Results 1 to 20 of 25
    lawlorlauren started this thread.
    bayville nj
    Hello I'm Lauren from jersey shore!
    Hi, I joined the forum to get some advice. I'm a young and beautiful girl who doesn't want to be taken advantage of and ripped off. I hit what I consider to be a jackpot of barebright copper about 400lbs of it I know I need to strip the insulation off to get more money for it but its taking forever!
    intros are not for asking ?`s
    Thanks for reading!!!
    Lauren xo
    6,815
    put on some old clothes, rat your hair, and wear a groucho marx face, you'll be fine! ; ) Anyway, g'luck! and welome to SMF You should try some of the build your own wire stripper threads, lots of ideas there. I've been meaning to set one up myself, just the 2x4 with a hole the size of the wire drilled in it, with another little hole drilled into the side, and a sharp screw tip adjusted in just far enough to slice the insulation
    massachusetts
    98
    44
    I too am fairly new, and posted a thread asking about a wire stripper. Try looking up reliable wire strippers it might come up.
    Welcome to the forum. Bare Bright not only has to be shiny, it also has to be thick enough(at least the size of a #2 pencil lead). If it is in good shape and in long sections you will get more by selling it and you won't have to strip it.
    Quote Originally Posted by lawlorlauren View Post
    Lauren xo
    Have someone help with making one of these and as far as being a girl, I think you'll have an advantage when you go to the scrap yard. They'll be falling all over themselves to help you. Just call around for some prices before hand for the copper. It's not bare bright till it's stripped clean. Good Luck;
    Maine.
    25
    49
    Welcome from Maine.
    Russell's Avatar
    Chicago,Il
    815
    495
    That 400lbs will become 200 lbs once stripped give or take. Keep that in mind.
    You _A: turn in as is 400 lbs x your yards wire price. Saving you x amount of time to look for other scrap.
    B: invest in a wire stripper deduct cost of it along with the weight you're loosing when you strip it. - The time it takes to strip it all down.
    If you don't have other sources or this is something you want to do as a one time thing strip it. If you have other sources of scrap either hold onto it until you have the time and need the money to sell it or sell as is and spend all that time you would be stripping ( no pun intended)... Looking for other sources.
    Do whatever will make you the most. There is only so many hours in a day/ week. Make as much of them as you can.
    GeorgeB's Avatar
    Manassas Park, VA
    2,919
    462
    Lauren xo
    It will seem like that but your looking at $1,000+ once done, so it is well worth it!
    2,864
    350
    Welcome to the forum. First of all I think Russell is wrong, I have been getting 1.25 a lb. foe insulated copper,bare bright or #1 copper I get 3.00 per lb. and you'll get alot more than 200 lbs. after stripping. There is no way the insulation weighs more than the copper. This is how I strip my copper wire. Get a chair that has hard plastic arms on it. lay the wire across the arm of the chair, lay a sharp utility knife on the wire at an angle and pull the wire under the knife blade while holding the knife still. It's easy and fast once you get used to it, the more you do the easier it gets. Good luck and keep us posted on how your doing.
  10. #10
    Russell's Avatar
    Chicago,Il
    815
    495
    Quote Originally Posted by GeorgeB View Post
    Who's getting 3$ or more a pound right now? You do realize there us a recovery rate which has yet to be determined. At best 90%, George. I may be under with 50% recovery rate, happyscraper. However, whobis getting over 3$ a pound anymore? At best 90% recovery 360 lbs the most likey scenario is what she has is 50 to 75% recovery. Prices in Jersey ate around 2.90$ at best.
  11. #11
    15,631
    Welcome to the forum. Read the old threads to maximize your profits, buy a pair of gloves and get a magnet. Mike.
  12. #12
    2,864
    350
    I don't know what the price of copper is in NJ. I said I get 3.00 per lb for #1 copper and that is what I got last wen. 8-1-12 Then again I only strip THNN or romax, idk but I think the recovery rate would be 80 or 90%.
  13. #13
    I heard that copper goes up when gas goes up is that true?
    Most scrap seems to go up and down with the stock prices or gold prices.
  14. #14
    submarinepainter's Avatar
    1,025
    1,230
    welcome!!!!
  15. #15
    Best of luck to you
  16. #16
    New Jersey
    297
    165
    Welcome from the Northern end of NJ.
  17. #17
    MisScrap's Avatar
    MD
    92
    135
    this is what I'm getting in the Baltimore area...(Maryland)....so it would definitely be worth your while to strip it...
    $3.29/lbs for BB
    $3.14/lbs for CU#1
    $2.05/lbs for Insulated CU#1
    $1.20/lbs for Insulated CU#2
    $0.85/lbs for Insulated CU#3....
    If you do the math...and have the time...you can see it's well worth your while...but you also have to keep it all coming in...
    Good luck and welcome!!!
    Read all the threads you can here...as I have found this forum to be essential in my day-to-day transactions (I am new myself...kinda thrown into the mix taking ownership of my yard) and get the mobile version for your phone...it helps if you run into problems negotiating prices...
    Last edited by MisScrap; 08-06-2012 at 08:51 AM. Reason: wanted to put in more info...
  18. The Following User Says Thank You to MisScrap for This Post:
  19. #18
    Denver
    343
    "And secondly yes I know what bare bright is, and yes its thicker than a no. 2 pencil in fact its probably fatter than most guys ****s on here."
    Awww. Burn!
  20. #19
    ^^Funny^^
  21. #20
    DropYoTop's Avatar
    Glendale Heights illinois
    157
    61
    That was really rude and Seriously obnoxious. Why are you ranting and raving?
    1. Hello from New Jersey!
      By bosco4317 in forum Introduce yourself
      Last Post: 10-21-2012, 12:05 AM
    2. New Jersey Shore Area!
      By OtusLotus in forum Introduce yourself
      Last Post: 07-19-2012, 07:44 AM
    3. Hello from South Jersey
      By DerrickInNJ in forum Introduce yourself
      Last Post: 03-07-2012, 11:59 PM
    4. Hi from New Jersey
      By Alex in forum Introduce yourself
      Last Post: 01-08-2012, 10:30 AM
    5. New in New Jersey
      By fnd5055 in forum Introduce yourself
      Last Post: 07-05-2011, 01:43 AM
Tags for this Thread
