you'll likely need some type ventilation. I've seen this accomplished in many ways, the most versatile was a fan placed in fresh air, and a tube of plastic attached (it came in long rolls), you simply ran the tube to where you wanted air, and if you were working in different locations, a hole could be cut anywhere in the tube, to provide air there. When the tube got to wholey
you simply replaced it. Summertime attics can be monsters. How clean?? What is the purpose of it? Have you visually inspected any of them ? Could there be a "bug" issue? Do the attics have walk boards, or are the ceiling joists exposed and open to below? (a potential safety hazard) Think I'd have lots of questions on that, but if they want it done bad enough, You can do it
