasm. My wife's uncle claimed that he had at least one broken in every truck he had ever owned. Between farming and wood cutting he was a high power abuser of his trucks.
    Bill
  14. #13
    1,910
    1,682
    Never had it happen but I watch out for breaking my windows. My one truck i made a wood box and put dog cage pannels along the back by the windows. And when i load it up. I put the tall flat stuff up against it so nothing can come threw. I aint ganna be able to see out the back anyway while its loaded.
  15. #14
    Haven't broken any of my windows...but
    I use to live at a "T" intersection. I was outside and this guy was coming to a stop. I hear glass breaking and look to see that his roto tiller had rolled forward and the engine guard smashed through the window.
    Was a machine about like this. Guessing he had it in neutral.
    Also guessing he didn't get the memo on these....
  16. The Following User Says Thank You to IdahoScrapper for This Post:
  17. #15
    Massachusetts
    351
    145
    I know this is bound to happen to me
    I have been looking for a back rack since i started scrapping, but have never even got a set of ladder racks
    I dont want to buy one because i know one will turn up for free as soon as i do!
    But a good one i use is a hood up against my cab, then wedge a door along each bed side/ wheel well. It holds nicely.
    1. Replies: 4
      Last Post: 05-07-2012, 05:40 PM
    2. What happened to affect copper prices?
      By Mick in forum Scrap Metal Prices
      Last Post: 04-08-2011, 01:07 PM
